This is in reference to the TV link for the psp. the audio cables are easy and self explanitory but I would like to know How I would plug in the red blue and green cables, which colors would connect to the red white and yellow inputs on my tv
  • 927 Answers
Good Day, kk;
It means that your TV link and TV are not compatible.
Sorry, big IRISH.
Posted on Sep 09, 2008
I understand about rca cables it's the green plug cable that I don't know where to put it. It doesn't fit anywhere.
RCA refer to the type of plug, the color code is for visual reference:
In standard video in/out:
Red: Left audio channel
White: Right audio channel
Yellow: Composite Videos
YPBPR Analog Composite video:
Yellow (Luma)
Blue (Blue Difference)
Red (Red Difference)
Orange is used for Digital S/PDIF audio.
For a detailed chart of RCA connectors color code:
Mar 08, 2015 | RCA Televison & Video
I just bought a new dvd player and it references the hdmi which I know the tv does not have. Will it still work with this tv?
Probably, you'll just need the audio and video cables separately. Most DVD Players still have Component video (one cable with 3 video plugs on each end and the two channel (red and white) RCA audio. Your TV also has an AV input (one cable with a single RCA plug on each end - usually yellow for video, plus the audio cable) and S-video.
The component video is your best choice with modern DVD players if you can't use the HDMI port.
I hope this helps.
May 01, 2010 | Toshiba TN55X81 55" Rear Projection...
Do not know how to install to cable box tv
Connecting this up will be easy. What you do is get a yourself a set of the right, for your setup, cables. That uses EITHER one of the formats, of these described, below. You will need, either, a THREE way Cable, or three separate " Coaxial Cored" Cables with RCA PLUGS on them. ColoredYellow, (Video) Red, & White. (Audio) AV. OR If you have SCARTConnection Sockets, it's a big Black Socket at rear of unit(s), you get aSCART Cable.& It's all inside. Now some units, use a standard calledComponent Video, that uses, a Green, Red, & Blue Plugs. Now, with the Component setup, you will also ,need, Two more Cables, for the AV Audio. these are, Red & White.(So with Component Video there are 5 Cables/Plugs in all). In any event ALL Cables go Color to Color, at each end, plugging into the corresponding Colored RCA Jacks, on either machine, or VCR or TV. Now if you have SCART, then it simply plugs in only one way. It is that simple. So connect up with the leads your set uses, and select the correct "Input" from TV/Remote, it is NOT on a "Channel" it will be on AV, AUX, and Press "Play" on VCR/DVD whatever.... should be all go.
Feb 16, 2010 | Curtis CMD1000 DVD Player
VHS to Easy capture to computer
The plugs you speak of are called RCA plugs, (Male side has an outside ring with "slots" around the edge, and a pin in the center. Female side has a short round "riser" with a hole in it). You need just standard Audio/Video hookup cables, available at any electronics store.. Walmart/Target/Kmart has them in the TV section. They get plugged into the Audio (Red & White) OUT of the VCR, into the Audio IN (Red & White) of the Easy Capture. The Yellow lead is for Video In/Out between the VCR and Easy Capture. The black is probably the S-Video connector, (round, has very small square hole, surronded by 4, 5, or 7 tiny pin holes) that can be also used to connect video/audio between VCR(if so equipped) and Easy Capture. Get a set of audio/video dubbing cables (abt $10 usually), connect Red to Red, White to White, Yellow to Yellow. Plug the Easy Capture USB cable into your computer (most likely), start the capture program. Start your vcr, hit Play. You should see your vcr tape playing on the computer screen.
Aug 18, 2009 | Televison & Video
Psp slim component cable
on the back of the tv, plug the blue into blue, red into red and green into green for video and the red and white into red and white for left and right (respectivley) audio.
Then go to your psp and select tv out on the left side of the XMB and select your output aspect ratio and your all set!
Jan 08, 2009 | Sony Video Game Consoles & Games
PSP update ver 4.05
I assuming it's an OFW psp. The other way to update is through sony's website. You will d/l the upgraded firmware to your computer then to your psp via usb. The directions they give is pertty much self explanitory. Follow every direction to the letter. But you don't have to d/l 4.05 you can go up to there newest firmware they have now. Anymore problems please feel free to ask.
Oct 13, 2008 | Sony Limited Edition PSP Daxter...
Can't connect psp component cables to tv
okay. here's what you need to remember as i encountered the same issue and had it resolved.
1. connect the psp tv out component cable to the tv. make sure you have every cable in their correct plug-ins.
2. on your tv remote, press output until your tv displays the correct output data info. it will display component 1 or component 2. make sure this aligned with where you connected your component cable.
3. turn on the on the psp, then press and hold the display button ( it is near the start and select buttons on your psp, with a box like icon. after 5 seconds, it will give you a gray screen with a box icon and an arrow which means you are transferring the data out from the psp to your tv display.
4. enjoy your psp on tv!
Aug 08, 2008 | Video Game Consoles & Games
DC doesn´t has image
try a different av cable or jiggle the connectro on the dreamcast av port
Apr 10, 2008 | Sega Dreamcast Console
Cant figure out how to get my psp to connect to the tv with my av cables
Okay if you got a psp slim plug them into the headphone jack and the on your tv select that input channel(where you plugged in the av cables to the t.v) then to get the display on the t.v hold the display button next to the music note button. 1 more thing if you didn't get the component cables and just the regular red yellow white ones you won't be able to view games on t.v
Feb 21, 2008 | Sony PlayStation Portable (PSP) Console
Televison & Video Logo
Top Televison & Video Experts
