Question about Weber Q Grill
Model Q200, Propane model Get no flame on the burner. Apparently, getting no gas. Something seems to be stopped up. What to do?
    Brigadier General:
  • 4,736 Answers
Whether you're using a 20 Lb Propane Grill Tank or a screw in gas canister, the solution to the problem is the same .
1. Be sure you have enough gas in the tank or canister to maintain proper ignition.
2, If the above checks out OK. Turn the LP tank valve OFF or if you're using a screw-on canister
turn the gas valve OFF.
3. Disconnect the hose from the tank or unscrew and remove the gas canister.
4. Wait 5 minutes and reconnect the hose to the tank or reattach the canister to the gas valve.
5. Open the gas valve VERY, VERY SLOWLY (Slow Motion, slow). Once the valve is full open, light
the burner & turn it to HIGH. Did the burner light and does the flame height look correct?
If so, you solved the problem. Remember to always open the tank valve Very, Very Slowly.
if the above didn't solve the problem, you will either need to replace the Hose/Regulator Assembly or the Gas Valve/ Canister Holder. The Hose/Regulator Assembly you can pickup from any home center or hardware store that sell grills & accessories for about $30.00. If it's the Gas Valve/Canister Holder, you will have to purchase that from Weber or from Factory Appliance Parts http://www.appliancefactoryparts.com/gasgrillparts/brands/weber/q200.html Part # WEB4195 ($29.99) The adapter hose is also available there if you want to make it a one stop shop for $32.99
I hope ths helped you and thanks for choosing FixYa. Happy Grilling!!
Posted on Aug 26, 2011
I bought a dcs fryer at a restaurant auction. I had it installed in my restaurant, and when I got it going flames were shooting out of the back. I had it looked at, but because there is no serial number...
The difference between Natural Gas Set Up and Propane Gas Set Up on Fryers are as follows:
Natural gas burner orifice has larger bore (#52) than Propane Gas burner orifice (#55 or #56).
Gas Valve's spring kit for natural gas has less tension (thinner) than Propane.
You have to order burner orifice ( the quantity depends on the number of burners your fryer has), pilot orifice and Gas Valve Spring Kit for Propane Gas if your fryer is set for Natural Gas or vice versa.
Regards.
Jun 22, 2011 | DCS Kitchen Appliances - Others
Model 720-0164 bbq low propane to burners now no propane to burners,,,new bottle.. how do i trouble shoot to see if it is the regulator
What you have is a classic symptom of a bad regulator. If no gas is going fromt he new tank to the burners, you can bet it is the regulator. No real way to test it once it stops working all together. As it is going bad, the flames on the burners will get smaller as each buner lights.
Mar 12, 2011 | Jenn-Air Grilling
Weak flame on webber q200 grill
Remove connection to tank, reconnect, open valve slowly, when you open valve to fast the tank valve has a shutdown in it, it thinks something is wrong and shuts valve down. Always open tank valve slowly when using.
Also your tank valve could be sticking causing this problem, to fix replace tank.
Feb 25, 2010 | Weber Q200
Flame going low on range cook-top
Check your gas supply is not running too low and then check for leaks, Let me know if this helps.
Jan 02, 2010 | Tappan TGF320 Gas Kitchen Range
Cal flame gas conversion
hi my name is mark, there are several possablitys why it can not be converted, one could be the orifice is pressed in manifold, another is it might require a different burners with air shutters and a regulater. it was problably designed for propane only, to save cost.
Mar 13, 2009 | Cal Flame 5-Burner
The southbend 436d range gives a yellow flame at the burners
Hello. Please advise if your unit is supposed to run on propane, at the bottom of the oven door is a smaller panel, depending on age, it either lifts slightly, and then folds down, or clearly has screws on the front. Your Model/rating plate is behind this, either on the back of the panel, a tag screwed to the frame, or on the bottom ledge of this area. It should state what gas the unit is meant for, propane or natural. If it was not converted to run on propane, or made to run on propane, this is your problem. If it was built/converted for propane I would suggest you contact your propane supplier, or a restaurant service company to look at it, it would require a few specialized tools, pressure testing, orifice size req., and burner BTU. to go much further than cleaning the dust out of the burner, and cleaning the orifice.
Hope that helps, and thank you.
Feb 12, 2009 | Southbend 436D-2GR Gas Kitchen Range
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
Jan 02, 2009 | Ovens
Flame way too high and yellow-Frigidaire Model #FGF328GM
call an approved frigidaire gas technician as it is possible that the jets in use are not for the propane gas
they are probably natural gas jets which have a larger jet size
the air shrouds around the jets have to also be adjusted to get the blue flame
you may be able to have it checked out under warranty as it is new
if you touch it your self , the warranty will be void
Mar 11, 2017 | Kitchen Ranges
Gas stove burner/oven noises
too much air on top burner ,delayed ignition on oven ,ignitor not lined up properly or check gas presure may need regulator adjustment or replaced. gas 784
May 12, 2008 | Ovens
Burner flame height adjustment
All ignitors will always arc whenever one of them does.
I haven't worked with propane systems much, but it seems you may need the propane pressure regulator adjusted.
If the problem is only with the power burner, I would ensure that particular orifice was actually changed. The hole in a propane orifice is smaller than for natural gas.
Jan 08, 2008 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Weber Q Grill Logo
301 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
