Question about Acer (BCM94318MPG) Wireless Adapter
Cannot install wireless driver for aspire 4310 broadcom
Please help me..after finished driver installation..the device cannot start..why..how to get the solution for this problem..
  • 3 more comments
  • Anonymous Sep 18, 2008
    yup...i have a same problem also...any who can help me?thanks
  • Anonymous Jan 23, 2009
    the driver is missing
  • kim_adie87 Jan 28, 2009
    same..
  • Anonymous Feb 19, 2009
    "cannot install wireless driver for aspire 4310
  • epulone Feb 19, 2009
    I have formated my acer TM 4400 and installed all driver from acer website. Unfortunately the wireless lan broadcom BCM94318MPG does't work. Xp regognize it but it is saying the network it is not available. I don't know why !!!!!
    Problem Solver:
  • 8 Answers
The main problem with installing Windows XP on an Acer 4310 notebook always comes back to the wireless lan. You will oftentimes see an error code 39, and be told that the driver is corrupt or missing. The problem with the wifi card seems to be specific to the broadcom 802.11b/g adapter. This same chipset would appear to be the basis for the 802.11g. Here lies the problem: you can't use a 802.11b or 802.11g driver. When you try to do so, you get the code 39 error.
With that in mind, I'm going to put up a brief but detailed tutorial that describes how to correct the problem and get your Acer notebook up and running. This is the method I followed when working on my wife's 4310, and it works every time. Keep in mind, however, that I am going to approach this from a fresh build perspective with a slicked hard drive, with the OS being Windows XP SP3. I would recommend that you slick your hard drive and do a fresh install to avoid in conflicts. Also note that in the relevant step I'm going to throw an idea out there for all of the dual-booters out there who have a Linux distro and need to run nds-wrapper or have no connectivity at all. I'm not sure if this works because I haven't tested it. So if it does work then that's great for everyone. Just make sure you put something in the appropriate forums for others.
Now! To get your Acer 4310 Aspire Notebook up and running with Windows XP SP3 installed do the following:
  1. You will need all of the latest drivers for your Notebook dating from 12-08-2008. Go here and download them all EXCEPT for the wireless lan driver. You want an older version, preferably from the timeframe of BIOS rev V1.10, and if you've got the factory driver DVD handy you should be set. For some very wierd reason I had to use older drivers. Further, the later driver zip files for the wireless lan doesn't contain the file you're looking for. Get all of your files together and unzip them, then burn them to a DVD or several CDs.
  2. Now, you'll need to slick your hard drive. The best and safest way to do this is with a utility such as DBAN, with the second choice being Kill Disk Just grab one of these and burn the ISO image to a CD and you're set. Now, the question may arise as to why these utilities should be used. First, they're free. And second--this is the important part--these utilities will not harm your hard drive. Low Level Formatting has been known to damage the platters and landing zone on hard drives. This is, in a word, BAD. Plus, by slicking the hard drive you have no chance of encountering any problems during installation. Kill Disk takes about an hour or so to wipe the hard disk, while DBAN will take about 3 hours. I use DBAN, but Kill Disk will work just as well.
  3. Now comes the fun part. Install Windows. For those who are having a hard time with the Windows install hanging on your Aspire, slicking the hard drive with DBAN or Kill Disk will almost always prevent that. Nuff said.
  4. Now, install all of those new drivers you just downloaded. Start with the chipset, then add sound, synaptic for the touchpad, video, modem, etc. Install the lan controller (not the wireless lan) last.
  5. Now, open up device manager by right clicking on My Computer and in system properties go to the hardwar tab, and then click on device manager. You'll see that wireless card glaring at you with an exclamation point and sporting an error code of 39.
  6. Select the wireless card and right click on it, then click "Update driver..." and click next
  7. Click "No, not this time" and click next
  8. Select "Install from a specific location" (advanced) and click next
  9. Click "Don't search. I will choose the driver to install" and click next
  10. If it has not done so already, the card should identify itself as "Broadcom 802.11g Network Adaptor". If not, that's just as good because even though it has identified itself, that's not the driver you want. Click "Have Disk" and navigate to where you stashed the older wireless drivers (CD, DVD, or somwhere on your Desktop).
  11. And here's the prize: from the driver list select Broadcom 802.11 Multiband Network Adapter and install it. You should immediately see your wireless come online, and the error code should go away in the device manager. Problem is solved!
Now, two things. First, the driver I used has the following date and version number:
  • 10/12/2006
  • 4.100.15.5
If you run into problems, check the date and version.
Second, those Linux folk who are having connectivity problems with this adapter should see if there is a similar multiband driver available. That should cure the problem--again, I'm not sure because I haven't done that. But it should.
Happy surfing!
Posted on Jun 06, 2009
  • 1 more comment
  • sajjadrizvi
    sajjadrizvi Jun 11, 2012
    Thank you very much for such a nice elaboration that really helped me out of this since it took the whole bloody day of mine.. thanks again may God bless you..
  • bazinga Jun 07, 2013
    There is a simple solution:http://www.station-drivers.com/page/broa... <-- install latest drivers
  • Damian Tanner Sep 27, 2013
    Thank you, you saved my day....
