Question about HP (J7941A) Print Server
HP print server appliance 4250 (J7941A)
When the unit is booted, it passes the post tests but then hangs on booting. Possibly its lost its software. any ideas James
    Scholar:
  • 47 Answers
Can you connect to the Web Interface? See http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=179111&taskId=101&prodTypeId=18972&prodSeriesId=27375 for more details. If it's truly lost it's firmware, you're probably toast, as I didn't see the availability of a serial port. I'm betting you don't have a support contract for it with HP, so if your firmware is gone, I'd recommend saving some cash and replacing it.
Posted on Sep 14, 2007
Cd start server primergy b210 fujitsu siemens
In order to change the boot drive you have to change the boot settings in BIOS, or sometimes you can get a separate boot menu which allows you to change this setting on a one-off basis. During the boot sequence you need to press the "F12" button during the POST testing to bring up the boot menu if one is available, otherwise you need to press the "Del" or "F2" button during the POST process to bring up the Bios screens. Navigate to the BOOT option and alter the boot sequence, save the settings, exit BIOS and reboot.
Feb 18, 2014 | HP Compaq ProLiant ML110 G4 Server
E-E61 media test failure check cable pxe-mof exiting pxe rom. operating system not found. how do i find it
Hard drive lost communications with motherboard. Remove it and reseat it. Check BIOS if it sees the HD.
Disable PXE boot in BIOS or remove from 1st boot option. This is a LAN (network) boot option. It can't find a DHCP server, that's why the media test failure is displayed. It's usually used to load an OS image from network.
Oct 05, 2012 | Acer Aspire 9410z Laptop Computer 17"
ML3670 does not boot as it does not found an boot disk
Replace HDD (Red Flashing ).It seems you have unknowingly disturbed your Raid . If Possible take backup of your server.Reconfigure RAID and Freshly Install OS .
Apr 04, 2012 | HP ProLiant ML370 G4 Server
Proliant server running Linux hangs at "attempting
I'd say the hard disk went bad. See if it'll boot from a live cd to copy your data off of the linux drive (if it's accessible at all).
Dec 30, 2010 | HP ProLiant ML370 G4 Server
Hp mini 110 1115sa hang on hp logo screen..
Well, I just want to comment something about it. I got the same problem and I am following the treads over the Internet and found a lot of complains to HP and few ideas; and for those whose guarantee is finished by this date, like mine, we got trouble and no real solution.
I reset hardware, and it didn't work at all. So, it seems it's just a little push for the HP Bios to work properly because the problem resists. I replaced the memory module and the same symptom. I didn't flash the Bios and didn't use the Recovery Software as those steps were mentioned not to work for this issue.
When the mini boot, I tested the Hard Drive with the utility from HP BIOS and it passed, also the Ram did. I tested them with third party software and passed, both mounted in this mini. Everything pointed out that replacing the Hard Drive would work. I installed a new 250 Gb Toshiba HD and at first boot a "clack" noise came from the HD maybe in the middle of the POST and it passed and the message that "select other boot device, bla bla.." appear. Good, but at the second try, the same problem came out: HP mini hangs on the HP logo screen. Please, any ideas will help this community. Do this new drive is bad too?
I feel some overheating, (I don't know what Atom temperature should be), by the dissipator and guess it would freezes the POST routine, or simply the BIOS is malfunctioning. I noticed that when the mini was turned off for a long time, it boots without problems even with the original hard disk and it loaded and worked fine in windows 7. Besides, I could start a Disk Clone process in order to get the same original installed software from HP. But this failed, too. Norton Ghost report "an internal inconsistency error". I guessed this was because of the bad sectors the original HD would have. After this step. I got acces to both disks using Partition Magic and other tools, even though, I partitioned the new HD. I just found a partiton table error in original disk and was fixed by Partition Magic. Everithing, as I said, looked great to remove the original HD an install the new one. But you already know.
Again, any help will be appreciated. Thanks for reading.
Nov 08, 2010 | Computers & Internet
Hello, I have a problem with: Machine is HP netserver E800 Runs MS W2k SBS. Hardware ? single PIII 933, board supports second processor IDE onboard controller with CD Problem booting up....
why not ask HP this. and not on the chat forums here,
this is NOT HP. not in the very least.
F2 sounds me , its the command to reload the OS.
did you lose the manuals on this server?
it tells you what F2 means, id be there in a heart beat at hP
in fact id down load all books on it now, because soon or now
there will be no PIII books at all, its a relic, pentium 3.
Can you boot to say a linux live CD.
or a window PE live cd?
your server will not boot to USB so, that out. (modern ways)
if yes your OS is dead, or HDD dead.
reload the OS. now. try that using the books for this server.
is it RAID? or one IDE disk.?
what does CD problem mean
why not tell the helper why is a CD in your hand
and how made it and if and OS install who's , HP or microsoft
we can not guess what you are attempting with CD in hand.
if the CD will not boot 3 disks,
1: yours.
2: linux live
3: windows live.
then the CD drive is dead, or you need DVD drive.
the newer OS needs a DVD drive, for sure.
i think (omg long ago) windows 2000 is on 800mb CD.
to boot CD you must tell BIOS to boot there first. force it.
true on all PCs and now impossible (near) with W10 and UEFI and secure boot enabled, (said or watchers looking here)
get a test CD with LINUX and test the boot.
this proves it can boot and BIOS is using it.
POST - memory count
power on self test or POST??????????????????
is this a BSOD , blue screen of ***** off a new CD from HP?
if yes the CD drive is DEAD< end of life gone and now reads corrupted data, as most do this old, buy a new CD drive.
now.
this BSOD if is, can be seen on 1000000 of posts (messages about POST, LOL where the guy doing it, used CD-r disk that are pure JUNK> or a burner old that is trashed.
please post here X your P.O.S.T screen,. I always wanted to say that.
there you go.
May 25, 2017 | HP NetServer E800
Hanging print queue on Canon iR2200-3300
my ir2200-3300 canon printer m/c ip adders change automatically in 2-3 days pl. solution my problem?my email ID sudesh_trivedi@yahoo.co.in
Nov 20, 2008 | Office Equipment & Supplies
HP (J7941A) Print Server Logo
224 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
