Question about Frigidaire GLTF1240A Front Load Washer
Washer wont wash- nothing...
I put a load in the washer, and come back to see the bottom of the load is soaked while the top of the load is dry indicating to me it hasn't moved 1 bit- the timer gets to the spin cycle and makes a loud humming noise with no action. Also when washer was working, it sounded like a turbine engine when on spin cycle- worth the fix on a 5 year old machine?
  • 1 more comment
  • puglife Sep 10, 2008
    bang on- thank you very much
  • lej1093 Dec 07, 2008
    my washer wont do anything but the spin cycle? help please
  • sfhlaj Feb 06, 2009
    I have the same problem. It fills with water and then it does nothing. Other discussions I read pointed to it being a problem with the water pump. So thinking thats what it was I replaced that (easy job and only $80 for the pump). Now as I move the knob through the wash cycles by turning it I get it to drain at least but it won't agitate or spin or go through any cycle other than fill, sit there, and only drain while I manually turn the nob to final spin. I took the back panel off and found that the motor is not even turning as I go through the cycles. I removed the belt and tried it again, still no movement. I called a repair shop and they told me it was the main control electronics and wanted $400 to install that. Any suggestions?
  • 868 Answers
Remove the back panel if it has one and look for belt that is off.Before you put it back on check the pulley for any looseness.It should be tightened if you need to.I'll assist you further if you need my help. Please Rate this !!!
Posted on Sep 09, 2008
Hi there, my washing machine will not spin dry and the machine wont empty, i have tryed turning it off at the wall and nothing! please help
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 30, 2011 | Fisher and Paykel IWL12 Top Load Washer
Washer dryer 8 - 4kg code WD-1457-RD It has come up with AE half way through a wash -- how do i fix it?? Thanks Kate
Did u figure out an answer to this Kate? this as just happened to ours and can't work out what it means! Aaron
Dec 22, 2010 | LG WD-12124RD Front Load Washer
MAV4755A Top Load Washer: When I turn the dial to start wash cycle, nothing ...
if press button selection, make sure that no 2 buttons are pressed
Jan 27, 2018 | Maytag MAV4755A Top Load Washer
Washed load of towels wont work
try cleaning the drainage filter located under the front bottom panel.
Aug 14, 2009 | GE WSXH208A Front Load Washer
Drying cycle malfunction
Unplug the dryer and replug back up again.
Put on wash /let it go thru the cycles.
Nov 27, 2007 | Malber WD1000 Front Load Washer/Dryer
Frigidaire GLTF1240A Front Load Washer Logo
81 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
