How do i change the amount of ink used for printing documents?
    Problem Solver:
  • 9 Answers
To change the amount of ink used by printers. You can check the preferences of the printer before hitting again on the print button.
When you click on file then print, there will be a window that will appear asking you what type of printer to use. On the right side part of the printers name you will see an option to open the preferences of the printer. Normally it will say properties or preferences.
Under the printer option, there will be another settings that you can see for "Quality". That is the one that controls the amount of inks used by your printer. Draft, uses less amount of ink (quality is poor) Normal, normal ink used by your printer. Photos and Best photo produces more inks. Of course for photo use to produce good quality of pictures.
This is the only way to control it. Drivers for printer are the one who controls the amount of ink used by your printer. Unfortunately looking on the hardware side, there nothing else that you could do to control it.
Posted on Sep 09, 2008
    Scholar:
  • 152 Answers
You can save ink by highlighting all your text, go to Fonts menu and select your font color to 50% gray. This will definitely help save on the ink output, even better than just using draft mode.
Trying to print documents, white background with black typed words. Problem I have is the printed documents have solid dark blue and solid black ink and the words don't show.
Are the ink cartridges installed in the correct colour order?
Have you printed a test page through the printer's own control panel? What was the result?
Open a new document, using the default settings. Key in some test text. Try printing. What is printed?
Jan 06, 2015 | HP Office Equipment & Supplies
Do I have to have a color cartridge in order to print? Can I just use a black ink cartridge?
The HP DeskJet 6122 can print with both or only one ink cartridge installed. The printer driver includes an option to print in gray scale as a substitution for color. If you choose to print a document that has a color other than black and white with only a black cartridge installed, I recommend you select the gray scale print option. To select gray scale, select the printer properties and check the box for gray scale rather than color printing. This selection can be made either at the time a document is ready to print (ie., a one time selection, using the "Properties" box in the print options window), OR as a permenant setting using the Control Panel, Printers, HP DeskJet 6122, "Properties" window. Once changed in the general printer properties, these settings remain active anytime the HP DeskJet 6122 printer is selected to print a document.
Sep 03, 2013 | HP DeskJet 6122 InkJet Printer
I have a new black ink cartridge but my printer wont print because the color ink is empty is there a way to get it to print without refilling the colored ink since i only need black???
When printing in BLACK, a small amount of the COLOUR ink also is used.
This "trick" prevents the COLOUR ink-jets from clogging, due to not being used.
So, you need to have a "good" COLOUR ink-cartridge.
Mar 18, 2011 | Epson Stylus Multifunction Inkjet Printer/...
My printer will not print in black. It will use the other colors, but not black. When I try to print a black and white document, it prints in blue.
if u want to print selected document in black than open the document select print go to printer properties select grayscale printing
always print in black
go to printer properties than go to maintenance than go to ink cartridge setting select ink cartridge black only for balck and white printing only.
OR
CHANGE CARTRIDGE
Jun 18, 2010 | Brother MFC 240C All-In-One InkJet Printer
Having difficulty on printing documents by using epson cx2900?
Have you changed the ink cartrage? Could simply be out of ink.
Check your last printed item. See if it is getting lighter toward the end of the document.
Feb 14, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Mono color
These models use a "3 colour" printing process. In other words, these printers do not contain black ink when the BC-05 colour cartridge is installed. To produce black print, a 3 colour printer mixes an equal amount of the three primary colours. This process is known as "composite" black.
As the ink in the cartridge runs out, one of the three primary colours will run out first, depending on the material that has been printed. After one of the three colours has depleted, this colour will be missing from the mixture required to print black, and the print will change colour. This is the indication that the cartridge needs to be replaced. Usually the remaining colours in the cartridge will run out soon afterwards.
Rate the solution as appropriate !
Feb 07, 2009 | Lexmark X7170 All-In-One InkJet Printer
Trying to print black only document
the problem with this printer is that all the inks have to be at a usable ink level, if any one of them are below the acceptable amount it will not print in any colour at all not even black.
Jun 25, 2007 | Epson Stylus C82 InkJet Printer
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
