TV timer i set a timer on my TV for it to come on at a certain time (eg. 10:00am), and set it an off time for it also (eg. 2:00pm). Why does it constantly go off after 2 hours no matter what time/how long i set it for?
  • Anonymous Jan 19, 2009
    hello
    my lg 29 in tv give a some problam in between colour pathies comeing
  • 28 Answers
You are most likely setting the sleep timer.
Posted on Sep 18, 2008
Can the timer be turned off for periods of time without losing the settings and how to ?
1) Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/UPM-timers-and-manuals.html
2) Unsure which timer you have.
Digital wall timers usually have back-up that holds memory for certain length of time before current time disappears.
Usually the programs remain indefinitely until timer is manually reset.
3) Why do you want to turn timer off?
Usually in-wall timers consume 3 watts of power per year.
Contrast big screen TV consumes 3 watts per hour standby loss when TV is turned OFF.
Feb 12, 2013 | UPM Programmable Wall Switch Timer
Why does my tv turn off automaticly
Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. M Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. M Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. Malena!!
May 10, 2012 | Vizio Televison & Video
I can't figure out how to set the sleep timer and i have no manual
On the remote there is a button called sleep. Every time you press it the time will increase in half an hour increments. Eg: Press it four times and the display will show 120, which means the TV will switch off after 120 minutes.
Mar 08, 2011 | Sansui 27" TV
Over tv its getting aoutmatically off
Hello
Put your hand on the back of your TV to check for overheating, if your set keeps switching itself off without warning.
Many TV sets come equipped with a safety feature that switches the power off if the set gets too warm.
Check the cooling vents located at the rear of your unit. Vents can collect dust and dirt, resulting in the fans becoming blocked and failing to work properly.
Remove dirt from the vents with a damp, clean cloth. Ensure the air conditioning is kept at adequate levels in the room where your TV is located. Keep the drapes shut on hot, sunny days to keep the room cooler.
Check the sleep-timer function on your TV if it keeps turning off. A sleep-timer is used to turn a television set off after a certain period of time has elapsed. If the sleep-timer is not turned off, your television will continue to turn itself off after a certain period of time.
If the problem persists,then a heat sink has gone bad.
The on/off button simply toggles a low voltage circuit that powers your tv. If it is dusty, it may complete the electrical circuit and send a false signal.
Take a can of compressed air, open the back and clean the dust off the circuit boards.
NOTE;opening the TV VOIDS warranty!!
Dec 22, 2010 | Televison & Video
Turns itself on at night on standby
that is could the timer setting in your menu check if is not set to start at a certain time....if yes turn it off
if not that could be a bad ground in the timer circuit
but normally its the timer setting in your menu.
hope that will help regards
Alan
May 09, 2010 | Toshiba REGZA 47HL167 TV
I want a programmable timer that can, eg, switch on a single phase electric motor for 10 seconds every hour. It may be 9 secs or 11 secs.
You need a programmable interval timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET70
Intermatic and Tork make digital timers with interval settings that can be set for specific short-duration with 1 minute minimum.
(Or set to pulse bell ringing with 1-127 seconds.
10 minutes is 600 seconds)
For example ET70115 single-channel timer.
The timer would be set for 24-hour operation, and then programmed for Pulse, and then set timer with 24 programs, with 1 program for each hour.
Mechanical cycle timers from Intermatic:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#cycle
1) Talento 1 hour cycle timer/ each tripper represents 1.25 minutes
2) Model C8835/ each tripper represents 15 seconds.
To operate these timers certain hours of the day, add another timer in-line.
The in-line timer could be digital, but remember digital timers are not protected from power surge and tend to have more problems, and do not have replaceable clock motors and trippers.
Apr 08, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
My tv will shut off all by itself while watching
Has the sleep timer been set for a certain time ? If not is it the weather affecting your areas power supply ? I'm not 100% certain but a surge protection socket in the mains outlet might solve your poblem
Oct 15, 2009 | Samsung DLP HL-P5663W 56" TV
Timer
firstly check your sleeping timer set ups. if that is okey, then check the following
the power supply components eg
power transistor on the power supply lekage
zener diodes, power diodes of the bridge rectifier.
in short the supply is drowing to much current, hence semiconductors are heating up and reach a cutoff point, and saturates
Mar 29, 2009 | Toshiba 35A44 35" TV
Olevia TV Remote doesnt work Sleep Timer
The TV is in 'showroom mode'. To fix: Click: Menu --> Picture --> Mode --> Power up then select: Home. Then click menu until you exit the settings. You will now be able to use the sleep timer.
Mar 10, 2009 | Bose Cinemate Digital Home Theater System...
Setting automatic shut off
How do I set on PCB to automatic tv shut-off?
Jun 29, 2008 | Curtis-Mathis CM19011 TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