    New Friend:
Http://www.station-drivers.com/page/broadcom_wlan.htm
Install latest drivers from there... choose OS
Posted on Jun 07, 2013
How do I get the acers drivers installed? I have down loaded all three wireless drivers,and none work.
Drivers for windows Vista are here: http://support.acer-euro.com/drivers/notebook/as_4720.html
Under Drivers and Utilities, Select and download these drives;
1. Wireless LAN Atheros
2. Wireless LAN Broadcom
3. Wireless LAN Intel
While installing, please start with "Intel" as you follow instruction there after. Restart your Laptop and install Broadcom, Atheros respectively.
Please ensure that VISTA SP1 is installed on your system prior to installing these drivers!
Driver incompatibilities on a system without VISTA SP1 might affect usability.
Rgds
Feb 07, 2011 | Acer Aspire 4720 Notebook
I cannot install wlan on my acer 4310 laptop.. pls help...
There are 3 driver options for Acer Aspire 4310, you may refer to the link below:
Atheros wireless
Broadcom wireless
Intel wireless
** turn off pop-up blocker to load the link properly.
Oct 30, 2009 | Acer Aspire 4315 Notebook
My acer 4310 can't instal Broadcom network adapter,please help.
i have same problem with acer 4310 broadcom network driver, and try lot of drivers. Finally i went to acer dearler/representative near my place and take the xact one. If u need it give me ur email, i sent u.
Mazhar
Sep 01, 2009 | Acer Aspire 4315 Notebook
Aspire 4310 Broadcom wireless
ok...
the drivers are not getting installed properly and i am sure that you are installing the right drivers,
what you can go is go to device manager and then right click on the drivers and go to properties,
once the properties box opens go to the tab that says drivers,click on update drivers and then go ahead and folow the wizard to update the drivers(make sure you download a fresh set of wireless drivers)..if it still gives a yellow triangle,
go ahead and right click on the wireless drivers,click on uninstall and then restart the computer and checked if it still has the yellow bang..
the link for website is
http://support.acer-euro.com/drivers/notebook/as_4310.html
once you downlaod the drivers its a zip file,download in the desktop,right click on it and then click on unzip,once the files are unzipped go to the unzipped folder and then click on install for the setup..and in this webpage go ahead and choose wireless broadcom as the option as it shows lan broadcom and wireless broadcom,u can also try installing wireless intel because it might be that you have intel card in you computer and not broadcom..
try it out..
vedhick
Feb 12, 2009 | Acer (D10709-002) (D10709002) 802.11g/b...
Net Adapter Not installed
follow this link to download your driver ---
http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=4486&formid=3394&website=AcerPanAm.com&siteid=7117&words=all&keywords=&areaid=2
download and install
if you still have problems let me know.
if it works please mark this thread as fixed :)
Dec 26, 2008 | Computers & Internet
My Acer Aspire 4310 wireless connection is not installed properly. My networks adapter under device manager was in exaclamation yellow signed. my Network adapter listed : 1394 Net Adapter Broadcom 802.11g...
There is another driver for this laptop that's a different type of wifi card.
http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=4516&formid=3394&website=AcerPanAm.com/au&siteid=8116&words=all&keywords=&areaid=12
that's one but that's for WinXP
Here's a site where all the drivers for that particular model
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com/au&siteid=8116&areaid=12&formid=3394#results
You can go down by each one until you find the correct driver or you can take off the wifi cover under the laptop and look at the wifi card and it will tell you which model it is so that you won't have to try each one till you find the correct driver.
Happy Holiday
My Wireless Broadcom Adapter is not properly running
here is the drivers and utilities page for your laptop.
just download new drivers and restart.
go to your os then drivers and utilities tab then wireless broadcom and
lan broadcom.
Problems with installation
go back and redownload your driver just to rule out a bad download.
http://www.acerpanam.com/synapse/data/7117/documents/AS4310_4710_Wireless%20Broadcom%20v.4.102.15.61.zip
download the Lan Driver as well, just incase.
http://www.acerpanam.com/synapse/data/7117/documents/AS4310_4710_LAN%20Broadcom%20v.10.9.0.0.zip
go to -
Start -> Control Panel -> System -> Hardware -> Device Manager
Click on Network Adapters to expand the list then double-click on your wireless adapter there
click on Driver and click Uninstall just to make sure its uninstalled.
go to this link to download CCleaner
http://www.filehippo.com/download_ccleaner/
Download, Install and run it
Click on the TOOLS tab on the left side. Scroll to your broadcom wireless software and click on it
Click on the Run UInstaller to uninstall the software
If you cant find the software entry, just skip this step.
Click on the REGISTRY tab on the left side
click on Scan For Issues
click on Fix Selected Issues
If it asks you to make a backup click yes and save
Click on the CLEANER button on the left side
click on Analyze
click on Run Cleaner
Now restart your computer
When you re boot go to the wireless adapter install you downloaded
and install
If this doesn't work let me know
first u install correct driver then u start ur wireless LAN ur LAN driver must be be not correct ok
first do this
then post ur result
Jul 29, 2008 | Acer (D10709-002) (D10709002) 802.11g/b...
Computers & Internet Logo
7,605 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
