Question about Panasonic KX-T7633 Corded Phone
Programming extensions The staff keep changing around and I would like to know how do I program their names and extension numbers into the switchboard without having to call in the tech.
  • 2 more comments
  • reception734 Sep 10, 2008
    Thanks for the prompt reply but sorry I don't know what is a TDA, we have a Panasonic KX-T7633 if this is right which is the programming button?
    Thanks
    I wondered our switchboard is a Panasonic KX -T7633 when a incoming call rings and I am on another call it gives a red light, how can I program it to beep in the ear or give some other noisy indication that there's another incoming call.At times I am busy with a call and my eyes are not on the screen, I don't get to see the red light flickiering furously, when it flickers like this would that be more than 1 incoming call.I also find that I can only take another call once I've replaced the receiver, sorry for all the ?s it is my first time working with this phone.
    Thanks for all the other replies they were really helpful.
  • reception734 Sep 11, 2008
    Thanks that was great information, it really did help.Many thanks.
  • caycedavid08 Nov 18, 2008
    we have a panasonic 72 key attendant console vb-44320-G and I have no manual to chng the ext names with and We have tried all day .How would I change the names on the extensions?
  • Panasonic Master
  • 2,460 Answers
By default a TDA user has access to the first 9 programs in the Basic Programming (000-009). It lets you set things like date and time, speed calls, extension name, number and PIN code, and operator extensions.
Access to the programming is from an allowed phone by PROG **1234. You may have to consult your installer/dealer to find out which phone does that, but generally it's the operator.
Carl
Posted on Sep 09, 2008
  • Carl Navarro
    Carl Navarro Sep 10, 2008
    The 7633 is a phone. The system is a TDA. The phone has a display with 4 soft keys underneath. The left key is marked PROG when the phone is idle.
    Extension 101, by default is the programming phone. All phones can program ring tones, background music and the like, and, when we install the system all phones can do system programming. At the very least, you should be able to walk up to x101 and press PROG **1234 and get into programming.
    Then dial 004 STORE 101and the display will show the current name for extension 101. (101:(name). You then can press the keypad keys up to 7 times to spell out a letter. (ie 2 will give you ABCabc2). Then press the right side of the Navigator key to advance the cursor and spell out your second letter etc.
    When you finish press ENTER to save it.
    If you don't grasp the concept of this, you should call your dealer/installer. There are a couple of user guides that explain this fully.
    Carl
  • Carl Navarro
    Try to follow this link. This is the customer operating manual for TDA systems.
    http://www.microtelcommunications.com/li...
    Call Waiting is a code for C.O. *7321 turns it on.. The appendix would be a good place to start, but the other feature I was telling you about is explained earlier in the manual.
    Carl
Change internal directory on optipoint 500
The extension name and extension number are set in the system programming. Use manager 'e' and change them in the station view. If you are swapping people around and want them to keep their extension numbers and names, you should re-patch the cables feeding to the wall sockets rather than change the programming (if you can).
Oct 20, 2014 | Siemens optiPoint 500 Standard Corded...
Hi We have a Nortel T7316E phone system. Staff
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344 (with the handset in its cradle).When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number.
Enter extension number you want to change the name on. (i.e 202)
Then press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name(Traci).
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Winston = 9 -> 4,4,4 -> 6,6 -> 7,7,7,7-> 8-> 6,6,6-> 6,6
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
Sep 05, 2013 | Panasonic KX-T7730 Corded Phone
How do I change the extention names on KX-T7730?
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system.
From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
1. Press PROGRAM * # followed by the system password ( default is 1234).
2. Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ).
3. Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change.
4. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered.
5. Press PROGRAM to exit program mode and you are done.
Mar 23, 2010 | Panasonic KX-T7730 Corded Phone
Trying to switch the extension number.
On the newer norstar systems the T7208 and lower phones can not be used for programming.The T7316e phone has to be used for programming therefore feature 983 will only work on the T7316e set.To change local dn's you have to go into config programming and to change dn old dn then new dn.
Sep 29, 2009 | NorStar T7208 Corded Phone
Names
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system. From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press PROGRAM * # followed by the system password ( default is 1234). Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ). Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered. Press PROGRAM to exit program mode and you are done.
PLEASE rate / vote this answer if it was helpful.
Thank you.
Jul 17, 2009 | Panasonic KX-T7730 Corded Phone
How do you program a Panasonic KX-T7730?
I assume that you want to program the extension names.
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system. From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the hook/cradle press PROGRAM * # followed by the system password ( default is 1234). Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ). Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered. Press PROGRAM to exit program mode and you are done.
Thank you.
May 18, 2009 | Panasonic KX-T7730 Corded Phone
The incorrect name being displayed when you use a preset number
The side buttons is programmed as extensions
To change the extension names follow these steps :
Jan 12, 2009 | Panasonic KX-T7730 Corded Phone
Panasonic Adv Hybride System KX-T7730
Thank you.
Sep 18, 2008 | Panasonic KX-T7730 Corded Phone
Changing names assigned to extension numbers
I just worked it out.
Press Program
Then **
followed by your passcode (usually 1234)
Then 004
Then press next till you find Mark
Press Shift then the button under Clr
Then enter the name so for Claire start with 2 and swing the jog button round till you get a C, then press 5 and swing the jog button round till you get an l etc..
If you make a mistake press Transfer
Then when you've got your name correct press Auto Dial.
Aug 20, 2008 | Panasonic KX-T7433B Corded Phone
For assigning a person name to the extention
Jun 18, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7633 Corded Phone Logo
559 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
