Question about Bose 901 VI Main / Stereo Speaker
How to connect bose 901 speakers to 5.1 setup?
Bose 901 connection to 5.1 setup?
  • mark 01 Dec 17, 2008
    How can i connect 901 to sony 1200 es receiver?If i use pre-amp output to 901 eq. i must use multi channel input on the receiver.But multi channel input is only 5.1.I want 6.1 or 7.1 sorround sound ,and that works only with HDMI,optical kabel or RCA coax.Help please!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • Anonymous Mar 16, 2009
    hahahahaha
    Brigadier General:
  • 8,546 Answers
The solution is simple and cheaper than you think.
The analog 5.1, 6.1, 7.1 outputs on your receiver should be active even with digital inputs that you want to hear. Your receiver turns everything it processes into analog output just before the speakers anyway so there's no loss of access to multichannel sound this way.
What I did was to buy a separate amp for the 901's and feed the Front L&R analog audio out to the EQ which is directly in front of the amp. The Active EQ is only for the 901's which don't have woofers or tweeters so Bose flattened out its final response electronically with some serious boosting at both ends. Having it in line with any other speakers would feed them a grossly over-compensated signal.
Your receiver will drive the rest of the speakers.
This is the cheapest way to have your 901's and hear them, too. Since the 901's are really efficient you don't have to buy a big amp that would heat the room. I'm using a separate Carver amp with 2x100w for mine.
Posted on Apr 13, 2009
Your reciever needs to have preout and main in to make your bose work.Connect the amplifier INPUT of the Bose  ®
 901
 active equalizer to the PRE AMP OUT jacks
of the receiver or amplifier. Connect right channel to right channel and left to left.
4. Connect the amplifier OUTPUT of the active equalizer to the MAIN AMP IN jacks on the
5. Plug the power cord of the 901 active equalizer into one of the switched outlets on the
receiver so that it will be powered when the receiver is switched on.
Posted on Mar 22, 2009
  • 53 Answers
Hello, if 5.1 is supported on on your speaker, you need find S/PDIF input.
Posted on Sep 09, 2008
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: Bose 901 series speakers to Bose 901 Equalizer
There is no direct connection between the 901's and their Active Equalizer. It is designed to be inserted between the source and the DEDICATED amplifier driving the speakers. Typically, this would be in a Tape Monitor loop on a receiver.
Tape Rec/Out to EQ In; EQ Out to Tape Play/In on the receiver. If you have a tape deck(s), it(they) would go into the back of the Bose EQ as if it was the receiver and you would use the Tape and 1/2 buttons for selection.
Or,if you have access to any other point that doesn't use the Tape Monitor, like a Pre Out/Main In jumper set, place the Equalizer there. That way it's always in front of the speakers and doesn't take up the Tape Mon.
Flip in the Tape Monitor and leave it on or the speakers will not receive the essential ACTIVE Equalization they require for proper frequency response. DO NOT place non-901's onto any amp using the Active EQ.
Like any speakers, the 901's will attach to the speaker terminals in the conventional manner.
Bose 901 equilizer connections to sansui G901DB
It sounds like you may have only the 901 loudspeakers, and not also the companion 901 equalizer box. You must install the 901 equalizer properly--using the tape monitor loop of the G901 receiver. If you of not, the 901 loudspeakers will perform poorly.
Jun 17, 2014 | Bose 901 VI Main / Stereo Speaker
How to connect my bose 901 to rx-v2200
Bose Equalizer Out > to RX 2200 Tape/DAT In
Bose Equalizer In > to RX 2200 Tape/DAT Rec
more instructions on page 9 Bose 901
Sep 12, 2012 | Bose 901 VI Main / Stereo Speaker
Bose 901 eq connect to mixer and amp
how to connect bose 901 speakers to mixer. help me
Mar 29, 2012 | Bose 901 VI Main / Stereo Speaker
I have a Harmon Kardon AVR 247 and I want to connect with Bose 901 VI equalizer. No other speakers are connected, just the 901's. Where do I connect the wires from the equalizer to the AVR 247...
I have this exact setup. 901s are my Mains.
The AVR247 has PreOuts on all of the channels.. No jumper to remove either. Just get a power amp or two and place the 901 EQ between the AVR247 and the Power Amplifier.
Jeff
Nov 28, 2010 | Bose 901 VI Main / Stereo Speaker
I have the following equipment and am going crazy trying to figure out how they get connected together. I also have the Carver Multi CD player and Carver Cassette Deck which I was able to connect to the...
Get a separate amp for the 901's and the rest falls into place.
1,2, 5) Place the 901 Active EQ between the pre/main front OUT of the receiver and the TFM-55X. Attach the 901's. Keep track of the jumpers you remove from the receiver. Or replace the jumpers with RCA splitter cables so you still have pre/main connection but can share the output with the TFM.
3) Pinnacle subwoofer (self-powered?) to the subwoofer out of the receiver.
4) Bose (AMS???) 5. As surrounds on the receiver. Place the sub module toward the rear so it mates sonically and directionally with them.
What? No center speaker? I'd get something more robust with bass capabilities, like a pair Bose 301 series 1's because the tweeters face in one direction only.
Except for the amps and the cube stuff that is essentially what I have. 6.1 with full-range speakers everywhere.
Aug 31, 2010 | Onkyo TX-SR803 Receiver
Proper wiring connection on bose 901 speaker with onkyo tx-sv424 purchase 5 years ago
trying to hook up sereas 2 901 to onkyo sx 424 i have access to carver c 1 if that will help
Nov 29, 2009 | Bose 901 VI Main / Stereo Speaker
Bose 901 no sound
Give a little bit more info about your rig. What amp, how connected (I assume you ARE using the Active EQ in a Tape Monitor loop or between the pre-amp and amp), Both speakers failing, just one? What works? Did it ever work?
Apr 14, 2009 | Bose 901 VI Main / Stereo Speaker
Onkyo tx sr 705 & bose 901
No. Active Equalization is required for the 901's and not to be used with any non-901 speakers.
Sep 13, 2008 | Bose 901 VI Main / Stereo Speaker
Free booklet/part #149393
http://www.bose.com/pdf/customer_service/owners/og_901.pdf
Jan 10, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901 v1 adding a amplifier
You may connect an additional amplifier to the Rec Out or Line Out from your existing receiver.
Please note the Bose 901 equalizer can be used to connect to one amplifier only.
Do let me know if you have any further questions.
Nov 28, 2007 | Bose 901 VI Main / Stereo Speaker
Bose 901 VI Main / Stereo Speaker Logo
3,036 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
