Put game disc in and that is it does not show disc was put in. i had it send out to have it fix and they said they fix the dvd drive then the next day they said there were bigger problems they said it needed a motherboard help
Fiend your solution direct from Nintendo. Here is your solution....
http://www.nintendo.com/gameboy/prob676ijt65/solution
a6
You probably just need a brand new laser. I will provide you with links for a step by step guide to replace the laser, and various sites where you may purchase a new laser at a decent price. First, you need to insert a disk and look at the top right corner of your TV for a little swirling circle. If that is not there you may need to open your system and make sure the people that "fixed" it plugged the Blu-ray player cables back in. If not just reattach the cables. There are only 2, 1 black and gray power cable and 1 silver flex cable. If it still doesn't work then replace the laser. Below you will find the links mentioned above.
Laser replacement guide:
http://progamer.cc/blog/ps3-laser-kem-400a/how-to-replace-a-ps3-bluray-lens-guide.html/
Online stores to buy Blu-ray lasers:
http://search.ebay.com/kes-400a_W0QQ_trksidZm37QQfromZR40QQsatitleZkesQ2d400a
http://www.psxboy.com/349_PS3-KES-400A-Laser-Lens.html
http://store.richspsxparts.com/pl3lake.html
http://www.echostore.com/kes-400aaa.html
If you replace the motherboard, pretty much the DVD needs to be replaced as well. Now if you sum it up, it nearly costs like a new unit. Instead of investing money on repair, just buy a new unit since your device is already out of warranty. With regard to the DVD, you can try cleaning the lens using dvd lens cleaner.
Its not the mother board is the dvd disc its the laser its not reading laser needs replacing. don't believe there BS there trying to con you
I can understand your frusrtrations
Was the Ps3 sent back to sony?
Sony has a 90 days but with a mother board
that is covered for 1 year...
i know how to fix it........ leave the ps3 off for an hour or 2 .....
then restore default settings..... then play a demo.. when i played my
demo it froze that might happen to you ..... if it does happen turn it
off then turn it back on ..... it might ask you to format ..... so i
formatted mine .. then you will c the disc.. it might not ask you to
format so thats good
try this first
1. put the disc in.
2. go onto any demo.
3. press the ps button.
4. then you should see ur disc.
everything works but the drive correct
file:///C:/Documents%20and%20Settings/Jay/Desktop/PS3%20BLU%20RAY%20PROBLEM%20FIXED!!!!!!!!!!!!!.flv
You-Tube video "file:///C:/Documents%20and%20Settings/Jay/Desktop/PS3%20BLU%20RAY%20PROBLEM%20FIXED!!!!!!!!!!!!!.flv" placeholder
not sure if my video is viewable but this may help
this better work this darn players
yes there watch this and this may help it is worth a shot
good luck and have fun gaming
we hope :) please rate my help
seal was broken and out of warranty
the place i sent it to said they fixed the dvd drive and it was the motherboard how can i check it
thank you i will try it
