Question about Motorola Mobility E815
Dial-up Networking How do I enable dial-up networking on my Verizon Motorola E815 cell phone?
##DIALUP (##342587)
Posted on Nov 08, 2006
I have a Motorola E815 Alltel cell phone and was wondering if I could somehow make this phone compatible with Verizon since they are my current carrier? How do I switch this Alltel E815 to Verizon?
Hi Dawn Lynn Martens,
You can take the device to Verizon to see if they can activate it with their frequency. Since they handle CDMA devices as the Motorola E815.
Best Regards,
Katya
Motorola Support
Aug 16, 2015 | Motorola Mobility e815 for Verizon /...
What does outgoing call are restricted by fdn mean
FDN(Fixed Dial Number) if enabled, allows you to restrict your outgoing calls to the limited set of phone numbers that are included in the Fixed Dialing Number list.
Jun 10, 2014 | Motorola Mobility Verizon Wireless Droid...
Outgoing calls are restricted by fdn
This means that Fixed Dialing is enabled to certain numbers. You'll have to disable this function in order to call other numbers.
Mark
Motorola Support
Forgot my password for my xv6700
) start phm regedit (google it to find a download location) go to HKEY LOCAL MACHINE>SERVICES>WirelessMGR
2) Edit the key called mutexflag change the value from 1 to 0
3) accept the changes close the program set you phone down and WAIT 15 minutes.
4) reset phone by pushing the reset button on the bottom
Put the phone in Field Test Mode:
From the phone dialpad call ##33284 and then hit send this will turn on the field test program.
Enable Dial up networking over Bluetooth:
Dial ##3328873 and hit send, then check the enable bt dun enable option and reset your phone, you should now be able to configure your PC or laptop to use BT DUN.
Feb 27, 2012 | HTC Verizon XV6700 Cellular Phone
E815 motorola phone
do a mater reset of your phone
initial setup menu-master reset
code is 000000
Aug 18, 2008 | Motorola Mobility E815
How do i take it apart?
you have to pry out the rear bottom cover with a plastic tool. that will reveal twu other screws to complete the dissasembly
Aug 11, 2008 | Motorola Mobility E815
Motorola E815 - Battery Charger
I had the same problem but for some reason was able to use one of those Energizer battery chargers but no others!! I took it to Verizon and they cleaned the pins. Try using a toothbrush to clean it. That worked for awile then stopped. I took it to them againa and since it was still under warranty, they gave me a new one!
Aug 21, 2007 | Motorola Mobility E815
Voice Dialing Issues
I am sad to say that the voice recognition failure is permanent on most of the E815 phones. Your phone will likely never support voice dialing again, even though the cause remains unknown.
I too had the peculiar problem of pressing the voice button and hearing a beep, but no voice prompt ("Say a command"). When I researched the issue, I found a plethera of similar problem reports. Very few reported recovery after simply restarting the phone. I even found one report of Motorola tech support giving up and instructing the owner of the phone to have it replaced.
Feb 14, 2007 | Motorola Mobility E815
Motorola Mobility E815 Logo
44 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
