Problem with volume
I just got a new (used) computer, and am happy with it, but there is no sound. Speakers are plugged in, and were working earlier when tech person brought it over and set it up. Thanks....
  • 152 Answers
If it was working before, then the problem could be just loosened connections. Just insert the terminals firmly. Also, used computers tend to have broken wires, so check for damage on your wirings and cables.
Posted on Sep 09, 2008
After moving and resetting up my computer at my new address my Bose Companion 2 speakers do not work throough my computer. They do however, work plugged into my iphone
make sure that you are plugging into the correct socket for the speakers, if they are colour coded then use the green one, then check the volume properties on your computer to make sure the volume is turned up and that the sound isn't muted.
May 03, 2011 | Bose (AA52650) 2 Speakers
Pretty much all of a sudden my sound just stopped working on my computer, it was working fine ever since i got the computer bout a year ago and earlier today my sound went out, my speakers worker fine (ive...
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
dont forget to vote
you might have to get a portable usb sound card if you mean dont have a sound card installed
Feb 06, 2011 | Computers & Internet
Creature III brand new faint sound!
Check out here:
Jan 10, 2010 | JBL CREATURE II Computer Speakers
I have the speakers but the sound is very low. How can I increase the sound output? thank you, Cliff
Hi cliff, Have you set the volume on the Subwoofer itself yet??? if so also have a look at your PC Sound volume , for example Start Control Panel , Sound , and adjust it higher there ;)
Hope this helps bud , and happy new year :)
Jan 03, 2010 | Polk Audio AMR50 Computer Speakers
I cant get my speakers on my computer to work
Computer speakers are specially designed for a computer desktop environment. They are smaller than normal stereo speakers and often have built in volume controls and amplifiers. In most cases, you can plug in your computer speakers and have them work immediately. Occasionally, however, you will need to adjust your computer sound settings to get them to work correctly.
  1. Step 1 Plug your speakers into each other. Most PC speakers have a detachable cord that goes between them. Powered speakers have a cord that plugs into the wall, which may be detachable as well.
  2. Step 2 126401_thumb.jpg Image Courtesy of: Look at the sound card output in the back of your computer. If your soundcard has three colored jacks, plug into the green one. If it does not have colored jacks, plug into the one next to the jack with the picture of a microphone. Plug the power supply into a wall socket.
  3. Step 3 Turn on the speaker, turn up the speaker volume and play some music. If it doesn't work, continue to step 4.
  4. Step 4 Turn your volume up on whatever media player you are using. If the music still doesn't play, continue to step 5.
  5. Step 5 Go to the volume settings. If you are using windowsmag-glass_10x10.gif, click Start Menu -> All Programs -> Accessories -> Entertainment -> Volume Control.
  6. Step 6 Adjust the volume settings. Use your mouse to drag the main "Volume Control" slider and the "Wave" slider all the way to the top. If either of them have the "Mute" box checked, uncheck it. Try the sound again.
Nov 14, 2009 | Sony SRS-D21 Computer Speakers
Low volume with volume cranked up
Are the speakers battery-powered (with dead batteries?) or AC-powered (but not plugged-in) ?
Do the speakers work correctly when connected to some other desktop or laptop or iPod ?
Oct 09, 2009 | HP Compaq JBL Pro (401508-001) Computer...
Labtec LCS-2424 speakers: left speaker stopped working
I have the same problem sir, only the speaker with volume
control works. Earlier I used to twist the volume control this
way and that way to get the sound from the other speaker also.
Now the same technique doesn't work anymore.
Jun 27, 2009 | Labtec LCS 2424 Computer Speakers
No sound on my computer. it was working until two days ago.
u don't need to restore it's dound setting problem iu just chek volume control and chek master sound and wave sound is on or mexmimum
Jan 08, 2009 | Bose MediaMate Computer Speakers
Speakers have not worked since purchased
Hi Monde
Happy Holidays,
As you said, you have warranty yet, use it! but, if you don't wish to use ti, you can buy a new pair of speakers, and use with montego bay or creative labs, USB sound card, and see if work fine, this should fix the problem.
Dec 29, 2007 | Logitech R-20 Computer Speakers
No sound
Most computers use the GREEN output jack on the sound card for playback...plug your headphones in the back where the speakers go...sound? Yes...then verify you ahve the speaker system put together you don't...note: self powered speakers must be plugged in to work (electrical plugged in). If no...then you got a bigger fish to fry... Good lUck
Aug 26, 2007 | Philips MMS 460 Computer Speakers
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
