Question about Sanyo DS27930 27" TV
Sanyo ds27930 I need to know how much it would cost, or if it is even worth the trouble of replacing the board within my tv. The cable connection was torn out of the back of my tv. When I took a look at it, it is soldered to a board (no wire), and the board has part of it broken off so no connection can be made nor for to solder back on. The board would have to be replaced. I can find a technician to do the job, but I do not know if it would be worth trying to get the board vs. getting another tv. The bad aspect is that I just purchased this tv within the past 2yrs. Any suggestions about the cost and if it is worth it? Thank you for your time.
  • techdumbgirl Jan 12, 2008
    Is the isolation block a little mmmm-silver suitcase looking thing?
  • 513 Answers
Cost for repair on that usually averages 45 to 65 dollars... unless tuner is damaged in most cases not. if not hooked to tuner then maybe a new isolation block..simple job
Posted on Mar 07, 2006
Sanyo tv model ds27930 not supporting my ps3
Whatever input you are using is either damaged or the tv is on the wrong channel and I'm sure you don't have it set on the wrong channel.
1. Another method would be to connect an old VCR to the TV through the cable plug on the back of the TV.
2. Then plug your PS3 or dvd player into the VCR's rca inputs on the back.
This works but your television has to have a cable plug on the back.
Oct 16, 2013 | Televison & Video
Tip
Sanyo DS27930 Manual Download
Download Sanyo DS27930 TV Manual
Have you misplaced your Sanyo DS27930 TV Owners Manual?
Would you like a digital, searchable, pdf version of the Sanyo DS27930 TV Users Guide?
Follow this link
(& click FREE) to download a pdf version of the operations manual.
I hope that helps.
____________________________________________
on Apr 30, 2010 | Televison & Video
Tip
Follow this link
I hope that helps.
on Apr 26, 2010 | Sanyo DS27930 27" TV
Can get tv to change to av1
The Input button on the original remote is needed to switch to the AV1 or AV2 connections. Unfortunately, I do not believe that the Sanyo DS27930 has an equivalent Input button on the TV. A replacement remote is available here: http://www.emtcompany.com/sanyo-ds27930-remote/rc64.html . Other universal remotes may be able to transmit the Input signal. You will need a remote that was programmed over 6 months after the TV was released with an Input or Source button. Then try all Sanyo codes until you find one that controls all of the features.
I hope this helps.
Mar 04, 2013 | Sanyo DS27930 27" TV
We have a Sanyo DS27930 TV. We just noticed that there are fast moving white horizontal lines that move continuously through the picture. It is very irritating to watch especially when the picture is...
Hello
You are talking about interfearence lines that comes across the screen of your TV from top to bottom, as moving at an inch thick or so, I thinks. It may be due to the external interfearence, or to some faults inside the TV. You just check the antenna connecting socket at the rear of your TV. It must be moderately tight. Check whether its internal connecting tab has a break or not. If there is some loose or break, replace the same.
Another fault is due to its power supply regulator section. You should check it from the mains filter capacitor to all parts fitted in the power supply section inside the printed circuit board of your TV. It must have some skill, concepet of soldering and desodering, knowledge to follow schematic diagram and more patience.
Also check whether a computer or any like high frequency working equipments set beside your tv. It may also cause some sort of intereferance. Ok.
Oct 31, 2010 | Sanyo DS27930 27" TV
Connected DVD player to Sanyo DS27930 TV via input
According the manual for this TV the remote control has an input button, it is left of the power button. Make sure that the remote mode slected for TV not VCR or DVD and press input button to make a selction, make sure that the power to the DVD player is on. If yours is different try stepping through the channels buttons, some TVs input is selected through the channel buttons.
Jan 02, 2010 | Sanyo DS27930 27" TV
No picture on flat screen new, with cable
IF THIS IS A LCD---TURN ON, AS NORMAL AND HAVE A SIGNAL INPUT,,CABLE ,SATELLITE CONNECTED TO THE ANTENNA INPUT .MAKE SURE YOU HEAR SOUND.. HOLD A LIGHT (THE BRIGHTER THE BETTER) IN FRONT OF THE THE SCREEN ('BOUT 3 INCHES)--IF YOU SEE A DIM PICTURE---BAD SCREEN AND THATS BIG BUCKS---IF STILL NO PICTURE--CIRCUIT BOARDS AND USUALLY THATS BIG BUCKS!! GOOD LUCK
Mar 16, 2008 | Sanyo DS27930 27" TV
Need original remote
Not sure, but have you tried getting a universal remote and programming it with a sanyo code? If this is not an option you can get MFR. remotes on ebay, but they might be costly. I went to ebay and did a search on "DS27930". I found one seller, but there was a least one. $34.95 for a remote sounds high to me.
http://cgi.ebay.com/Sanyo-FXWK-DS27930-DS32424-DS32920-DS36930-6450610165_W0QQitemZ5846882733QQihZ012QQcategoryZ15065QQrdZ1QQssPageNameZWD1VQQtrksidZp1638.m118.l1247QQcmdZViewItem
Feb 10, 2008 | Sanyo DP19648 19 in. LCD TV
Universal remote codes
i need remote codes for a star choice remote to be used on a sanyo DS27930 27" tv please help
Dec 23, 2007 | Sanyo DS27930 27" TV
No progressive scan from component input
Sanyo DS27930 does not support progressive scan
DVD player must be set to interlaced scan
Nov 24, 2007 | Sanyo DS27930 27" TV
Sanyo DS27930 27" TV Logo
124 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
