Question about Pioneer MEH-P5000 MiniDisc Player
Volume AM/FM has volume(sound),but when I play a minidisc,the head unit reads the disc ,but no volume.
  • dave moilliet Mar 05, 2006
    how do i change the setting on my simple burner?It only offers LP 2 and LP4.Ichanged the setting,Still no sound
    Novelist:
  • 196 Answers
Your MD player probably isn't LP capable. Attempting to play an LP recorded MiniDisc in a player that is only SP capable will produce no sound even though the display (time counter, track name) looks like everything is operating properly. Record the MD you were attempting to play in SP and you will get sound.
Posted on Mar 05, 2006
What does utoc error mean on a Kenwood mini disc player
Well, what it means is
TOC errors often mean the recording head/optical block is cooked. A cleaner might work, but often it's the end of the MDR.
Are you sure the battery is correctly (fully) charged? Try removing the battery and running on (only) the charger.
try cleaning the lens with a minidisc lens cleaner.
open the unit and check the laser position - it should be all the way to the left. that's where it should start to read the disk.
Read these:
https://groups.google.com/forum/#!topic/alt.audio.minidisc/63uCBegyG8A
http://www.minidisc.org/repair_q2.html
http://forums.sonyinsider.com/topic/21439-fun-with-the-sharp-702-utoc-error-fixed/
http://www.mazdas247.com/forum/showthread.php?98358-TOC-Error-on-brand-new-disc!
http://www.borus.de/minidisc/303.htm
Jul 07, 2014 | Sharp MD-MS702 Personal MiniDisc Player
Error code 13
I checked the manual and it says if you are recording the disc is dirty and cannot be read, if you are trying to play a disc the same may be true and to try and reinsert the disc.
I've only had 2 bad minidiscs out of hundreds of them, it is possible an old one has damage or dirt. It may also be the complex play and recording heads are worn out or damaged.
If you have dropped the unit the heads may be messed up. Most people don't understand MD's are read write and can be used many times. On the other head they record with a magnetic skate riding one side of the disc in the cartridge while a laser is firing at high power on the other side to record. They do not work like a CD recorder.
One will find many old MD decks with bad heads which will still play recorded discs but cannot record and save to a disc. To figure out if one is working try to record and save, after doing so eject and reinsert the MD if it is blank the recording head is shot regardless of what the unit says.
Most MD decks unless you have the upper end $1,500 ones most people have never seen are not worth the expense of repairing due to head cost and limited numbers of qualified people to do the work. In those cases it is better to just find another which works.
May 25, 2013 | Sony MDS-JE480 Mini Disc Player
I have bought a used sharp mdmt888 when i play back minidiscs the sound is distorted,ive used a head cleaner but to no avail,the discs are fine on my hifi,could the head need replacing?Thanks.
Digital is an ON/OFF system. Head cleaning will not eliminate distortion. Nor will head replacement.
Most likely you are pushing a headphone output into a line-level input. Check your owner's manual and/or menu of output functions.
I need more informatrion. What are you playing the discs through - headphone or line? What is it going into? What does "the discs are fine on my hifi" mean?
Mar 12, 2013 | Audio Players & Recorders
My disk is stuck and will not eject. TOC still works and songs will play and I would like to retrieve the disk as the content would be costly to replace. can you advise?
Your 520 was a great machine, it is older and many are worn out. It sounds like a loader problem, you can take the top off and access the loader mechanism, if you remove the inside cover you should be able to pull out the disc.
In all likelyhood the recording head is work out or damaged, so be careful with the disc. Most discs will still work if carefully removed, don't get your fingers, dust or hair in the open shutter space on the disc, it is open when inside the machine or you'll mess it up form being read on another machine.
Since you can still play it try doing an analog copy of it by hooking up the audio out to a DAT, CD or other Minidisc unit capable of recording the songs before you start tinkering with the mechanics, so you'll have a backup.
Good Luck!
Aug 23, 2011 | Sony MDS-JE520 Mini Disc Player
When I input a disc and hit play I receive an error which says "TOC ERRORa".
Possible that the disc is not reading and so the the TOC- table of content error must be referred.
It can be due to a poor head tracking or the failure of the data being read or processed.
Clean the head and use a good disc to be checked once again. If so the optical head can be faulty as it might be getting weaker.
Nov 06, 2010 | Sharp MD-MS702 Personal MiniDisc Player
Hi. I have a Sony MZ-N710 Mini-Disc Walkman which wont read discs and also does not charge. If power is connected via the charging station or directly, or via external battery adapter the spinning disc...
Possible that the optical head unit has failed in your walkman and might need a replacement. It will be adviceable to seek the cost factor of a replacement unit of Sony that might turn out expensive ... to the entire cost of the set.
So unless the optical head reads there is no data transfer or processing.
Nov 03, 2010 | Sony MZ-DH710 Personal MiniDisc Player
Won't record. Often get read error when inserting minidisc.
The head assembly has a read head and a record head (combined into one sub-assembly). Unless you're in a very dusty environment or are a heavy smoker then it's difficult to get dirty heads, it's much more likely that your unit is just suffering an age-related head failure which will progress further to affect disc playback as well. The first sign of a playback error will be the dreaded "TOC error". There is no fix: the units are long discontinued and the heads do not last forever. Spare ones are as rare as fresh **** **** and are not easy to fit. The unit has lasted far longer than it was designed to and is now on the slippery slope to total failure. While you still can, make analogue transfers of any music which you only have on minidisc and prepare to switch to a newer format in the near future. It's a real shame as the sound quality on a good MD unit still blows anything which has followed it (especially the iPlayer) out of the water.
Apr 07, 2010 | Sony MDS-E10 Mini Disc Player
Sale c13 read error
C13 read error means that the player is unable to read the TOC (Table Of Contents) on the minidisc. it has to read this first so that it knows where everything is stored on the minidisc.
TOC errors can be caused by faulty minidiscs, those which have been incorrectly finalised or by a faulty head assembly on the machine.
If possible, try to see if you get the same problem with different brands of minidisc, and also whether minidiscs recorded on other machines work on your player and whether minidiscs recorded on yours work in other players. Report back with what you find as it helps determine whether the player itself is at fault.
In reality though, it's a 9 year old unit and like all optical disc devices, minidisc heads do not last forever. If the head has failed then your only fix is to replace the player as spare parts are no longer in production and existing stocks are almost as rare as fresh dodo doo-doos.
Mar 16, 2010 | Sony MDS-JE470 Mini Disc Player
Minidisc problem
Only just seen your question whilst trawling for old unanswered questions.
My answer will be way too late for you, but may be of benefit to others searching the site.
You didn't state the make and model of MiniDisc player, but the symptoms are classic indicators of a failed playback head.
Sadly, it's irreparable. It's definitely not a DIY job, the parts will almost certainly be impossible to find, and even if you can, will cost more than obtaining a replacement model.
I'd suggest that you search or post a request on your local FreeCycle/Freegle group (first postings must always be to offer something, but you can reply to existing offers straight after joining). Failing that, you can pick a unit up very cheaply on auction and classified sales websites.
Aug 21, 2008 | Audio Players & Recorders
Sony MDX 65 6 disc changer installation
No, you have to have a Sony head unit or a Sony FM Modulator package with the uni-link connector on it.
Jan 17, 2008 | Sony MDX-65 6-Disc MiniDisc Changer
Pioneer MEH-P5000 MiniDisc Player Logo
165 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
