Question about IBM ThinkPad T41 Notebook
IBM ThinkPad T41 boot-up problem
On boot-up laptop emmits 2 sets of 4 beeps & does not turn on. if by chance it does go into windows system freezes after a few minutes. please help. thanks in advance
  • 53 Answers
Hello, enter BIOS (by pressing "Delete")and find there restore default. If you drop it you need check inside laptop of connections components. Check Cpu or Ram.
Posted on Sep 09, 2008
IBM Thinkpad T41 beep sound on system startup
Here are the beep codes for the Thinkpad:" Continuous beeping System board failure One beep; Unreadable, blank or flashing LCD LCD connector problem; LCD backlight inverter failure; video adapter faulty; LCD assembly faulty; System board failure; power supply failure One beep; Message "Unable to access boot source" Boot device failure; system board failure One long, two short beeps System board failure; Video adapter problem; LCD assembly failure One long, four short beeps Low battery voltage One beep every second Low battery voltage Two short beeps with error codes POST error message Two short beeps System board failure.
Dec 26, 2012 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
IBM ThinkPad
this can be solved...can you boot to safe mode, through F8?
Mar 07, 2008 | IBM ThinkPad T41 Notebook
Need to do system restore from safe mode on thinkpad t41
When you begin to boot the system Tap the F8 key. This will give you several options for booting Windows in different modes. Select Safe Mode and boot the system.
Once in safe mode begin system restore by going to Start > Programs > Accessories > System Tools > System Restore
Follow the steps in the System Restore Wizard
Oct 31, 2011 | IBM ThinkPad T41 Notebook
3 series of 4 beeps on ibm thinkpad t41
The closest diagnostic code that matches what you're saying is the 4 (continuous beeping). This is a video module failure or system board failure. The T41 does not have a separate video module which indicates system board failure.
If you can locate a T41 with a good system board on eBay for less than $50 then you could attempt a repair on the system. Otherwise the system is dead and its cost is greater than its value.
Oct 17, 2011 | IBM ThinkPad T41 Notebook
My IBM T41 make beep sound and turns off itself. What is happening?
You can try the steps below.
Try removing the battery and plugin the charger and try turning on.
Do you see any thing displayed on your screen when you switch on?
Please mention the beep pattern, 2 beeps or continuous beep.
Hope this helps. Good Luck
~SmokinJoe~
Aug 24, 2011 | IBM ThinkPad T41 Notebook
IBM thinkpad T41 -> get
The IBM Thinkpad has a very strong security system.
If you are seeing a lock symbol when booting then somebody has set the supervisor password. If you can't remember it or guess it (try "password", "admin", "pass", etc) then you need to find the person that set the supervisor password.
Once the supervisor password is set the T41 is very well protected and it can't be reset by removing the laptop battery or CMOS battery.
There is a way to read the password from the protection chip but this is very complicated and requires taking the laptop apart and building your own chip reader.
The instructions for doing this are are:
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Hope this helps,
Chris
Mar 08, 2011 | IBM ThinkPad T41 Notebook
My IBM ThinkPad T41 screen won't turn on. it only beeps 3 times. thats all it does
One long two short beep? Sounds like the common Video issue. You can try the reflow method. Look it up on yourtube or you can get the reflow guide from www.msbin.com
Jun 14, 2010 | IBM ThinkPad T41 Notebook
No wireless adapter found in XP on ThinkPad T41
Boot your laptop into windows. Go here to IBM Lenovo support and download the Cisco Wireless LAN Mini PCI adapter driver >>>>>>>
http://www-307.ibm.com/pc/support/site.wss/MIGR-42683.html
Once downloaded just execute the file as it is an .exe file, you will the wireless icon appear in the system tray (bottom right of the screen).
Regards.
Sep 15, 2009 | IBM ThinkPad T41 2373 Notebook
IBM thinkpad t42 boot up problem.
The sympton is rather vague, but I suggest the following options, to be followed one by one, until one of them works for you.
1) Boot your system in Safe Mode (if Windows is your OS) by pressing F8 after the usual "beep" provided by the BIOS after it detects all is fine. If it boots up, which takes a little longer than usual, then your system is probably Ok, although it may have a configuration problem.
Reboot the machine from the shut down menu and hopefully it will work Ok. If not, then, depending on whether you have Windows Vista (or better), try:
2) Boot again pressing the F8 key, but this time locate the option that reads something like "Last known good configuration". Highlight it with the arrow keys and press Enter.
If you have System Restore set on your drive(s) your laptop should boot up normally.
3) The last option would be for you to go into your system BIOS and run at least a HD detection test, followed by a memory test, etc., but I would only recommend doing this if you know what you're doing. If not, ask a friend for help.
Aug 17, 2009 | IBM Thinkpad T40 Thinkpad T41 Thinkpad T42...
T41 will not start
You could have a memory problem. You RAM could be faulty or just needs reseating.
Feb 19, 2009 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T41 Notebook Logo
584 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
