Question about Canon PIXMA MP780 All-In-One InkJet Printer
Memory light flashes
When I power up the unit it will not print, the memory light is flashing, and when I press the power button to turn off, I get a Machine in use can't shut down message.
  • 1 more comment
  • sramzz Sep 09, 2008
    This is a Canon Pixma MP780 all in one, and the problems I describe are not listed in the manual.
    While the suggestion to look in the manual is valid, the manual for Canon Pixma MP780 does not address the problems I've described, i.e will not print, memory light is blinking, when I push power off, message says can't shut down, machine in use.
    Thank you, the printer is functioning again
  • 1,031 Answers
If all jobs have completed and you are sure that there are no pending jobs, disconnect the interface (parallel or USB) cable from the device.
disconnect the telephone line cord from the device if applicable
Disconnect the power adapter from the device.
then Shut down the computer.
Wait for some minutes then reconnect the power cord.
, press <ON/OFF> to power the device back on.
Reconnect the interface cable (and telephone line cord - if applicable) to the device.
Turn on the computer.hope this helps
Posted on Sep 09, 2008
  • Starnley Johnwells
    Starnley Johnwells Sep 09, 2008
    Connect the telephone line cord to the appropriate port on the device. The telephone line cord must be connected correctly for the device to function properly if any before powering the printer device
    Master:
  • 726 Answers
  • unplug the printer from the mains supply
  • hold down the start button on printer while reconnecting the AC supply
  • hold start button for 2/3 secs
  • release.
    Brigadier General:
  • 5,158 Answers
Please confirm that you have the usb connector into the proper connection on the printer. it's easy to put it into the phone connector by mistake
Robert
Please rate this solution ... thanks
    Brigadier General:
  • 6,966 Answers
Initially, pls try:
  • release.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
    Genius:
  • 1,269 Answers
Try to unplug the power and USB cable of the printer for about 5 mins then plug it back in. Check if you can print again. If not, go to Printers and Faxes, Right click the printer icon and click "Use Printer Online". Last option is Uinstall and Reinstall the driver of your printer. Use the setup CD that came with it. Do not plug the printer until the wizard told you to do so.
  • 97 Answers
Can i know the model and brand of printer?
In general, You please check your mannual for wat that blink light means and troubleshoot. If you dont have mannual, you can goto the support page of your product in their company website and download mannual or check the troubleshoot options for your problem.
  • Ganeshkumar Arumugasamy
    Hi
    please check whether you had connected to PC properly.
My xbox 360 is now showing flashing 1 red light on and off
These steps are taken from the support site as always, it's the first website where you should look.
Solution 1: Disconnect and reconnect cables
Here's how:
  1. Turn off your Xbox 360 console.
  2. Unplug all memory units, controllers, and accessories from your console.
  3. Unplug everything from the back of your console, including power and video cables.
    Don't remove the hard drive.
  1. Reconnect your console's power supply.
  2. Reconnect each accessory one at a time, starting with a controller.
  3. After you've reconnected every accessory, turn the console on.
Solution 2: Remove the hard drive
To see whether the problem involves the original Xbox 360 Hard Drive, temporarily remove the hard disk drive. Here's how.
Note Not all Xbox 360 consoles include a hard drive. If your Xbox 360 console doesn't have a hard drive, to go Solution 3.
  1. Turn off the console.
  2. Locate the hard drive on the top of the console (or on the left side, depending on how the console is oriented).
  • Press the release button on the hard drive.
  • Lift the hard drive away from the console.
hdseparating.jpg If these steps resolve the issue, reattach the hard drive to verify that the error occurs only when your Xbox 360 Hard Drive is connected.
Solution 3: Disconnect memory units or USB flash drives
Here's how:
  2. Unplug any memory units or USB flash drives attached to your console.
  3. Turn on the console.
If these steps resolve the problem, reattach the memory unit or USB flash drive to make sure the error occurs only when it's connected. If this is true, order a replacement memory unit or use another USB flash drive.
Solution 4: Request a repair
If the previous steps don't resolve the single flashing red light issue, there are no additional troubleshooting steps. Your original Xbox 360 console must be repaired at our service center. Start the repair process online.
Jan 09, 2015 | Microsoft Xbox 360 Console
Hl1440 drum indicator flashing
ok turn it off take the toner out clean all the terminals put them back in make sure everything is closed properly turn the machinie back on and let me no what happenes then
Sep 12, 2008 | Brother DR-400 Replacement Drum - 20000...
I have a Wrist Blood Pressure monitor MF 81 that I would like to set the Date and time on it - I don't have a manual
Start with the unit turned off. Now hold the Power button on until it starts to blink zero (0) on the display. Wait until the display shows two zeros. Press and hold the Memory button until a two-digit number starts flashing at the bottom; this is the year setting. Press the Power button repeatedly until the year is correct. Now press the Memory button, and the month will start flashing at the top of the display. Press the Power button repeatedly until the month is correct, then press the Memory button. The day is now flashing. Set it with the Power button, then push Memory. The hour is now flashing, set it with the Power button (note that it is in 24-hour format, so 1 p.m. displays as 13). Press the Memory button to advance to the minutes, then use the Power button to set it. Finally, press the Memory button to turn the unit off. It is now ready for use.
Sep 04, 2010 | Mark Of Fitness MF 81 Wrist Blood Pressure...
Won't turn on. On button glows green and harddrive light flashes and goes out. On button continues to glow. If I hold the on button down 5 seconds it goes out. It was working fine, I turned it off and...
*This method only applies to Aspire ONE A150 only
1) Format USB memory stick with FAT file system.
