Pop up weindow
I am using Vista Home Premium. As soon as Windows opens, I have recently begun getting a series of windows stating :-----
Please wait while Windows configures the HPProductAssistant.
Deleting that window, brings up the next :---
The feature you are trying to use is on a CD-ROM or other removable disc that is not available.Insert the HPProduct disc and click O.K.
Deleting that window, brings up another :----
An installation package for the product HPProductAssistant cannot be found. Try the installation again, using a valid copy of the installation package ‘hpproductassistant.msi’
Deleting that, the others come up again in the same sequence, and eventually disappear after deleting each as they appear again..
Can you advise how I may stop this sequence appearing each day ?
  • pixieanne Sep 09, 2008
    Your reply would be applicable to Windows XP or earlier, but unfortunately not for Vista. Can you advise further ?
  • pixieanne Sep 13, 2008
    Thank you 'aocartas' for your suggestion. However, when I opened the startup tab, the HP Product Assistant is not listed. The only HP items listed are --- hpsysdrv Application / HP Software Update / HP Health Check Scheduler..
    Have you any further suggestion ?
    Problem Solver:
  • 7 Answers
Here's the fix, run it and remove the hpproductassistant entry. It works, I struggled with this a long time.
http://download.microsoft.com/download/e/9/d/e9d80355-7ab4-45b8-80e8-983a48d5e1bd/msicuu2.exe
Copy entire link, paste into browser, install and run. again, just remove the hpproductassistant entry.
Posted on Sep 10, 2008
Hi Ma`am,
You can stop this message from appearing by deleting it in the start-up configuration. How to do this is go to start then run, on type msconfig. A menu will appear then go to start up tab then uncheck the the HP Product Assistant. After the configuration was done the computer will ask to restart your computer. Try if the popup windows will still appear.
Posted on Sep 09, 2008
Did a clean install of my laptop. Windows does not acknowledge Windows Vista Home Premium
There will be a sticker on the laptop wi the product key. It will be in the format of xxxx-xxxx-xxxx-xxxx-xxxx Sometimes the sticker will be under the battery. If the sticker is not on the laptop it was either removed, or you need to make a complaint with Walmart.
Apr 17, 2013 | Dell Inspiron Computers & Internet
I could not upgrade neither windows XP, Windows 7 of this Product Model: GT5662. Would you assits? Thanks.
Hello kelvinvu, according to the information that I gathered from this computer model, it has Windows Vista 32 bit home premium installed on it. Windows XP is an older operating system so you can't "upgrade" to it. You could however install a fresh copy (more likely completely erasing all your previous information on vista and data files) or you could upgrade to Windows 7. Since you are using "Windows Vista 32 bit home premium", you have to upgrade to "Windows 7 32 bit home premium" or better. So if you were trying to "upgrade" to Windows 7 Home Basic, it will not allow that since it considers that a downgrade in the Operating System. You should actually be able to pop in the Windows 7 Home Premium CD while vista is running and start the upgrade process pretty painlessly that way. Just access the CD and walk through the menus for upgrading Vista to Windows 7. As a reminder, you must use the 32 bit discs. If you try and use the 64 bit discs (a different operating system as far as windows is concerned) you will have to go through the same process of installing a new version of windows (not upgrade). I hope this has solved your specific problem kelvinvu, have a great day!
May 15, 2011 | Gateway GT5662 Desktop PC
I open Portrait Professional Studio v9.8 and as soon as it open windows vista home premium states the program has stop responding and shuts down. I have used it in the past with no problems but cannot...
windows vista is known for having problem rendering graphics (its the reason win7 was released just one year after vista) try right clicking the program icon and selecting properties. Then tell the system to run the program in win xp sp3 compatibility mode. If still nothing, then you should seriously consider upgrading to win7 to stop the 1k+ bugs and holes that are in vista from eating your hard drive and graphics processor up.
GOOD LUCK AND PLEASE RATE THIS POST!!!
May 09, 2011 | Anthropics Technology Portrait...
Windows vista to windows xp
OK. Hi, You can actually keep upgrade but you have to buy a license from Microsoft.
When you are asked to register you can option to call 800 phone number & explain that you want a license for a second computer. They can issue a new key to activate your upgrade.
Hope This helped If you need more assistance please comment back. Please rate. Good Luck!
Mar 12, 2009 | Microsoft Windows Vista Ultimate Edition
HP Solution center doesn't start...
I'll assume that you actually have an HP printer (or scanner) attached to this unit.
Uninstall the HP drivers and software which came with your HP printer (or HP scanner) and reinstall it from the driver discs (reinstalling the HP software over the existing installation may take care of it also). If you don't have the discs that came with your HP equipment please post what model you have and I will track down a link for you to download the necessary stuff for reinstall.
Feb 26, 2009 | Acer Aspire 5315 Notebook
Unable to logon in to my system,it shows user profile not found.
Yes, use your installation disk (hopefully you have one), and run the repair utility.
Feb 02, 2009 | Microsoft Windows Vista Home Premium with...
Explore won't open in Vista (not IE, I mean windows file explorer)
Most likely a damaged or altered registry entry. Clicks start and type
'regedit' and hit <enter>. Expand the keys at left to reach:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Click on this key, then locate the shell string in the right pane. Double
click it, replace the contents with just:
explorer.exe
Click ok, then close the registry editor and reboot.
This will resolve the issue.
Good Luck.
Live, Love, Laugh.
Apr 30, 2008 | Microsoft Windows Vista Home Premium with...
DEVICE DRIVER PROBLEM FOR Sandisk SDCZ4-2048
Here you go:
http://www.sandisk.com/Retail/Default.aspx?CatID=1092
Feb 16, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
766 people viewed this question
David Payne
David Payne
