Question about Dell E172FP 17" LCD Flat Panel Monitor
Monitor My monitor is a Samsung SyncMaster 204BW I am having a problem with the links opening up. When I click ona link it goes to the top of the monitor in a long bar clear across the top. The more links I click on the more they layer up on long boxes across the top, just like the address bar. I can open them by clicking on the little square next to the X on the right corner, the box you would use to enlarge the picture. No one has been able to solve my problem, passing the buck from AT&T to Dell to the monitor, but nothing works. My PC Tech expert has never seen this happen and does not know how to solve it.
    Problem Solver:
  • 19 Answers
Do you have friend that has a laptop? If yes, you can have your monitor hooked up to external VGA connector. Your problem may or may not disapear. If it does it is likely that the graphic chip is to blame. You may find a inexpensive graphic card (plenty available) that will work.
Posted on Nov 19, 2008
Samsung Syncmaster 204bw has a red screen
A red or pink tint to the screen indicates that the back light bulbs are failing and are about to burn out. Its time to look for a new monitor.
Mar 17, 2012 | Samsung SyncMaster 204BW LCD Monitor
My 204bw says check signal and is hooked up! How can I reset it? Thanks
Make sure you have in on the right input mode.If you are not recieving anythingat all,then you could have a bad AD board, or bad inverter.
Jun 03, 2011 | Samsung SyncMaster 204BW LCD Monitor
I have a Samsung SyncMaster 204BW monitor using with a Dell Precision M70 latop. How can I get the monitor to display in the wide screen format (full screen)? Currently I have an almost square active...
Did you set the PC to send the vidoe signal to be at the
Native resolution of this monitor?
1680 x 1050 @60Hz.
Here is the user manual:
http://static.highspeedbackbone.net/pdf/Samsung-204BW-UserManual.pdf
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jan 14, 2011 | Samsung SyncMaster 204BW LCD Monitor
My samsung syncmaster 204bw power light keeps blinking and wont turn on.
Does it do the same with another PC?
If it is monitor, then please read below
Look for bad caps first:
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Dec 29, 2010 | Samsung SyncMaster 204BW LCD Monitor
Describe your samsung syncmaster 204bw Problem: I turn the monitor on, the power button turns blue, the screen remains dark, the image on my Powerbook G4 appears flashes on the screen before it goes black...
Check the power supply DC filter cpas first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Basic LCD monitor troubleshooting guide:
Nov 08, 2010 | Samsung SyncMaster 204BW LCD Monitor
Samsung syncmaster 204bw will not turn on
Check the power supply first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
May 31, 2010 | Samsung SyncMaster 204BW LCD Monitor
The monitor powers up and the analog icon blinks on and off and nothing else happens...no colors...when connected to computer.. The images show for a few seconds and goes blank...turn monitor off and on...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 15, 2010 | Samsung SyncMaster 204BW LCD Monitor
The monitor powers up and the analog icon blinks on and off and nothing else happens...no colors...when connected to computer.. the images show for a few seconds and goes blank...turn monitor off and on...
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 29, 2010 | Samsung SyncMaster 204BW LCD Monitor
I have samsung syncmaster 204BE monitor. always
If you are talking about the power light flashing and no picture then its not in sleep mode, the power supply has failed. Check our web site at: HTML clipboard www.ccl-la.com Look in the monitor repair pages. We have a step by step repair guide for this model Samsung. If you don't want to do the repair yourself we do offer a repair service, information is available on our site.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 31, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Monitor not opening up page
This is definitely not a Hardware problem.
Samir
Sep 09, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Dell E172FP 17" LCD Flat Panel Monitor Logo
35 people viewed this question
Alun Cox