2) Download BIOS for A150
http://global-download.acer.com/GDFiles/BIOS/BIOS/BIOS_Acer_3310_A_AOA110%20&%20AOA150.zip?acerid=633850493862245097&Step1=Netbook&Step2=Aspire%20One&Step3=AOA150&OS=X01&LC=en&BC=Acer&SC=PA_7
3) Extract all files the downloaded file and place FLASHIT.EXE and BIOS file onto the memory stick
4) Rename BIOS file to ZG5IA32.FD
5) Turn netbook of, with power AND battery connected
6) Plug in memory stick with BIOS file and Flasit.exe
7) Press and hold Fn+Esc the unit will go on, hold until power LED is flashing then release keys. If it does not flash, then release and press power button once.
8) You'll notice the LED of both the usb memory stick and the power LED will flash together.
9) After a few seconds the flashing will stop and the unit will reboot or switch off completely.
^^ this is a copy paste from my own solutions
May 13, 2010 | Acer Aspire One AOA150-1570 Notebook PC
How to memory delete
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Mar 24, 2010 | Canon iP4500 Photo Printer
How do you check the memory when solid green light
svmtony --
Here are the instructions for at least printing what is in your memory, and how to delete the memory as well.
You can download the entire user manual (in PDF format) from the link below (the download is on the right-side of the page, about 1/3 of the way down the page):
Here are the instructions for retrieving the fax's from the memory:
(I found this at: http://safemanuals.com/annexe_MX310%20series%20Easy%20Setup%20Instructions_CANON_PIXMA%20MX310-_E.htm
�� Printing a List of Documents in Memory
The machine can print a list of documents stored in memory (the memory list) showing the
transaction number (TX/RX NO.), transaction mode, recipient, number of pages, date, and
transmission time of each document. When printing or deleting documents in memory, specify a
document by its transaction number.
1 Press the FAX button, then press the Menu button.
2 Press the [ or ] button to select MEMORY REFERENCE.
3 Press the OK button two times.
The memory list is printed.
�� Printing or Deleting a Document in Memory
3 Press the OK button.
Hope this helps!
-- RT
PS - If useful, don't forget to vote!
Jul 31, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon MX310 In use/memory light flashing, nothing in memory and unit not in use. Powered down and re powered still the same.
redtaildesig --
Have you tried to purge the memory? To delete the files in memory:
If you'd like to print from memory (I think you already know how,but just in case):
Hope this helps!
-- RT
Jul 30, 2009 | Canon PIXMA MX310 All-In-One Printer
HP C5180 All-in-one : Memory Card Error, No memory card in it
  1. Remove the memory card from the camera.
  2. Locate the memory card slot on the product that is compatible with your memory card. Figure 1: Memory card slot locations c01331721.jpg 1 - CompactFlash (I, II) 2 - Secure Digital, MultiMediaCard (MMC), Secure MultiMedia Card 3 - xD-Picture Card 4 - Memory Stick, Magic Gate Memory Stick, Memory Stick Duo (with user-supplied adapter), Memory Stick Pro 5 - Front universal serial bus (USB) port (PictBridge-enabled)
    NOTE: Some portable USB flash drives with a read-only partition, such as U3 smart drives, might be incompatible with the front mass storage port on your product. These partitions are added by the manufacturer and may include utilities and other software. Refer to the manufacturer for additional details about your drive.
  3. If it is not already on, turn the product on by pressing the power button (c01324469.gif ).
  4. Turn the memory card so that the label faces inward and the contacts face the product. Figure 2: Inserting the memory card c01335108.gif CAUTION: Inserting the memory card in any other way might damage the card and the product.
  5. Gently push the memory card into the memory card slot until it stops. The memory card does not insert all the way into the product; do not try to force it.
  6. When the memory card is inserted correctly, the status light next to the memory card slots flashes and then remains solid green. CAUTION: Never attempt to remove a memory card while it is being accessed. Doing so can damage files on the card. You can safely remove a card only when the status light next to the memory card slots is not blinking. Do not pull out a memory card while the light is flashing green.
Step two: Print the photo
  1. Press Photo Menu . A message displays on the control panel with the number of files found on the memory card.
  2. Press the right (c01185072.jpg ) and left (c01185108.jpg ) arrow buttons to browse through the photos on the memory card.
  3. When the photo number you want to print appears, press OK .
  4. After selecting the photos, press Photo Menu again.
  5. Press the right arrow button (c01185072.jpg ) to select Number of Copies , and then press OK .
  6. Press the right arrow button (c01185072.jpg ) to select Layout , and then press OK .
  7. Press the right arrow button (c01185072.jpg ) to select Paper Size , and then press OK .
  8. Press the right arrow button (c01185072.jpg ) to select Paper Type , and then press OK .
  9. Make any other appropriate changes to the settings, and then press Print Photos .
May 23, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Print from Memory
Check and see if your fax has a power save button next to your LCD screen. Pressing it will store everything into memory or you could do a flash memory clear however you will lose everything that is stored in memory(RX and TX only). Press FUNCTION , 9,*,8,#,7 then press start, next press your # key to scroll to flash memory. Press start. This should fix it.
Apr 23, 2008 | Sharp FO 5550 Plain Paper Laser Fax
Fisher Slim- 1800
with the unit turned off press memory once and the hour digits flash.
Press the cd ship |<< or >>| buttons to adjust the hour.
Press memory again and the minute digits flash
Press the cd ship |<< or >>| buttons to adjust the minutes
press memory once more. the display stops flashing and the clock has been set.
Sep 27, 2007 | Fisher SLIM-1500 CD Shelf System
Canon PIXMA MP780 All-In-One InkJet Printer Logo
75 people viewed this question
old marine
old marine
