Question about Toshiba Satellite A105 Notebook
Monitor is blank!!!!
Ok this is an odd..yet weird problem. I'll make this short. Bought laptop. Awhile later..laptop monitor goes blank. SO..i think its broken..i hook in external one. external works fine. I also went into bios and made sure everything was factory set. Oh yes...the laptop monitor is on..but its still black..like a unhooked monitor that is on..but not connected to a computer. So that brightened up something. I went into bios and changed the setting to LCD+RGB. And it semi works now. Laptop monitor shows in bios...and when xp loads. but when im actually in XP it goes blank again ARGH! NOW LISTEN TO THIS! i just installed linux as another OS. And when i'm in linux...everything works PERFECTLY. Laptop monitor shows and everything! But in XP....windows XP that is...it acts like an idiot and stays blank on me..i updated graphics drivers and everything..even formatted and stuff! i dont know what to do...any help? please?!
  • John Coffey
    John Coffey Sep 09, 2008
    Monitor works for 30 seconds, gets shaky and unstable, displays vertical and horizontal lines in color, then goes dark gray and quits. I plug in a Dell lcd ft04 externally, it works perfectly. Have factory loaded windows xp home edition sp2, most updates.
I had the same problem with my Toshiba laptop. I found that by opening or closing the screen slightly (with the computer on), the display suddenly returned and stayed on. I assume there is a problem with the contacts or connection.
Posted on Feb 11, 2009
    Novelist:
  • 210 Answers
Firstly, the LCD+external setting will switch one or the other or both on.
Secondly, if you go into your display properties (or even the advanced page where your video card additional features are) you can usually select which monitor is "primary".
I suspect that your external display is primary, and the LCD screen is not "enabled" or used as part of the desktop.
The settings are all there, it's just a matter of finding them (depending on what video card is in whatever laptop you have)
This might have happened in the first place if you accidentally hit "Fn" and one of the "F" keys up the top. Fn + F6 on my laptop will switch LCD/external monitors on and off. (for example) There is usually a little blue picture on one of the "F" keys to denote that function.
Posted on Sep 09, 2008
  • Steve Rand
    Steve Rand Feb 05, 2009
    Oh! Well if that is happening, your screen is pretty much dead. The capacitors that control the panel are probably swolen.
    If you're lucky, you might be able to buy a cheap replacement screen from an auction site and swap it in... otherwise it's just not worth it.
Occasional odd coloring and backlight flickering
Please check it monitor color adjust button. If ok then you check it monitor cable if change possible then change it or power cable also proper connect. If not solved contact Good Monitor technician.
Thanks.
Feb 17, 2014 | Apple Cinema Display 23" HD Monitor
Weird Display Problem
aperently when you tilt the unit.. the base mount which is bolted to the frame is causing a short inside the monitor..some electrical part is connecting with something else inside..I have a flatscreen tv that does the same thing. you may also find a monitor at most resale shops like goodwill...
Feb 02, 2014 | Dell Computers & Internet
My monitor screen is ok for awhile but suddenly turns a dull yellow color. I just bought it a few months ago.
you must adjust the display settings in the software program that was being used to change the display setting.
  • If you have a flat panel LCD monitor, unplug the monitor power cable, wait about 30 seconds, reconnect the cable and then turn on the monitor. This resets the electronics on the monitor.
  • Make sure the monitor has power - the light on the monitor is on. If the light on the monitor is off, the monitor does not have power. Connect it to a different power outlet.
  • If the monitor has a detachable video cable, obtain a second monitor cable for testing purposes in case the cable is bad.
  • follw the another steps-
  • Replace the monitor power cable.
    1. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    2. Replace the video cable. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    3. If the monitor does not work after replacing the cables, replace or service the monitor
  • Thanks,
    Nov 18, 2009 | Compaq Presario 5000 PC Desktop
    Monitor goes blank but is still connected
    Do bios update on Computer.Select the product number and search on Website for bios and than try the monitor
    Oct 13, 2009 | Computers & Internet
    I bought a Lenovo S10e last week, for my mum, the monitor was to small for her, so today I bought a Benq g2220hd monitor, problem is that I dont get a signal on the Benq monitor, I did get the windows logo...
    first i would check the compatibility of the monitor to the laptop and see what they say, and if it should work odds are the monitor will have to be set manually through the laptop itself or on the menu of the monitor itself, may take a while playing cat and mouse but im sure you will get it, more then likley from what im understanding its a resolution issue between the monitor and the laptop, especially if you got the windows logo on the boot
    enjoy
    Jul 06, 2009 | BenQ Computers & Internet
    Put an adaptor on my cable and the monitor screen goes blank
    Hi Kathy,
    Nothing you can do, it could be the laptop does not understand Digital Video Interface DVI
    What is the laptop make / model?
    Mar 13, 2009 | ViewSonic VA1912wb 19" LCD Monitor
    Monitor goes blank. I turn if off and then it comes on for awhile, then goes blank again.
    Try swapping with a good known working monitor. Then check your memory.
    Aug 09, 2008 | Gateway Computers & Internet
    Laptop Screen dark yet computer works with external monitor
    does the fan work ok? and do you have a laptop holder for it or you just have it on a desk ....get a laptop holder for it if you do not have one and as for the rest goto the power mangment area on the computer and see if the monitor might be on stand by after a few min ...
    Jul 14, 2008 | Compaq Presario R3000 Notebook
    Toshiba Satellite A105 Notebook Logo
    250 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
