Question about Panasonic Videoprojector PT-LM1E Multimedia Projector
Screen adjustment i have a projector i cannot fix the adjustment on the screen it was move to the left i cannot see the whole view on my slides
  • 22 Answers
Adjust the screen area of the computer’s display settings to match the projector’s native resolution. Refer to your projector documentation for the optimum or native-resolution setting for your projector model. If you can't find this information or are uncertain, most projectors support a maximum of 800 x 600 pixels.
• With certain laptops, you might need to disable the laptop display to obtain the best image, especially when the native resolution of the laptop exceeds the native resolution of the projector.
• Font smoothing will automatically generate a cleaner font outline, both on your laptop and on the projector. To apply font smoothing, do the following:
1.
In Control Panel, open Display.
2.
On the Appearance tab, click the Effects button.
3.
In the Effects dialog box, select the Use the following method to smooth edges of screen fonts check box, and then select Standard or ClearType in the list.
If the projected image is dimmer than it was on the laptop, check your projector documentation for information regarding lamp timers. If the lamp life has expired, replace the lamp for maximum brightness.
If the projected image is not rectangular, try one or both of the following:
• Make sure that the projector is perpendicular to the viewing screen.
• Raise or lower the projector.
If the projected image displays vertical lines, "bleeding," or spots, try one or more of the following:
• Adjust the brightness of the image.
• Check the projector lens to see whether it needs cleaning.
• Adjust the sync and tracking on the projector.
Posted on Jan 09, 2009
How do I adjust view from an angle?
Best to have the projector 90 degrees up and down and left to right to the screen. Try turning the projector to move the image left or right.
Aug 30, 2014 | Office Equipment & Supplies
Kodak carousel 760h projector
Yes, there is a fix. It's a pretty straight-forward adjustment. You can go to this web page: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-locale=en_US&pq-path=6499
The Service Manual there will detail the the adjustment.
Good Luck !! Jim
Mar 11, 2014 | Office Equipment & Supplies
Kodak 650H projector - will cycle when the button is pushed to advance, but doesn't stop when the shutter is open. Rather it seems to keep moving until the shutter is in the closed position. The slides...
Sounds like a timing problem to me.... There is an adjustment you can make, but it's a "trial & error" fix: you have to make an adjustment one way or the other in the camstack, and then see if it's worse or better (relative to a correct slide cycle). This adjustment is made with the projector upside-down with the bottom cover removed. Check out the attached picture for more detail on where & how to make the adjustment.
Feb 09, 2014 | Kodak Office Equipment & Supplies
Can't get slide projector to focus with lens in projector
Check the lenses inside the lens tube and see if they are loose or out of place
Feb 05, 2014 | Kodak 4200 Slide Projector
When the projector was turned on it started to cycle as when ejecting slides then it stopped and seems to be jammed...the rectangle black screen that opens and closes during the cycle to view slides is...
First of all, remove the tray (use the emergency tray removal in the center hub of the projector). BE CAREFUL not to spill your slides, so before you remove the tray, make sure the tray ring is in position & tight, then when you remove the tray turn it upside down immediately and move the tray plate to the "zero" position. Remove any slides that might be in the gate of the projector. Turn the projector on and cycle the projector 2 or 3 times in Reverse. This should clear a tray/slide jam. Good Luck !!
Jan 24, 2011 | Kodak ABR Ektagraphic 35mm 140 Slides...
Carousel projector slide not working right. Can only see half of the picture on the screen.
I had a similar problem and was able to get the full view by giving the change button a quick touch for a partial activation. It seems as though the cycle does not complete before the motor is turned off at what should be the end of the cycle. I took it apart to find the problem but did not discover the correction. So the little "flick" on the change button finished moving the slide into position and the "blocker panel"(inside the projector)) out of the way so the whole slide could be seen.
Jan 13, 2011 | Vivitar V5000AF Slide Projector
The autofocus will not focus. The paper is blurry. How can I fix it?
Remove the orange plastic parts near the camera.
There is a square opening/hole.
Get a long small screwdriver and adjust the screw connected to the lens.
I did this with it on, so I could see if it was making a difference. I am not 100% sure if adjusting the screw was the fix. However, moving stuff around in that area seemed to make a huge difference.
Sep 08, 2010 | Elmo Projectors EV-200 Slide Projector
My Kodak 760H will not stop once you switch the unit on. It just cycles through the whole carousel and will not pause long enough for you to view the slides. The remote will let you reverse it but it still...
The KODAK Carousel Slide Projector was manufactured from 1971 to 1981 (approximately).
The contact on the slide change mechanism is worn through. If you are lucky, a factory-trained repair dealer may be able to adjust it slightly so that it lasts a few more years.
Mar 23, 2010 | Kodak Office Equipment & Supplies
I have a TRV-35G and the colour is predominately green which I cannot correct across the whole screen with the joystick control. Where the colours of the picture have been corrected (across 2/3 of the...
Try turning colour correction OFF. (button in up position). See what affect the iris control has. This control will changed the color of the slide from deep red at nearly closed to washed-out blue and white. at full open. I adjust the controls for each slide. The color temperature of the 8549 lamp varies with the brightness. lower level warmer, higher cooler.
Dec 02, 2009 | Elmo Projectors TRV-35H Slide Projector
The "arm" that ejects the slides has jamed on my Kodak projector.
the grease on the moving parts of the mechanism gets sticky with age. when the motor and cam stick, the select and index levers (which the cam moves) will stick. you'll need to remove the top and the whole mechanism and clean it out with wd40, dry it and regrease it. just remember what you removed so as to reinstall it properly.
Aug 09, 2009 | Kodak Office Equipment & Supplies
Panasonic Videoprojector PT-LM1E Multimedia Projector Logo
198 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
