Question about RCA R56WH76 Projection Television
Rca r52wh77 help!!!!
My tv had a convergance problem, a friend tried to put a new fuse in and screwed up the board cause now it wont turn on. can anyone tell me what the part # is for that board, where i can get it and what is cost around. i have looked everywhere it seems and have found nothng.. thanks to anyone who can help..
  • wayfastytee Sep 14, 2008
    can anyone help me with wat part number thatr board is on the left side where the fl231 fuse is on. and what they usually run in cost... please i really wanna fix my TV asap..thanks to whoever can assist me or point me in the right direction..
  • wayfastytee Nov 14, 2008
    looks to be R52wh77yx58 or 50 does that # ring a bell. this is the main
    board where the fuse fl231 is located bottom left board right when u
    take off the back. if so please email me @ gixrsixr@gmail.com thanks.
    also what do these run around? i cant even see the part on rcas website
    Genius:
  • 1,030 Answers
To replace the power deflection board. i will need to know the family number this is a yx1 or yx38 or something like that that is found after model number..there are two model numbers on label this is a small number above the larger model number for instnance it can be r52wh77yx1... very important to get correct number.. these boards if you can get them range from 350 to 65 just depending on that number
Posted on Oct 03, 2008
RCA R52WH77 ITC222A chassis convergence problem - FL231 changed!
did you hear an arch before it went if so , one of your crts is arching
and sorry they are not avail anymore
Sep 20, 2009 | RCA Televison & Video
How to adjust the convergence on my RCA R52wh77 tv there is no convergence button on system anywhere. TV is only 2.5 yr old and I really don't want to pay $300 to have them come and adjust tube when I can...
you have to go into the menu,sometimes convergence is listed in the video section.
the chasis number is ITC222.
some had manual convergence then you have to adjust red onto green,blue onto green DO NOT MOVE GREEN
if it has autoconvergence activate it.do not do anything until its done.
Sep 18, 2009 | RCA R52WH73 Projection Television
3 blinking power button lights RCA R52WH77
have you tried checking some voltages in the convergence board it could be the damage is there and not the deflection board since the 320vdc was connected thru the yoke. you can also try to deactivate the convergence board to see if the tv set will remain on this will give you a better idea of where the problem is. good luck!
Aug 13, 2009 | Televison & Video
R52wh77 3d raunbow picture and no convergence option in menu. Should I get a new TV?
there are 3 fuses in a row next to the flyback
transformer.solder all the pins on the flyback
and replace the middle fuse.check the other 2
fuses.this is very common with RCA.
Jul 18, 2009 | RCA HD61W66 61" Projection HDTV
Tv help!!!!
ok to replace that board you have to have the entire model number. it will be on the label in small letters it will be likke r52wh77yx1 or ......yx38 or something like that ...this is critical in getting the right part
Sep 09, 2008 | RCA P52937 52" Rear Projection Television
How to remove fuse
solder will have to be removed from component solder side..
Jul 29, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA R52WH77 convergence missing from menu
THis is very common on these sets. there is a special fuse thats cause this.. kinda hard to get rca part number 259213.. .4 amp. the reason this blows is there is bad solder connections on the flyback. so when you replace this fuse you have to resolder these connections. so if you know how to solder and can find this special fuse. it is a fast and easy repair
Apr 08, 2008 | RCA P52937 52" Rear Projection Television
Convergence
Two boards govern this circuit . 1) convergence power supply board # 271860 2) convergence amplifer # 271861 . In most cases amp board is your problem . You might want to check the amp board for loose connections on it .Most of the times its the cable sockets on the borad have loose pins . This the board that has the metal heat sinks in a row of about nine of them on the board . Good luck
Mar 11, 2008 | RCA HD52W59 HDTV Projection Television
I have a rca hdtv r52wh77 1 year old ,i have color problems ,i cant get to the convergence set up ,please help.thks
Try looking at the main board very near the flyback and you should see 3 fuse links (they look like hard capacitors) one of them is probably open causing lack or power to the convergence board by way of the ribbon seated close to the vertical output IC
Dec 22, 2007 | RCA P52937 52" Rear Projection Television
Open Questions:
RCA R56WH76 Projection Television Logo
129 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
