Question about Toshiba e-STUDIO3511 All-In-One Printer
Private Print Only
Hi
We are using Toshiba 3511. We want to disable the Normal-Print (Direct Print) option. All our users should choose the Private-Print option only. How to do that ? Please advice.
Thanks & Regards
Justin Jerald
5 Suggested Answers
SOURCE: Print driver for Toshiba E-Studio 3511 Copier/Printer for Window
You can go to http://copiers.toshiba.com and download it.
Posted on Feb 04, 2009
  • 71 Answers
SOURCE: Disable Printer Spool Option?
To manually stop and restart the spooler service perform the following steps:
1. Click Start, click Run, type command, and then click OK.
2. Type net stop spooler, and then press the <Enter> key.
3. Type sc config spooler depend= RPCSS start= Auto, then and press
the <Enter> key.
NOTE: The spaces between = and RPCSS and = and Auto are important.
Without these spaces, the command will fail.
4. Type net start spooler, and then press the <Enter> key.
Posted on Jun 16, 2009
  • 653 Answers
SOURCE: Copier Disable
U can impose dept code~~~
Posted on Feb 13, 2010
wheatlandsvc
  • 1110 Answers
SOURCE: Hi, My Toshiba E-Studio 3511
I am assuming you have emptied the old waste toner "box" and not replaced it with a new box. This is not a problem, just clarifying. If this is the case then you have toner packed into the sensor block which is telling the machine that the waste toner box is still full. Just look behind the waste toner box and look for a little set of wires. They lead to a small black sensor. Now look at the waste toner box where it mates up with the sensor. You will see a small square box area on the waste toner bottle. The sensor looks thru this block and if it is blocked with toner it will tell the machine the box is full. Just tap on the little block and make sure there is no toner in it and re-install the waste toner box and the indicator should go away.
Good Luck and Thank You for using Fixya.
Posted on Aug 11, 2010
Toshiba 3511 color print problems
Hope it's not the calibration. This could happen due to transfer belt timing problem. There are sensors and reflectors inside the transfer belt assembly. They may be dirty. Clean them or replace the transfer belt if required.
Oct 03, 2012 | Toshiba E-Studio 3511 Color Copier
I am trying to print from my HP laptop to a Toshiba E-Studio 3511 Copier. Windows 7, 64-bit system. I downloaded the Universal driver from the Toshiba site. That did not work.
try this
http://copiers.toshiba.com/downloads/KB/file_uploads/6029/es4511-v122130-w2kxpvis-pcl6.zip
if u using usb port try the network cable by using ip
Jun 12, 2011 | Toshiba E-Studio 3511 Color Copier
Toshiba-Service _manual_ 1550SH.PDF not found
Hi ahmedarefaie,
Here's the link where you can download the file you are requesting:
CLICK-> http://www.eserviceinfo.com/downloadsm/33830/Toshiba_BD-1550.html
File information: File name: 1550SH.PDF Size: 714 kB Extension: pdf MD5 Checksum: 702d4a1ea9bbc02157fa2e5918adfa6a Mfg: Toshiba Model: BD-1550 Original no''Chassis''Ordercode: Description: Toshiba BD-1550 Service HandBook Group: Electronics > Office equipment > Copiers > Uploaded: 2007-12-07 22:13:33 User: baster1 Multipart: No multipart
Once you are on the website I had provided just direct yourself to download link as indicated on the picture attached.
Thank you for choosing Fixya!
Feb 18, 2011 | Toshiba Computers & Internet
How do i print an envelope from the bypass - it is not giving me the choice of an envelope in printer properties page size
Unfortunately, bad choice, e-studio 3511c is not capable to print on envelopes, that is why you can't find option in printer driver.
Jan 25, 2011 | Toshiba E-Studio 3511 Color Copier
Toshiba 3511/4511 suddenly stopped faxing
Try use the monitor button for faxing, check whether there is tone or not.
Jul 08, 2010 | Toshiba E-Studio 3511 Color Copier
How do i set up a folder on our Toshiba so i can send print jobs to that file and print them at a later date
you dont need to,try using the private print function within the print driver-but dont forget your passcode that you will have to give the print job. the job will go into the invalid print queue on the copier from where you can release it.
Sep 15, 2009 | Toshiba E-studio 281c Copier
How do i reset admin password on toshiba eStudio 3511. I bought it used through 3rd party and they don't know the old one.
If you download the iso for trinity rescue disc here
http://trinityhome.org/Home/index.php?wpid=5&front_id=12
burn that to a cd and boot your laptop up with that you should be able to reset the password with that - short of that use a bart pe disc ( google this ) to recover your data and then re install the operating system
Apr 27, 2009 | Toshiba E-Studio 3511 Color Copier
Fax option gd1200
the GD1200 can be used in the e352 / e280 / e230 / e350
Apr 03, 2009 | Toshiba E-Studio 3511 Color Copier
Toshiba e-STUDIO3511 All-In-One Printer Logo
204 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
