Question about RCA T25062 25 in. Combo
TV - Won't stay on
We push tthe botton to turn the TV on, it makes the little sound that it is on then turns right off? Any reasonable fix to this issue? Thank you!
  • 64 Answers
Probably a bad transistor, you'd be best having a pro take a look at it. Good Luck!
Posted on Mar 01, 2006
My Samsung tv won’t turn on the red light stays on what can I do to fix this
As long as you have the standby indicator the standby voltage is there, next thing to test is the PSON or Pwr-on terminal on the power supply board if your able to, should be 0 with it off and abotu 3.5 vdc when you push the on botton, if you don't have that its the main board that is bad, if you do its the power board...if you don't have a meter or the knowledge to test it then you need to either recycle it or take it in for service somewhere
Mar 17, 2018 | Samsung Televison & Video
Element flat screen tv screen appears off when power is on
At this stage, try replacing ps Caps. Old elements had cap problems in ps area.
Feb 11, 2014 | Element Electronics Televison & Video
I don't how to set the timer. please help.
keep central heat off (botton on left push down botton on right push all the way up. Turn dialclock wise and either push in the little white button or pull out the "advencor". that button works the speed of the dial by turning it also
Mar 11, 2013 | Heating & Cooling
The tv usually turns on but now it won't. When it does turn on it makes a noise like a motor boat sound. The noise stays on until you shut the tv off. I'm not sure what it is I think it's the fan but
I would say that if there is a fan inside of it and it sounds like a fan bearing going bad then that is what it is. The reason for it not to be turning on anymore could be because whatever that fan is cooling has failed. Not sure.
Jan 30, 2013 | Televison & Video
THE TV WON'T TURN ON SONY TRNITRON
Sounds like the clunk most Sets have when dead cold and first turned on= a degaussing coil which will not stop the set from working.
If the power light does not make it on someone has to open the unit and see if the fuse inside is bad---not exactly a light set either and if you are not able consider either a shop or replacing the set as some repairs on this model can get rather expensive.
Dec 06, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My lcd tv keep flashing the on botton when i turn it on and there is no image,i have to keep pushing the on botton until the on botton light stay on and the screen comes on,
The power supply needs repaired NOW. I suggest you do not play it---unplug it ---and take it in for service. If you continue to play it you will price yourself into a new tv.
Nov 25, 2010 | Toymax Magnavox 37MF231D 37 in. LCD TV
Need operating manual
if you are asking about the ” innovage” large tv remote… you do not need a code booklet.
maunally turn your tv on
point the remote at the tv
push ” code search”
a red button will blink
push the ” TV” button
then push the upper right botton with a circle and line on it…
the red burron will blink during each push…
at some point the tv will turn off…
push the “enter” button
the tv will then work with the remote.
it it takes too long to catch so to speak…
do not turn the TV off…
during the process… go ahead and push search code again..then TV
then on/off botton sometimes this speeds up the process.
i’ve found every once in a while the large remote stops responding to the on/off button…
just repeat the steps.
We hope this helps please rate/vote for me if it does thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 09, 2009 | Televison & Video
Channel display for Sony WEGA KV32FS100 will not turn off
Most all Sony models use the same programming for the remotes. Borrow a Sony remote and push the display to turn it off.
Mar 23, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
RCA T25062 25 in. Combo Logo
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
