Question about E-Machines Computers & Internet
Stays at 100% Cpu usage, I have E machine W3307
  • gotnoclue355 Sep 10, 2008
    apdproxy.exe is program is taking 99-100% CPU usage. What is this and do I need it. I'd be greatful for any and all help
  • 258 Answers
Ok... if using winxp press ctrl, alt and delete keys together to bring up task manager select processes tab and find out in the cpu column what program is using high number (percentage) in cpu column. That is the program that is causing it, if you don't know what the program is by the name of file let me know and will be happy to further assist you.
also.....if you are using vista press ctrl, alt and delete together and select task manager....then follow the same instructions as above.
Posted on Sep 09, 2008
  • Brett McGuigan
    Brett McGuigan Jun 22, 2009
    Name: adobe photo downloader
    Filename: apdproxy.exe
    This is a valid program but it is not required to run on startup.
    This program is not required to start automatically as you can run it when you need to. It is advised that you disable this program so that it does not take up necessary resources.
    To disable this tool below is really easy to use and can stop this program from running at startup.
    Windows Startup inspector, click the link below,
  • 2,961 Answers
There's a good chance you have a trijan, assuming you have an antivirs programme, run it in safe mode (F8 on startup and enter using safe mode), use the administrator account to log into windows, and then go to my computer icon, right click>properties>system restore tab, then turn off system restore.(viruses and trojans have a back up in system restore)
Run anti virus programme, restart pc then turn system restore back on
If you don't have an anti virus/spyware you can get a free download with free updates here, (choose the avg free download)
What is 'vmhost.exe*32' and is it necessary?? Its using upwards of 70 CPU Usage making my pc VERY sluggish.
The file VMHOST.EXE is identified as the Trojan Program that is used for stealing bank information and users passwords. DO NOT PUT ANY PERSONAL INFO IN ANYWHERE. Run virus scans or take to a professional
Jul 01, 2014 | Acer Aspire Computers & Internet
Constant 100% CPU usage
you have to get safe mode if you have win xp /7 .also need to check malware and remove unwanted start up programs.
Apr 04, 2014 | Toshiba Tecra 9100 Laptops
100% cpu usage
In Task Manager, go to the Processes tab and sort by the CPU column. See what is hogging up all your CPU. It may be a virus, if so, I recommend downloading Malware Bytes and doing a full scan. Warning, it could take several hours to scan depending on the size of your machine. Good luck!
Nov 23, 2013 | Patrick M. Kolla Spybot - Search &...
CPU usage 100%
This is due to memory and program usage.
Depending on your computers specs. try these steps
1. Disk clean and defrag
2. Virus, spyware, malware, Trojan, rocket scan and removal
3. Registry cleaner and optimizer
4. Check disc space on the C: drive
5. Turn off unnessasery programs auto starting
If this does not work it maybe that you need to upgrade your computer or add some extra RAM.
Sep 28, 2013 | Dell OptiPlex GX280 PC Desktop
High CPU usage from interrupts and ACPI.sys
go to bios see if the cpu cap is off or on also go to system in computer and adjust all index options can also try cpu usage controls in control panel
Feb 28, 2013 | Computers & Internet
I am not really sure if this caused by the fan performance, but I can confirm that my laptop dell inspiron 1420 is very hot after running about 1 hours.. and often my CPU usage reach 100% when I use Vista...
First, I appreciate the details provided in your question. Thanks!
The specification of your laptop are fine and enough to run and support Vista. It is true that greater number of processes and CPU usage causes, but normally the machine can handle it well if it gets proper ventilation.
Laptop heating issue generally occurs due to fan failure, which may damage the system, if not checked properly. Another cause of overheating is the dust present inside the laptop, which clogs the fan and heatsink. I suggest that you should get you laptop checked by a professional for servicing (if required). I believe immediate action is required to prevent any damage to your machine and data.
Hope it Helps! Let me know if i could be of any further assistance.
Nov 25, 2010 | Computers & Internet
100% CPU usage
Try to monitor the CPU usage before opening CROME. If it is normal before opening it then there is some process under CROME which takes you CPU usage report to GOOGLE on this. and remove it through Add/Remove programmes under control panel.
Try to use Firefox instead of CROME.
If it happens again then there is some thing wrong with OS( most probabaly Spyware or trozen).
Jul 30, 2009 | Computers & Internet
CPU Usage jumps to 100% and down to 2% when I change websites
I'd say it has NOTHING to do with how or when you access Yahoo. In fact, anytime you see an extreme jump in CPU usage like have to consider that you may very well have a TROJAN VIRUS that's hogging up all your memory (among other things viruses do). If you don't have a good anti-virus program, then get one fast. Update all virus definitions, then.......RUN a FULL scan on your pc or laptop! Watch what you find.
Mar 31, 2009 | Yahoo Mail
CPU Usage Meter 100%...... Indexing..... HELP!
What processes are you running?
Check taskmgr.
You will find there what is going on, and which program and processes are running on your computer taking the 100% CPU usage.
Dec 30, 2008 | Dell Latitude D430 Notebook
Computers & Internet Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
