Question about RCA 27R410T 27" TV
RCA 27R410T When I turn on my tv the picture just goes down the center of the screen. It's kind of smashed together and elongated. Does anyone know where I can get a schematic from?
Try to go to vertical section check the capacitors and the vertical output IC....anime
Posted on May 04, 2008
    Champion:
  • 277 Answers
Hi Sounds like a dry solder joint on or near the flyback try here: http://www.eserviceinfo.com/ good luck windman
Posted on Mar 05, 2006
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
I have a 27 inches RCA TV (model:27R410T) , Firstable when i turn the tv on ,it works fine but just for about 2 minutes , after that video has gone , no video only audio ,and start changing channels...
It maybe some semiconductor IC got hot, need service or repair. It may repair itself if you leave it on standby for a month(at operating temprature a week)? This is low tempeature(the lower the temperature the longer the time) annealing or moisture curing technology, used by Nasa on transistor failure in satellites, or long range unmanned vehicles. You can always repair the unit later.
Aug 26, 2010 | RCA 27R410T 27" TV
27R410T 27" TV: our RCA Model 27R410T has maybe 20 hrs of total us...
Ok, well the good news is prize or NOT it is still covered by a warranty, that's the law, you need to contact your local RCA office, and ask them for a referral to an Authorised service center, and you will be able to make a claim, and in any event, that's where you are going to have to take it to be repaired in any event. The Consumer Act, indicates that anything sold must be of "Merchantable" quality, clearly any unit that fails after less than 24 hours use, falls into that definition. You simply have to find a Dealer, Service center, whatever, and in all fairness, they should take care of it, there may be some costs involved, but usually not. Below is a technical Service manual, this is what I use to train the engineers to repair these units, have a look, www.electro-tech-online.com/.../36401d1261034747-rca-32-television-32v434t-need-help-repairing-atc010_training_manual-1-.pdf
May 06, 2010 | RCA 27R410T 27" TV
Still can't get parental block to turn off on my RCA 27r410t. Have tried most of the steps found here on Fixya. Front panel is blocked also.
Unknown password-- ITC008 chassis with TV off press and hold volume down on the front of the tv and clear on the remote for 5 seconds
Feb 09, 2010 | RCA 27R410T 27" TV
RCA 27R410T Television colors are distorted
If you`re talking about colored spots in the screen, then you may have a degauss problem. It was frequent for those sets to have bad solder joint on the degaussing coil connector or thermistor next to it.If you`re handy with a soldering iron these connections would be near the a.c line input. good luck and don`t forget to unplug
Nov 01, 2009 | RCA 27R410T 27" TV
I Forgot my parental control code!!
to reset it just unplug it. the memory only works when there is power to it.
Jun 26, 2009 | RCA 27R410T 27" TV
TV has Sound but no picture
your tv set have a problem in the horizontal section of the board.have sound but no picture or no raster.contact your service tv technician to check your tv set.......anime'
Apr 05, 2008 | RCA 27R410T 27" TV
RCA 27r410t 27" won't turn on,just makes high pitch noise
that high pitch is comming from the flyback replace the flyback and the HOT.and you will restore back the life of your tv.good luck.
Jun 04, 2007 | RCA 27R410T 27" TV
RCA 27R410T 27" TV Logo
161 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
