Question about Cannon 10476G Dual Fuel (Electric and Gas) Kitchen Range
Cooker gas cooker dont cook food on regulator number cannon came out said fine as a great cook of 50 years am at wits end
  • Anonymous Mar 20, 2014
    Twin regulator replacement
How do i take the cooker off auto?
Posted on Jan 27, 2009
Della 12 Quart 1600-Watt Electric Pressure Cooker Multi-Functional Timer Slow Cook XL Part number: 048-GM-48261 Unable to get this cooker to slow cook.
it is possible that you have misunderstood the instructions
for a slow cooker you have low medium and high
press slow cook and on low and in 8 hours the food is cooked
I see from your statements that you expect the cooker to be set on slow cook but cook at a high temperature fast
if it says slow cook --9 hours and the temp is 125 degrees , have you waited 9 hours to see if it is cooked as the slow cooking process is by the gradual build up of heat in the container that is not expelled by radiation to the air
in a pressure cooker , that build up of heat also builds up pressure and so it cooks better
other solution--- if it is not right return it for a warranty refund or if out of warranty , junk it and get a different make
Mar 25, 2017 | Crock Pots & Slow Cookers
Paula deen pressure cooker. Can I use it for slow cooking? What is temp of keep warm? Could put lid on loose. Also, timing notches are mixed into keep warm button. I overcooked my first batch
A pressure cooker is NOT anything close to a slow cooker. The cooking philosophy are practically totally opposites. A pressure cooker basically cooks your food in a fraction of time because it is under pressure. A slow cooker takes hours.
The whole idea of using a pressure cooker is that it is sealed and applies pressure to cook the food faster. The lid needs to be sealed for the pressure cooker to operate properly. It is frequently referred to as "infusion" cooking now days.
You need to read the instruction book that came with the pressure cooker. Pressure cookers usually cook for less than an hour--my homemade pressure cooker spaghetti sauce is cooked in less than 30 minutes. They are nice and were very popular long before anyone thought of microwaves and slow cookers. However, there are some precautions to be taken. There must be water or liquid in a pressure cooker. The rubber seal needs to be cleaned frequently and, when the rubber seal warps/stretches and no longer seals, it needs to be replaced. There are also certain foods that CANNOT be cooked in a pressure cooker like rice, dry beans, etc. The pressure control valve operates to regulate the amount of pressure and releases extra pressure otherwise the unit would blow up (very dangerous!). Most pressure cookers (required on all new ones) have a small rubber emergency stopper that will "blow off" in case the pressure is too high. I've seen this happen and my mother cleaning potatoes & meat from the ceiling!
Mar 03, 2017 | Crock Pots & Slow Cookers
My cooker keeps releasing pressure during cooking & there is therefore no pressure to release at the end of the cooking process resulting in uncooked food
Your valve is leaking. You may be able to replace it or repair it. It is usually easier to replace the cooker, unfortunately. Sorry.
Dec 30, 2015 | Instant Pot IP-Lux60 6-in-1 Programmable...
I have never had a slow cooker in my life and found this one in a garage sale without the manual. How does it work?
Yes you can use any cheaper cuts of meat or chicken and yes less liquid is used in slow cookers. add hard veges n use green veges for end of cooking time. cook for 6 or 8 hrs on low. Yeilds ecellent results. Find slow cooker books for great meals n desserts. I use mine every week.
Apr 22, 2015 | Crock Pots & Slow Cookers
I just bought a Hamilton beach slow cooker. Does anyone have any good family friendly recipes I could try?
There are some great and really easy recipes available for free on the internet for slow cookers. See this link for some good 'family friendly' ideas: http://www.netmums.com/family-food/recipes/food-recipes-slow-cooking
Jul 15, 2012 | Hamilton Beach 33176HB Hb chrome 7 qt....
Have a frigidaire gas stove has worked great for 6 years. Now we are getting a strong smell of gas when it is heating up or cooking. Have checked to make sure flame is on and it is. It also seams like it...
Try changing out the regulator for the stove. Does the flame seem weaker than it used to? If so, your regulator is probably going out and the gas you smell is the residual leaking out when the stove is on.
Jul 01, 2011 | Frigidaire Ovens
No gas to lower oven - Cannon Camberley
Hey Stephen - try setting the clock then set the cook period. the oven will only work when that's on i think.
May 07, 2009 | Ovens
Russell hobbs slow cooker no recipies for casserols in enclosed book please advise
Here's a great set of threads on receipies for slow cooker's.
http://bellybelly.com.au/forums/recipes-cooking-food/17924-slow-cooker-recipes.html. You will need to adjust to suit your slow cooker. Cook times vary by wattage just like cook times vary for Microwave Ovens. Also, your altitude can affect cooking times.
Since you didn't mention your cooker's model, start out at Amazon to find a copy, but look for a used one as it may be much cheaper.
Start here:
http://www.amazon.co.uk/Russell-Hobbs-10951-dual-cooker/dp/B0000E5SPN
Hope this helped your dilemma and fixed your appetite.
May 21, 2008 | Kitchen Ranges
Low Gas Pressure on Smeg Range cooker
there should be a regulator on back of the stove where the gas line connects.you will see a plug that unscrews,remove this plug and run the unit.if this solves your problem clean the plug really good and put back on.
Dec 25, 2007 | Kitchen Ranges
Open Questions:
Cannon 10476G Dual Fuel (Electric and Gas) Kitchen Range Logo
337 people viewed this question
Top Cannon Kitchen Ranges Experts
Paul Carew
reyaazm
Level 1 Expert
Tom Chichester
Are you a Cannon Kitchen Range Expert? Answer questions, earn points and help others
