Question about Dell E172FP 17" LCD Flat Panel Monitor
Monitor not opening up page
My Samsung Syncmaster does not open the page when I click on a link. It goes in a long bar across the top of my monitor. The more links I try to open, the more they just layer on top of each other in a long bar across the top of my monitor. I can open them by clicking on the square box right next to the X at the top right of the screen. I was told by another fixya person that I should drag the little box to open the page and next time it would open but I did as told and it does not work. Thank you
    Champion:
  • 220 Answers
This is definitely not a Hardware problem.
Samir
Posted on Sep 30, 2008
My monitor keeps flashing black whenever a page loads. This was after I updated some drivers on Windows 7.0
Click on Start Button
Click on Control panel
Open Programs and Features
Click on View Installed Updates ( from left panel )
From the list check for the update done by date ( since when the issues started )
Click on the update and click Uninstall from top bar.
Restart your PC and it should work fine.
Regards,
Shawn.
Feb 04, 2011 | Samsung SyncMaster 2493HM Monitor
How can i disassemble this monitor
For a copy of the user manual you can go to:
http://online.manualspace.com/computer-monitors-free-ebooks/samsung-monitor-service-manual/4207/samsung-syncmaster-793mb-793df-crt-monitor-service-manual-91.html
Scroll down this page and you will see a red link entitled "Download Samsung SyncMaster 793MB 793DF CRT Monitor Service Manual".
Right click on this link and select the menu option "Save Link As".
Save the file to your computer then you can simply use Winrar to extract the file.
Would you kindly rate my answer please if this has helped resolve the problem - thanks :)
Oct 20, 2010 | Samsung SyncMaster 793DF 17" CRT Monitor
SyncMaster 216BW Monitor: it works for 1 hour suddenly the image goes and af...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Samsung monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 16, 2010 | Samsung SyncMaster 216BW Monitor
My monitor syncmaster 920nw hissing when is power on and diod not shine
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG and other monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 30, 2010 | Samsung SyncMaster 920NW Monitor
The monitor powers up and the analog icon blinks on and off and nothing else happens...no colors...when connected to computer.. the images show for a few seconds and goes blank...turn monitor off and on...
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Mar 29, 2010 | Samsung SyncMaster 204BW LCD Monitor
How to open the back cover of Samsung SyncMaster 794mg CRT .
"Don't kill yourself just to save some bucks"
Here are the instructions:
http://www.josepino.com/?open-samsung-back-cover
Apr 24, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Monitor
Do you have friend that has a laptop? If yes, you can have your monitor hooked up to external VGA connector. Your problem may or may not disapear. If it does it is likely that the graphic chip is to blame. You may find a inexpensive graphic card (plenty available) that will work.
Sep 09, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
The topic i click on doesn't open up on the monitor, it goes across the top of the screen in a long bar. The more links I open, they just layer up on top of each other across the top of the screen in the...
Do this. With one of the windows open instead of using the square box to enlarge the window, use the mouse cursor to drag the corner of the window out to the size you want. Then close the window by hold down the Control key while clinking on the X next to the square box. The next time you open this type of window it should be the size you want.
Sep 02, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Opening monitor
It's easy to open, just insert a flat screwdriver in each top slot and push it until it "clicks".
Complete instructions and photos at:
http://josepino.com/?open-samsung-back-cover
Good luck.
Jan 16, 2008 | Samsung SyncMaster 550S Monitor
Stripes on my Samsung Monitor
The contrast may be to high.
Adjust the brightness and contrast to make it go away but still readable.
if that does not help the FL (backlight) is going and the unit will need to be replaced.
Sorry.
Jan 02, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Dell E172FP 17" LCD Flat Panel Monitor Logo
51 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
