RCA RP3721 Clock Radio
Problem for RCA RP3721 Clock Radio
RCA alarm clock - RP3721 - crystal or AC for time?
By 123456 on Mar 03, 2006
What does this alarm clock use to keep time? Is it primarily a waveshaping circuit off of the 60hz AC that clocks digital circuit - or - does it run always off of a crystal time keeping circuit?
I assume for battery backup, it has a crystal time keeping circuit. If it does use 60hz AC, how does it switch when power may be detected as low?
The problem is that every once and a while the clock gains time, but no AC has been lost (as far as observed).
Thanks.
Larry Park
Same Problem
Jan 14, 2008
-   my clock has run steadily for years, but suddenly started gaining 10 minutes a day. Could a dead battery cause this?-   chrisalberts
Best Solution
posted on Mar 24, 2006
Very Helpful)
techman
Rank: Guru  RCA Expert
Rating: 86%, 7654 votes
They used to use crystals to help the timer ics to keep time but since the development of Micropros. all this is built in to one chip. Now they will use a resonator or a small crystal for the timing clock of the micro but nowdays the manufacture uses that clock to keep all in check. If your gaining time you probably are having problems with your ac duty cycle as this also keeps clocks in check.. This would not affect most devices but could be a problem. But of course a defective Micro could also cause this gain in time And probably is?? Now a battery backup is nothing more then a battery in line with the Microproccesors B+ terminal through of course a diode as well as a voltage limiter resistor to take over the B+ when the units ac supply is absent..
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for RCA RP3721 Clock Radio
Questions and Unsolved Problems for RCA RP3721 Clock Radio
Do you recommend RCA RP3721 Clock Radio?
Answer
Answer
CD cover will not close; the clasp on inside is not catching the pin on inside cover. Model #... (More)
Answer
GPX clock radio / docking station for iPod - the blue time display is too bright. Even the dimmest... (More)
Answer
Since moving to another part of the office building, I lose most stations and those that play have... (More)
Answer
how the heck can I set the wake up to be on a radio station and not just hear static?
Answer
I cannot seem to turn off the NAP light and the alarm keeps going off. I have the RP3721A clock... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Clock Radio Experts
Top Audio & Video Equipment Repairmen
in , NY
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
