Home | GPX | HMTU3234 Shelf System | Cassette Player
GPX HMTU3234 Shelf System
Problem for GPX HMTU3234 Shelf System
Cassette Player
By Vinnie on Mar 07, 2006
Tape plays too fast. Cleaned audio heads/guides and replaced belts. Still plays too fast on both decks. Any adjustments/component checks I can do?
Same Problem
Mar 08, 2008
-   My belts needed to be replaced because the tapes would not eject. Now the tapes play too fast. Could I have threaded the belts wrong?
Please help,
Fred-   fredr
Best Solution
posted on Mar 14, 2006
Helpful)
silly girl
Rank: Wiz
Rating: 81%, 3597 votes
Motor speed needs to be regulated by PWM. Reducing the current (with a resistor) actually lowers the torque - which, with a given load, does result in reduced speed - however, different length tapes (60min vs 90min), as well as different quality, and even current position in the tape, will change the load and hence the speed.
You need to regulate the speed via PWM. It's sometimes done on a small board built into the motor, in which case you'd have a round hole into which you could insert an INSULATED screwdriver (tiny flathead wrapped most of the way in electrical tape works).
It may be done on the main board, in which case you could find a pot conveniently labeled "motor speed", or perhaps "pulse width" or "pwm" or something to that effect. Find it, mark its current position just in case, and turn it to see if it gets the effect you're after.
And there are some tape decks in the world with no speed adjust - they are designed with a specific speed motor and the sizes of the wheels and gears are calculated for that speed.
Also there may be a mechanical fault/malfunction causing the speed problem.
An initial check and thorough cleaning of the capstan and pinch roller should be done. If there is a buildup of tape oxide or a piece of a broken tape wrapped around the capstan, the tape travel will be too fast (do to the effective increase in capstan shaft diameter).
If the pinch roller isn't fully engaging, the tape can be getting pulled onto the takeup spool at a speed faster than the capstan control.
A different source of trouble might be a slip clutch (possibly an
idler/clutch assembly)which is binding, or otherwise not functioning the way it should.
Another type of motor doesn't have it's speed controlled by an internal or external voltage.. instead, the motor has an internal centrifugal speed controller. This type of motor can be found on older tape decks, and might not have been utilized more recently.
Good luck
Was this helpful?
Yes
No
Solution #2
posted on Feb 05, 2008
Somewhat Helpful)
chie-chie
Rank: Wiz
Rating: 85%, 124 votes
  • very easy.. if your motor 12 v or 6 volts...for 12 volts motor buy an ic "kia 7812 this parts is voltage regulator with 12 volts 1a output..7806 this parts is volt.reg with volts 1a output..7803 3 volts output etc. etc.
  • input 1st terminal
  • ground mid terminal
  • output 3rt terminal
same a transistor.
Was this helpful?
Yes
No
Solution #3
posted on Jul 10, 2008
Not Rated)
letter123
Rank: Apprentice
Rating: 0%, 0 votes
yes I have yorx combo radio player cd player tape player and record player model no. L150. The problem is tape won't slow down on both tape deck sound to fast or has gitter to it. I don't if it bad motor or something else around that motor. same motor driven both tape deck . I have check the voltage on the motor won't stay same it changes 10 volts to 14 volts.
Was this helpful?
Yes
No
Solution #4
posted on Jan 07, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had this same issue with my stereo. I found that the rotation of the capstan was being blocked by a little glob of a red substance. I removed the substance and it allowed the capstan to rotate freely.
Solution #5
posted on May 28, 2007
Not Rated)
BenjaminaBOY
Rank: Master
Rating: 68%, 19 votes
It might be a button error like the play button is making the fast forward button work.
Was this helpful?
Yes
No
Popular Solutions for GPX HMTU3234 Shelf System
Questions and Unsolved Problems for GPX HMTU3234 Shelf System
Do you recommend GPX HMTU3234 Shelf System?
Answer
Answer
just i have for 6 monts and star turnin of when i up volume more then half why
Answer
cd player will spin for a second then it stops
Answer
everytime i insert the tape it goes fast forward or rewind only, any idea? help please...
Answer
Does anyone have any idea where I can get at least a copy of schematics for this model as well as a... (More)
Answer
my cassette player in the car caught a tape. After some struggle, it broke and I was able to repair... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GPX HMTU3234 Shelf System:
Top Audio Shelf System Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Audio Shelf System Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
