Question about Water Pik Flow Valve Assy. Series II Bronze 325
No water flow though pool pump
Why would there be no water flow through pool pump?
  • William Walsh Sep 18, 2013
    Perhaps I was not clear in my description of the pump. This a pool cover pump that pumps the water off of the pool cover.
  • Anonymous Mar 18, 2014
    How to collect the condenser water for discharging into sewage conduit?u
    Problem Solver:
  • 4 Answers
Check and see if all valves are turned in the appropriate positions. Sometimes homeowners forget to switch the valves from spa mode to pool mode or vice versa and wonder 'why isn't my pump pushing water?'. Another thing to consider is what type of pump you have. If you have an owners manual, check and see if you have a flooded suction pump or if it's self priming. You may need to dump water into the trap before seeing water flow through. You may also have faulty valves or check valves. Check your filter and make sure all positioning of valves are in proper place. If all else fails...call a pool professional. These small self performing tips are just something to consider to save some money in the long run in lieu of calling someone that may poke your eyes out with a service call and something as trivial as turning a valve. Hope this helps!
Posted on Oct 10, 2008
4 Suggested Answers
SOURCE: Hi- I'm a new intex above ground metal frame pool
how do I hook up my 1000 GPH intex filter pump?
Posted on Jul 18, 2010
  • 11800 Answers
SOURCE: I have a Waterway SVL56
That means that the connection between the motor and the actual centrifugal pump is broken. This is terminal: replacing the broken part will cost you more than the price for a brand new pump. Just cut your losses and replace it.
Posted on Dec 18, 2010
  • 297 Answers
SOURCE: pool pump intex 51 pumps water but return flow is low
if you cartridge is completly clean then start by disconecting the out tube that goes to the pump housing
sometimes debris gets caught there entering your pump.
a little hair causes other things to back up
once you are satisfird that those 2 things are ready then close it all up and open the bleeder cap on top of the cartridge holder
Now let water in from the suction side
when water starts coming out of the bleeder cap then open the return side
Now turn on the puimp
let it run for 20 seconds and then close your bleeder
Should be working fine after that.
dont forget to leave the bleeder cap alone on the bottom of the canister unless you are draining the water from the canister to clean it. As soon as you are done close it back up
Posted on Jul 15, 2009
Pool pump surges water no steady flow
Check your water level, skimmers and weir gates, and the o-ring on the pump lid where the basket is. Air is getting in somewhere between the pool and the pump basket.
Mar 14, 2014 | Pool & Spa
Motor is burning hot to touch, causing water in secondary trap/pump strainer to heat up. Also, noticed little to no air pressure in pool jets. What could be causing this issue?
Jason
this sounds as though there is no water going through the strainer into the pool. check the gate valves to make sure you have water going to the pump and that water can get back to the pool.
check and valves or backwash valve on the pool to make sure the filter is open to be able to let the water filter to the pool.
something is stopping the water flowing to the pump or preventing the water to move through the pump into the pool.
Rod
US Parts Center
Feb 05, 2013 | AO Smith Centurion 1081 2 Hp Standard...
Water not flowing to jacuzzi but still flows to pool? Might anyone know what I check first have no idea?
There is no way you have water flowing to the inlets of the pool and not have the pump working.
What do you mean by the word "Jacuzzi" in your statement?
Is this a set up where you have a diverter that the water is used in both the pool and the hot tub?
Rod
US Parts Center
Jul 05, 2012 | Jacuzzi Pool & Spa
Water flow error
Water Flow should be like this
Pool Water-
May 22, 2010 | Intex Automatic Salt Water System for ...
No water flow in pump
The impeller in the pump unit could be broken. If there is water flow into the pump, but no flow back to the pool, the impeller is most likely broken.
Make sure the hoses are not hooked up backwards.
Jun 20, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Water not flowing out of pump
Have you primed the pump by bringing water down to the pump? It will not work if the supply line is not filled with water from the pool.
Pool heat pump won't keep running
It is likely that you have a low refrigerant condition and require an HVAC person to service the unit. It's not unusual to need "freon" every so often. Call the repair man...
Mar 03, 2009 | Hayward 116k BTU HeatPro Digital Heat Pump...
Water Pik Flow Valve Assy. Series II Bronze 325 Logo
4,207 people viewed this question
Top Water Pik Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Water Pik Pool and Spa Expert? Answer questions, earn points and help others
