Question about Bosch 24 in. SHU53 Built-in Dishwasher
BOSCH Model: SHU5312UC/U12
How do I get to the control pannel?
  • Zoltanar Apr 30, 2012
    Hi Mark. You suggested you might be able to send through email a PDF of the repair guide of the dishwasher. I have a Bosch SHU5312UC/12 which I have a couple troubles with.
    1. I am stuck with the 1 minute countdown
    2. The Rince button is stuck and I haven't figured out (don't want to force the plastic thing) how to carefully remove the front panel
    3. The small window in front of hte count-down timer is loose. I need again to remove the top front panel to glue it back.
    If you could please send me (if you have it) the repair manual would be just awesome! My email address is "com dot gmail at okovacs" (do proper replacement, et reverse the order)
    Thanks a million for your help!!!
    BTW, In my first attempt to remove the door front panel, I had one of these black plastinc thing fall off. I was lucky enough that the other one stayed in place, or I guess I would have looked a long time to figure out where it goes! :)
SOURCE: Replacing Control Module
Sergio,
Did you get your problem resolved. By now I think you have found the two screws on the sides of the inter part of the door. Did replacing the module fix your problem. I have the same problem.
Mike
Posted on Jul 06, 2008
  • 44 Answers
SOURCE: my bosch dishwasher model shu5306 uc/u12 counts
Your d/w has a faulty control board... only solution is to replace it.
Posted on Mar 21, 2010
Macmarkus
  • 2605 Answers
SOURCE: I need to look at bosch SHU5312UC exploded viewe of the door
I think I know the pieces you are referring to and you can only install them one way. I can direct you to searspartsdirect.com and if you enter your model number you should have access to several breakdown illustrations of your d/w however, I`m here to tell you, don`t sweat it. Most illustration`s I`ve seen don`t even show them either.
Those two blocks ( which slide into the front of the hinge behind the door panel by the way ) can remain left out without any functional consequence to your dishwasher. In fact the regional training representative for north america used to joke with us techs how he had a collection of them from tossing them into his toolbox instead of putting them back in place. They do increase the structural support of the front panel, but unless you plan on moving it around frequently, I wouldn`t worry about it.
If you are still concerned, post back with your email and I can send you a complete repair guide in "pdf" format for your dishwasher.
Hope this was helpful to you. Thank you for coming to "fixya" and please let me know if I/we can assist you further in this matter. Please take a moment and rate the info I provided for you here today.
Good luck.
macmarkus :)
Posted on Mar 30, 2010
  • 88 Answers
SOURCE: My Bosch diswasher SHU5312UC runs down to one min
hi,theres a overflow swich it the pan under the dishwasher...it might be sticking or your control board behind the disply for 1 min..is bad...call i will fun you through it...
Posted on May 12, 2010
  • 561 Answers
SOURCE: Bosch Model shu9925uc/u12 not draining throughout
ensure filter in bottom of machine is not blocked. if clear
suspect blocked pipe or defective evacuation pump.
i hope this was helpful
Posted on Dec 12, 2010
How do I fix the heater in my Bosch shu5306uc / u12?
SHU5306UC-12 BOSCH DISHWASHER Manual - Sears ...
www.searspartsdirect.com > Kitchen Appliance Parts > Bosch Parts
Download Manual for Model SHU5306UC-12 BOSCH DISHWASHER.Sears PartsDirect has parts, manuals & part diagrams for all types of repair projects.
Aug 01, 2015 | Bosch Dishwashers
How do I run a diagnostic test on the Bosch shu5315uc/u12? The cycle time of my dishwasher is at least 4-5 hours.
Long running time on a Bosch dishwasher is almost always a blown solder joint at the heater relay on the control board. You can resolder the joint, replace the relay or replace the control. Control board part number is 00266746.
Jan 13, 2015 | Bosch Dishwashers
I have a Bosch SHU4322uc/u12 dishwasher remove wires from control module, should have taken picture, but did not,need to know where to plug wire into control module thx
Look at the notches in the control and on the wire connections. They are all different and only fit in their own spot.
Dec 30, 2012 | Bosch Dishwashers
My Bosch diswasher SHU5312UC runs down to one min and won't pump the water in or out.
May 12, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
Good luck.
macmarkus :)
Mar 30, 2010 | Bosch 23 in. SHU33A Built-In Dishwasher
My bosch dishwasher model shu5306 uc/u12 counts down to one minute left then just keeps running
Mar 21, 2010 | Bosch Dishwashers
My Bosch Dishwasher cycle runs for 2 plus hours!
If this unit is running for a long time it is because it is still try to heat the water temp up it is eather the control board or the heater.
Mar 28, 2009 | Bosch Dishwashers
Sergio,
Mike
Jun 28, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch 24 in. SHU53 Built-in Dishwasher Logo
154 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
