I was able to create a connection over bluetooth from my PC to PDA (Tungsten E2) and am able to send pictures and memos over it, but the internet connection does not work. The following error appears when I attempt to get a website to load: The page you requested cannot be displayed. The web site you are trying to access may be temporarily unavailable or the URL u entered cannot be resolved. Please check that you correctly entered the URL or try again later. This occurs for any site, event the ones which are preprogramed into the palm. What needs to be done so that this connection will work?
You have established a bluetooth connection between your Palm and your PC, but you probably haven't configured your internet connection to be shared with the Palm. o do so, open My Network Places by right-clicking it and selecting Properties. The Bluetooth Network adapter was automatically created during the Bluetooth installation. Right click the icon and select Properties. In the General tab select the Internet Protocol components and click Properties. Write down all the information from the next dialog, and click Cancel. Back in the Adapter properties, select the "Sharing" tab and check "Enable Internet Connection Sharing for this connection". Now, to configure the Bluetooth USB, right-click the Bluetooth icon in the system tray and select Advanced Configuration. Change to the Local Services tab and double click "Network Access". Change the type of service to "Allow other devices to acces the Internet/LAN via this computer". The alternative to this option will allow your device to connect to your computer as part of a LAN, but will not have internet access. Note the Configure Connection Sharing button: it'll open the configuration screens we've visited before. But some Bluetooth software will not have this button, hence I guided you through the other route . On your Palm device, a new Connection configuration is needed. From the Palm Launcher open the Prefs application, and switch to Connection. You'll see a list of connections and will tap the New... button. You can assign any meaningful name to this connection. Select the values as indicated in this image. Tap the device name to choose what computer will be used for this connection. Make sure your computer is in discoverable mode. If you tap the Details button you'll see the next screen. Now create a new Network access configuration, using the connection created in the previous steps. Tap Network to go to the next screen. Tap the New... button and enter a name for your Network access configuration. You shouldn't need a username and password. Tap the Connect button and you should see your LAN connection initiating. To make sure the connection is working, still in the Connect dialog, tap the menu Preferences and select Options. Choose View Log and the screen you see will show the negotiation between the Palm and the DHCP server on the network. To check your DNS is working, scroll to the bottom of this log, and enter PING and a hostname. Use the Return stroke as an Enter and If your connection does not complete, or if your Palm shows a Timeout error, try adding a script to this connection. This is common with Palm OS 4. Newer versions of Palm OS should not need any script to work. From the Network dialog, tap the Details button. On the next dialog tap the Script button. On this script dialog enter the following: SEND CR DELAY 1 SEND CLIENT WAITFOR CLIENTSERVER END Hope this works!
