Question about Acer Aspire 5670 Notebook
Acer Aspire Desktop SA80 Start Up Problem
When turning it on from the tower it goes to a white Acer screen with Del: Enter Setup F12 Boot Menu Intel inside. It holds for 4minutes & 25 seconds everytime before I get the windows login page up. Any ideas or should I try recovery disks?
Del enter setup or f12 boot menu
try reseating the graphics card (remove and reinstall) making sure to press it firmly into the slot
Mar 07, 2014 | ASUS Computers & Internet
Change the f12 boot menu on an acer t180
Press F2 to enter BIOS setup at startup. You can set which devices appear in the list from the boot menu.
http://johnbokma.com/mexit/2007/12/22/acer-aspire-phoenix-bios-boot-screen.jpg
Jan 20, 2013 | Acer Aspire™ T180 PC Desktop
When its switched on it doesnt boot, just goes to the acer splash screen that says 'Del to enter setup" and "F12 for setup'. I think it was switched off with a usb memory stick 2.0 connected,...
Have you gone to 'setup' using F12?
If you can get into Setup you should be able to change boot options to boot from fixed (hard) disc. Unless the hard drive has been damaged or formatted this should work.
Jan 04, 2011 | Acer Aspire™ T180 PC Desktop
My Acer has a screan has the acer logo on it and askes me to click the Del: enter setup F12: reboot menu, Need help please.
Have you tried ignoring the message and letting it boot normally? The computer might be set to show the POST screen on boot. Let it run and see what happens.
Jul 08, 2009 | Acer Aspire M1640 Refurbished Intel...
Acer Aspire T180
check your removable media disk drives and make sure that you don't have like a jump drive or CD-Rom that the computer doesn't like. If that doesn't work, enter the BIOS setup (usually F2, F12, ESC or something like that....check the bottom of the screen.) and find the Boot Order settings & move hard drive to #1
Jan 08, 2009 | Acer Aspire™ T180 PC Desktop
My ACer T180 does not boot boot up
sound like the hard drive. do you hear the drive spinning?? you may need replace or reformat.
what OS are you running....?
Sep 10, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire E380
Uw systeem erkent niet de harde schijfaandrijving. Het is zeer mogelijk dat sinds XP CD niet de harde aandrijving die de aandrijving zelf heeft ontbroken zal zien en zal moeten worden vervangen.
Sep 03, 2008 | Acer Aspire E380-UD420A (ASE380-UD420A)...
Wont turn on
He is getting the screen with del, enter , f12 so the power supply is fine it could be his bios battery that needs to be reseeated and factory default loaded. If you left it on for a while it could be in a state of sleep/hibernation and if you should it down manually you could have stopped it from resuming and thats why it wont boot now and by reseating the bios battery for a couple minutes could remove the resume from the computers memory and might fix your problem. Hope my answer gets you closer to a solution. Please Help rate me if I helped you out or not I am new but a very good tech.
Aug 09, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire T180 Frozen
Select the del and in bios, select optium defaults. next select F12, will it go any further?
Jun 08, 2008 | Acer Computers & Internet
Acer Aspire 5670 Notebook Logo
171 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
