Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Run as not working
Run as is not working properly. The weird thing is that it is working for the most applications. Till now it is not working for some admin tools.
Somebody any idea?
Thanks in advance
Kind regards,
Henry
  • 34 Answers
Unfortunately XP Pro doesn't have a fully functional Run As command. If you try and make a request for certain system functions it will always authenticate as the current explorer user. The solution is rather odd and cumbersome. Say I was logged into Arthur but wanted to run control panel as Keech then I would follow the directions below.
1. Navigate to C:\Windows\System32\ and Run As cmd.exe as Keech 2. Open Task Manager and kill the process explorer.exe 3. In your command window type C:\Windows\System32\cmd.exe and press enter 4. Open control panel normally
5. All done!
Posted on Sep 14, 2008
My acer laptop wont let me use the acer orbicam
If you have any application that uses the webcam (such as Skype) run it. You will have access to the camera. If you have face recognition software run it. It will turn on the camera.
But more importantly look in the Start>All Program>Acer menu for a webcam application. Do read the user's manual to find out what the name of the web cam application is.
Dec 23, 2013 | Acer Aspire 5100 Notebook
I have GE dbl33eb4ww dyer that wont get clothes dry till you run them through about trhee or four times
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 19, 2010 | GE DBL333EA Electric Dryer
Not working properly
your mobile have old version are low version of java thats why heavy java apps or new java files can not run in ur fone.
plz dont forget to rate
Sep 07, 2009 | Motorola Mobility MOTOROKR EM30 Cell Phone
Lenova computer running Vista crashes most applications. Two examples: Family Tree Maker: Problem Event Name: APPCRASH Application Name: FTM.exe Application Version: 18.0.0.86 Application...
Weird category.  Seems OS- or program-specific enough.
The exception codes are supposed to give you insight into what's going on, (Intel exceptions C000 00029 and E043 4F4D in the context of Vista or your CPU in particular, say) but perhaps you should try the Vista equivalent of WinXP's RunAs options, where you can run them as older applications and dodge some incompatibilities.
Similarly, you might want to create a VM (or runtime jail; many, many options to be had there...) and try it in that context, so that if the program's spoiling things at least your system won't need to worry or crash.  The easiest thing of course is to find updates of those programs that promise to play well with Vista.
Aug 22, 2009 | Computers & Internet
I am using VISTA and the application shuts down when I try to use
Vista doesn't support all applications fully yet.. The only thing i can advice you to do is installing all the programs you want to install as Administrator.. Like so:
And if the programs still after installation doesn't work properly you can try to run them in Windows XP SP2 compability mode, like so: 4fc2f68.gif
PS: Please don't forget rate my solution
Mar 13, 2009 | Novatel Photo Explosion Deluxe 3.0 Full...
NEW COMPAQ PRESARIO CQ70 HANGS
Two things you need to do. Next time it hangs do a ctr-alt-delete and end program. This will end it properly so it does not become corrupt. Next (you can do this now) go into Control Panel and click on Administrative Tools. Click on Event Viewer and Applications. You will see a list of applications, scroll down the list and see if you can find when your notebook had an error the last time. Right click on the Notebook and click on Details. It will give you a reason it is hanging up. You can go to the Microsoft Website and type that code in and on the Knowledge Base it will tell you a fix.
Don't forget to rate this solution before you log out.
Jan 25, 2009 | HP Pavilion zd8000 Notebook
Windows home xp
Hello!!!
Goto Run command and type msconfig and disable the apllications which runs in the start up ..Those applications makes the system startup slow!!!
Oct 26, 2008 | Microsoft Windows XP Home Edition
Nokia 6630 problem
hi! may be you do not close web and just switch to oher applications. this cause the current open application to run in background which consumes bettery! make sure to close applications properly.here is the tip "press and hold menu button, it will show list of opened application on top left of the screen, goto those applications and close them"
hope it will work!
Jan 30, 2008 | Nokia 6630 Cellular Phone
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
310 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
