Question about Brother MFC 420CN All-In-One InkJet Printer
Error unable to initi
Brother mfc 420 cn
Error stating unable to initi. I have checked for foreign objects and cleaned as instructed but no luck. I need to mention the the status of the machine is ready. What should I try now?
  • 6 more comments
  • MikiStewart Sep 14, 2008
    Exactly the same problem. Can not find an obstruction in the printer. Do not know what to do next.
    Is this printer worth taking to a repair shop? Or, should I just cut my losses and buy another?
    Thanks
    M
  • Ruslab Sep 18, 2008
    I have the same problem with Brother MFC 420CN. It gives error: unable to initiate. I tried all steps in the manual, nothing works. Your site says there was one solution posted, but I couldn't find it! Appreciate any help.
    Russlab
  • tuba1 Sep 22, 2008
    I have the same problem with Brother MFC 420CN. It gives error: unable to initiate. I tried all steps in the manual, nothing works. Your site says there was one solution posted, but I couldn't find any!
    Thanks for your assistance in advance.
    srolf
  • Anonymous Nov 20, 2008
    Printer MFC 420 Cn "unable to initi" what's the solution?
    Mfc 420 cn printer error " unable to initi" . What the solution?
  • seesee38 Dec 31, 2008
    is there a solution to this problem to many people with the same thing
  • mw2009 Jan 06, 2009
    unable to init.
  • hudkoa chic Jan 12, 2009
    My printer is telling me to check the maual book but i lost it and now i need help to trouble shoot my printer
Did ok
Posted on Sep 09, 2008
I have a Brother MFC-3360C printer and have an error. Clean Unable 51
Error 51 normally indicates a paper jam or a sensor problem. Check the paper path and the printer head movement zones (far left and right) for any foreign objects (even small pieces of paper). If there has been a paper jam, was the paper forcibly removed? If so, possibly one of the sensors has been knocked out of position or damaged. Dust, dirt, grease or spilled ink may also be contaminating a sensor. This is maybe one of the most elusive problems to solve..!
Apr 10, 2015 | Brother MFC-3360C All-In-One InkJet...
Clear "error 76 : Unable to clean" on brother printers mfc-j430w
Most likely, The machine has a mechanical problem or a foreign object such as a paper clip or ripped paper is in the machine
Nov 20, 2013 | Brother Multi-Function Center MFC-240C...
My brother mfc 420 cn says unable to clean see troubleshooting guide that i know longer have
If you look at the Brother website you will find a trouble shooting guide for your machine.
In the guide, for the error you quote Brothers guidance is to check for a stuck piece paper, however it also states that if the printhead is hard over to one side (righthand side if memory serves me correct), then to contact Brother. If you do so, Brother will tell you it needs to be serviced by a Brother agent, which will likely cost you more than a new one !
If it isnt a stuck piece of paper, the problem is due to the fact that Brother machines excessively self-clean. Each time they self-clean a small amount of ink is dumped in to a holding tank/sponge. When a predefined number of self-clean operations have been performed, the machine refuses to print and gives the error message you have stated. Brother state that the tank/sponge must be replaced before the counter is reset, again by a Brother agent.
However, there is a way of reseting the self-clean counter yourself - if you Google your model number and the error code somewhere in the results you'll find how to do it. The only risk of doing this without changing the tank/sponge is that it will eventually overflow and leak out the bottom, but I did my Brother all in one some time ago and have had no problems yet.
Oct 05, 2010 | Brother MFC 420CN All-In-One InkJet...
Error : Unable to clean
Unable to clean means that the waste-ink "sponge" is full. If you've already checked for small paper part (which is very unlikely to cause this error message), the error is mechanical. Unfortunately, that's not something us users can change, but the machine would require to be sent to service. So if your machine is not within warranty, I'd doubt it'll be worth the service cost.
Jun 02, 2009 | Brother MFC-5840CN All-In-One InkJet...
Unable to clean-need trouble shooting guide
I am having usual problem of unable to clean (Brother MFC-5440CN). I have looked for any strange object but can't find any. Could this be amechanical problem and what is solution?
May 27, 2009 | Brother MFC-5440CN All-In-One InkJet...
What is 'print unable 51' never had a paper jam!
Do the following:
Print Unable
XX
problem.
—OR—
A foreign objects such as a clip or
ripped paper is in the machine.
Open the scanner cover and remove any foreign
objects inside the machine. ( You might try cleaning the scanner glass.)
If the error message continues, disconnect the machine from
the power for several minutes and then reconnect it.
Try this and let me know what happens. Binary Bob
Nov 21, 2008 | Brother MFC 240C All-In-One InkJet Printer
Error message on my mfc 420 mc
this has been written many times here in the forum.
plz search forum "unable to print"
Jun 22, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother mfc 420 cn
if you have an error 41 the machine wont print any more due to a short circuit in the print head.
plz check error message.
anyway, if you have received error 41 you need a new printhead or better (because its cheaper) a new mfc.
sorry!
Feb 13, 2008 | Brother MFC 420CN All-In-One InkJet...
Error message unable to print
Send it back. The printhead voltage is innnnn disorder. Netxt will be Error 41 (Every Error starting with 4 means probs with printhead and in 99,9% the head has to be changed and cant be fixed!)
Sep 20, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
469 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
