Question about Pioneer MEH-P5000 MiniDisc Player
Changed settings(LP to SP)
I changed the record setting from LP to SP,Still no sound?
    Novelist:
  • 196 Answers
If there is still no sound, you probably hooked up the unit's wires wrong. Try switching the wires coming off of the back of your head unit so that the wire that is supposed to be connected to the amp turn on in your factory harness isn't connected to the antenna lead or something like that. I don't know what the Pioneer wires look like, on my Sony there are two blue wires, one with a white stripe on it and one just plain blue. The wire with the white stripe on is the one that should be connected to the amp turn on in the factory harness.
Posted on Mar 06, 2006
Why does my camera stop recording after one hour? i need to record 90 minutes
Your camera records in two modes: SP and LP modes. SP is a higher quality mode that runs for about 60 minutes, while LP records for 90.
To change to LP mode, open the menu and select [VCR setup]. Select [REC MODE], set it to [LP] and close the menu.
Keep in mind that your video and audio will be of noticeably lower quality with this setting applied.
Mar 08, 2011 | Canon ZR200 Mini DV Digital Camcorder
I need to know how to switch the tape speed from sp to the long play setting without a remote. the universal remote i have wont give me the option. it records only 2 hours on a 6 hour tape instead of 6...
Normally this setting is found on the remote if there is no parallel settings on the panel of the set.
So if youhave lost the remote controller the universal remote must be changed to one which can select the speed settings. Normally the default settings is on the SP mode while the LP mode needs to be selected.
The other option is to identify the trigger of the main processor and use a manual switch to turn on the LP mode. Check for the manual of the set and look for the LP output pin of the processor.
Here the SP mode output also must be taken into consideration so that you can use a manual 4pole two way switch to activate the SP-LP mode.
Otherwise you may need to get the original remote control from the OE maker.
Jan 03, 2011 | Televison & Video
How do you switch tape speeds to LP on a Sony Handy cam TRV 240
You can set tape speed SP or LP in record mode only and can not change it in playback mode.
To set tape speed, turn camcorder in camera mode and go to Menu and set SP or LP in record speed option.
Jan 03, 2010 | Sony Handycam DCR-TRV240 Digital Camcorder
I can't find what i recorded, help! Why are some SP and some LP. What does this mean?
sp and lp are speeds.(you set it) does it say there are any records? if so you may have added on to the end of one. not creating a new one. or you may have not recorded it at all.
Nov 16, 2009 | Olympus VN-960 Digital Voice Recorder
Change VCR settings from SP to LP or EP
Hi;
I have a Panasonic VCR with a different, but I know how to 'fix' your problem on my m/c. The remote for my m/c has a "REC MODE" button; operating that button changes from SP to EP etc. Check it with the "Program" button on your TV screen.
harrisonmx3
Apr 27, 2009 | Panasonic Televison & Video
Mikomi ET858 digital voice recorder suddenly switched from saving files as .WAV to .ACT, whatever that is. Can play interviews on machine itself, but can't save them to computer. Help! How do I switch it...
Hi all,
I recently bought this little headache of a dictation machine to help me with my Law revision. Had similar problems but have worked out the following:
The machine appears to have 2 modes of recording - LP and SP. When the machine is in LP mode, it appears to be a format for the machine itself to allow for longer record time. Because of this individual format it will not play back on computers. If, however, you change it to SP mode (from what I can ascertain from the VERY unhelpful user manual is 'high quality recording' i.e. standard WAV format) it saves the file in a .wav format which is playable on computers.
To switch it from LP to SP (this is on my dictation machine only - i take absolutely no responsibility for breakages etc):
Turn on
Press 'M' to cycle to 'REC' mode
Use the Volume control to cycle between SP, SP VOR (no idea what VOR is i'm afriad), LP and LP VOR
Record as usual.
I've made test recordings on both SP and SP VOR and both save to WAV format and can be played back through a computer.
If anyone knows what VOR is then please shout back.
Hope this helps.
Liam
Apr 10, 2009 | Dictaphone Walkabout 5210 Digital Voice...
Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Nov 24, 2008 | Sony Handycam DCR-TRV730 Digital Camcorder
Changing my record mode from SP to LP
In order to change the menu settings you must 1.)turn on the power 2.) Touch FN to display PAGE 1. 3.) Touch MENU to display menu. Use the arrow buttons to scroll until the TAPE SET menu is highlighted. Press the exec button to reveal SP in RECORD MODE. Press it again to bring up a menu that will give you the choice of SP or LP. When you're done press the exec. button a couple of times and you're done. Do Keep that even though the tape will run 1.5 its normal length there are certain features that cannot be used while in Long Play (LP) mode. I have a sony camera but was looking at your model camera yesterday. I noticed that many of the menus and navigations were the same. I'm assuming that my directions will at least allow you to know what menu to look for. Good Luck.
P.B.
Oct 15, 2008 | Sony Handycam DCR-TR7000 Digital Camcorder
Setting the tape speed
Power up camera on Camera mode, go to menu, select camera settings, go to Record Mode and select SP or LP there. Now your camera is ready to record as per selection.
You can not change speed SP/LP during playback mode because its properties of signal set during recording.
Mar 15, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Pioneer MEH-P5000 MiniDisc Player Logo
49 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
