Question about Acer Veriton 5200 PC Desktop
AGP 4X CAN I USE A 2X 4X 8X GRAPHICS CARD ON THE ACER VERITON 5200.
    Brigadier General:
  • 6,966 Answers
Specs sheets for an Acer Veriton 5200 says that it has one AGP 2X/4X expansion slot, therefore the answer to your query would be a yes. Even if your add-on video card is 8X, it would still work however the card would downgrade itself to only $4X.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 09, 2008
Will a NVIDIA GeForce FX 5500 video card work on a P4B533-E motherboard?
HI Lau_kua08,
First off, your motherboard is a AGP 4x slot, and the Card is a AGP 8X card. However, NVIDIA based graphic cards which support AGP 8x mode (Accelerated Graphics Port) follow the AGP 3.0 specification. The AGP 3.0 specification retains backwards compatibility with older AGP 4x technology. All NVIDIA Geforce and Quadro GPU's which support AGP 8x mode are downwards compatible with AGP 4x motherboards. When a graphics card which operates at AGP 8x mode is installed on a motherboard which only supports up to AGP 4x mode, the card will automatically switch to AGP 4x operation.
So, yes it will work.
Good Luck,
Mark
Oct 27, 2009 | ASUS P4B533 Motherboard
Vga card
high resolution is supported by high resolution monitors or LCD no matter what type of Video card are you using so first check monitor compatibility with the resolution
Oct 05, 2009 | EliteGroup K7SOM Motherboard
Compatability
You have an AGP expansion slot for a graphics card.
It uses either 1x, 2X, or 4X graphics cards. Since the only AGP graphics cards out there are 4X or 8X, the 1X, and 2X are moot points. (They were also Junk anyway!)
Your AGP graphics slot only supports AGP graphics cards that are 1.5 volts. There are AGP graphics cards out there, that are Universal. Universal in that they will run as AGP 8X, (.8 volts), or AGP 4X, (1.5 volts)
This is an example:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4103516&CatId=318
Don't expect to play the high end new intense games with this. I'm afraid you'll have to update your motherboard, processor, ram memory, and a better graphics card to do that.
(Example? XFX Nvidia nForce 680i LT SLI motherboard, Intel Core2 Duo E8200 cpu, Corsair XMS2 PC6400 ram memory, 1GB x2 of them, (DDR2 at 800MHz), and XFX Geforce 9800GTX+, vid card. (Plus OCZ SteathXStream 600W power supply)
This won't break the bank, and will slam some games to the wall!)
Jun 05, 2009 | Intel D845GBV (BOXD845GBVL) Motherboard
Looking to upgrade video. is there a limit to uprade old mboard
Only cards that work with this board are AGP 4x graphics cards or possiblly AGP 8x cards that are backwards compatible. If you buy an 8x card do your research to make sure it's backwards compatible before purchase. Newer graphics cards are pci-express x16 or pci-e 2. These will not work with your board. Hope this helps & please remember to rate my answer. Thanks.
Jan 10, 2009 | Matsonic MS9327E (MS9327E+(USB))...
Graphics card support to motherboard D845GBV
AGP 2.0 and 3.0 4x and 8x feed with the 1.5v spec. AGP 1.0 1x and 2x was fed at 3.3v. In short, you should be fine.
May 15, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
AGP card to replace inboard graphics card
Yes, your GeForce is compatible with the BRIOs AGP 2X port. And there is no problem in using an 8X board in a 4X or 2X AGP slotted motherboard... it would only be a problem if you have a 1X AGP port which is rather old (fisrt agp ports on the market).
Apr 16, 2008 | Computers & Internet
Agp 8x vs agp 4x
the 4x card WILL work in an 8x slot but it will only run at 4x speed because of the card limitation. also, the 8x card WILL work in a 4x slot but it will only run at 4x speed because of the slot limitation. i've done it. peace
Nov 05, 2007 | Palit Microsystems GeForce FX5500, (256...
Installing GeForce 5200 on Dell Dimension 2400
I suggest that better check that graphic card in another machine and make sure it is working.
Also find out the data transfer speed of your mother board through the AGP slot is compatible with your graphic card. (e.g. 4X, 8X, etc.)
If you are sure that your system really has an 8X AGP port (A choclate colored slot) then you could deffinitely install the card and work with it.
With the information I received the Dell Dimension 2400 deos not features an AGP 8X port, in that case it is not possible to install the card.
Then you should buy a new motherboard with AGP 8X Port to be able to install the Ge force FX 5200.
Nov 03, 2007 | PNY Verto GeForce FX 5200, (256 MB) PCI...
Compaq s4020WM AGP Questions
I don't think there's a 8x AGP card made that would not work at 4x, and any 4x capable AGP slot should handle an 8x card. AGP 1.0 (x2) signals at 3.3V AGP 2.0 (x4) signals at 1.5V AGP 3.0 (x8) signals at 0.8V
Apr 05, 2007 | Compaq Presario s4020wm (DK214AR#ABA) PC...
Acer Veriton 5200 PC Desktop Logo
124 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
