Question about HP Compaq Presario V5000Z Notebook
My dvd rom does not Exist what should i do? - HP Compaq Presario V5000Z Notebook
  • Jaipal Reddy
    Jaipal Reddy May 11, 2010
    Hi s_honest,
    Need some infromation about your computer.
    1. May I know the version of Windows you use? Is it XP or Vista?
    If the operating system is XP, perform the below steps and let me know:
    a. Click start -> Select Run -> Type devmgmt.msc -> Click Ok.
    b. Click on the + sign next to the DVD/CD ROM devices and let me know the entries listed there.
    If the operating system is Vista, perform the below steps and let me know:
    a. Hold the windows key and press 'R' -> Type devmgmt.msc -> Click Ok
    From the above steps let me know the exact DVD/CD drive entry listed there, also check if you have any yellow exclamation mark on it.
    Thank you.
    President:
  • 2,961 Answers
Firstly set a system restore point, just incase you make a mistake, then click start>run, then type regedit and press enter.
in the listing look for HKEY_LOCAL_MACHINE_SYSTEM, current control set,control, then class.
Left click on the folder 4D36E965-E325-11CE-BFC1-08002BE10318 and look for entries named lower filter or upper filters on the right hand side of the window.
If any are found, right click on them and select Delete.
Close regedit and restart pc, it should then re-appear
Posted on Sep 09, 2008
How do I unlock my philips DVD player, model DVP3600
this very difficult, since all manufacturer has special code for certain region. Do not exist universal code for alll region world.
All manufacturer put in the ROM of the microcontroller the special TOC, for guide the DVD to read only the region that they sell.
However you must read your instruction manual for to see the indication for to see which format read your DVD.
God bless you
Jul 11, 2012 | Televison & Video
Lost access to my DVD/CD ROM after updating Microsoft files. Running Vista on a Dell Inspiron 1721 laptop. Tried to delete low filter in Regedit but that filter does not exist.
you can try to searh for upperfilters in the registry and delete it. if it did not exist, kindly try to perform system restore on your computer as it is a way as well to restore the registry settings. ( restore your computer to an earlier time as the DVD/CD is still working )
May 10, 2011 | Computers & Internet
I have an acer aspire 5520 and the dvd rom doesn't even show up on the hardware. I update all the driver and got a new dvd rom and still nothing. please help....
Removing the UpperFilters and LowerFilters registry values from the Windows Registry is a likely solution to several Device Manager error codes in Windows 7, Windows Vista, and Windows XP.
UpperFilters and LowerFilters values might exist for several device classes in the registry but those values in the DVD/CD-ROM Drives class tend to corrupt and cause problems most often.
Important: Changes to the registry are made in these steps. Take care in making only the changes outlined below. While it's not a necessary step to complete this process, I recommend that you play it safe by backing up the registry keys you're modifying.
You can follow the step by step text instructions here. If you prefer a screenshot step by step guide, you can click here.
Hope this information helps!
Apr 07, 2011 | Acer Aspire 5520-5908 Notebook
Cant find dvd rom?
If you can't find the DVD ROM, try to click the start button, then click My Computer. Then try to find if the opticcal drive / DVD drive exist on it. If it is not, try other options..
You may uninstall it from the device manager by clicking Start > right click My Computer > then click Properties > then click Hardware > then click Device Manager. Under DVD/CD ROM drives, right click the device and Uninstall. Then restart the pc and go back to device manager. Then click Scan for hardware changes let it auto install the drivers. Check if it works....
Sep 20, 2010 | Toshiba Satellite M105-S1021 Notebook
Samsung DVD-ROM SD-608 needs drivers
hello, try the driverguide link below seems to have drivers you are looking for, can download it by either free registration or watching few ads. I have used site several times myself and can be trusted.
http://members.driverguide.com/driver/detail.php?driverid=32269
Hope this helps.
Kind regards,
Amar Sondhi
Jan 24, 2010 | E-Machines etower 500id PC Desktop
Dvd rom problem
Try to turn off the vista's burning feature.
It's not yours or anyones burners....just an update in vista which buggered the policies up
Go to your run command and type (start.....Run.....)
type gpedit.msc
Go to User configuration/Administrative templates/Windows components/Windows explorer
On the right pane, double click on "Remove CD burning features" tick the enabled button, then OK.
Reboot or logoff/logon to apply.
If your vista version does not have the gpedit function, do the following.
Open regedit, go to:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
In the right pane, if it does not already exist, create a new 32-bit DWORD value. Name the new value as NoCDBurning, and assign the value data to 1.
This should fix the problem
Sep 07, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
In dvd rom probelm nor read the data or music only blank disk
Hi, this problem occurs if yours DVD ROmis old or used most often, to sovle this you have one solution i.e open the DVD Rom clean the LENS with a IPA (ISO Propyle Alcholol) but remeber to clean with the help of a soft cloth & close it immediately after closing the DVD rom check the CD's /Dvd's.
More often if this not helps you'll have to change the DVD rom as it costs only 1000/- INR approx.
Regards
kunal
Jul 14, 2009 | Toshiba Satellite A135-S2276 Notebook
Iv lost my dvd rom icon on my laptop
You could try restoring the system to an earlier date with system restore. If your good registry has been saved this may solve your problem.
Apr 27, 2008 | HP 373314-001 - HP Multibay II 8X Laptop...
Using the pm63005dvd laser lens cleaner:
exist some software but i will NOT recomended you to use couse it will work just few days and u have to buy new cdw/r.ok?
Sep 04, 2007 | Computers & Internet
HP Compaq Presario V5000Z Notebook Logo
26 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
