Vaio PCG-R505EL - fan making noise
Ventilator is making noise when machine is in the docking station. Sounds like it touches something... what should i do?
  • markcoble Dec 07, 2008
    I have a Sony VGN-BZ12VN that does the same with the docking statio that goes with it.
  • jusvalue Apr 04, 2009
    I too have the same issue (PCG-R505EL). I took the machine apart and removed the fan housing. I then opened the fan housing and cleaned it thoroughly. This however did not yield the desired outcome. I did find that the part that spins (the fan itself) is held snug to the housing and shaft with magnets. My guess is, these magnets have lost the strength to hold the fan firmly in place as it rotates. I think the noise comes from the motors shaft is spinning faster than fan. Thus, the noise is a result of the magnets weakening over time as magnets do. I see three options here: 1. Replace the magnets (good luck finding those). 2. Buy a used replacement for the fan (risky because you do not know the condition of the magnets). 3. Buy a new laptop (this hurts, as I love my notebook). Anyhow, this is what I believe to be the problem. If someone else knows more please feel free to jump on in.
    Note: You can use power panel to adjust fan settings for each profile. However, this compromises CPU performance by regulating CPU speed to prevent overheating.
I too removed the fan from the housing and cleaned the fan shaft with a Qtip. Then I cleaned the magnets.
THEN I used a really light bike chain lube called Prolink to lightly lube the magnets and the fan shaft.
The thinness of the lube ensures that it won't gum up the fan shaft and if the shaft does make contact with the housing it won't make quite so much noise.
Three days now and the difference from "grinding chrun" to whirring fan is noticeable.
Posted on Jan 16, 2011
Will a kensington universal docking station work with my sony vaio pcg-7d2l
Yes it should if you are running Windows XP, Vista, 7 or 8. You just connect to the unit using a spare USB port on your laptop and a plug-plug USB cable. It has it's own power so you'll need a mains socket. This means you can unplug your laptop and leave any devices charging on the docking station USBs. Your laptop should auto-instal the station. I believe there is a table/support available which combines with this unit. There a varying prices for this unit so look around.
Good Luck
Feb 27, 2014 | Kensington SD400V USB Docking Station with...
Vaio pcg671l lost external power (no problem for the power supply cord, work well wit battery). I am looking for a compatible docking station as external power instead.
hi. I would like to suggest you get these parts are offline, because it's easy for you to test before buying {make sure you match the parts before buying}
May 15, 2011 | Sony VAIO PCG-505 PCG-671L PCG-700...
How can i reboot my sony laptop tpye pcg-r505el
open command prompt and type shutdown then hit space button then -r then hit enter button your laptop will reboot
Feb 19, 2011 | Sony VAIO R505EL Notebook
I need sony laptop drivers model PCG-6P9P
to the one who needs a sony vaio laptop driver,
i hav a sony vaio laptop model PCG-6P9P. evrything is in good condition except the battery and keyboard. how much do you want to pay for my laptop?
Sep 13, 2010 | Acer EZDock (LC.D0303.005) Docking...
Loud fan belt type noise from laptop
There are no belts in a computer, sounds like something is rubbing in your computer cooling fan blades, get a can of Duster ( to clean dust from things) and spray the compressed air into all the vent holes to clean out any dust and debris.
May 23, 2010 | Sony VAIO PCG-K35 Notebook
Whilst working, my Ariston oven ventilator tangential fan motor at times produces an intermittent metallic noise, as if metal is touching with metal. What could this be, and how can this annoying noise be...
Whilst Working? An explanation of what you were doing would be extremely helpful.
#1) If it sounds like metal on metal, chances are its METAL ON METAL.
#2) Its pretty obvious you didn't make graduate highschool, let me explain this as simple as possible so you don't hurt yourself trying to read it.
#3) Your fan (thing that blows) probably caught a wire (metal string), or was altered slightly and is now hitting a metal ventilator (sponge) which is installed near the fan on this particular model.
Oct 11, 2009 | Ariston Technologies Ovens
Cpu fan malfunction
Hello Chris....i highly recommend you dont "pry" on anything and it have it serviced by a qualified tech. The vaio incorporates the heatsink and fan as a unit, It's a 2 wire fan that is temp. controled from 5v and up. You can take a vacuum and place at the ventilation opening and remove some of the dirt & dust that has accumulated inside, this will help. The cost is around 100 buxs for a new fan & sink...Sony part # 1-763-483-12. Attached is a pic of the unit..; Also note: a depleted battery will effect fan operation as well.
Hope this helps and will fixya up....
May 18, 2009 | Sony VAIO GRV670 Notebook
LCD turns white.
probably failure in the LCD controller IC in the lcd controller board. that no signal was sent out to the lcd driver ic thus you could only see white display. A replacement of LCD panel is the best solution. best regards
May 16, 2009 | Sony VAIO PCG-R505 12.1 in. Flat Panel LCD...
Sony vaio pcg-r505el won't turn on
Vista or xp? I'm assuming Vista?
Apr 06, 2009 | Sony VAIO R505EL Notebook
Computers & Internet Logo
681 people viewed this question
David Payne
David Payne
