Question about RCA HD52W59 HDTV Projection Television
My RCA is a big screen 52 " is about 7 years old
The colors on my big screen cannott be ajusted properly and looks very dark on all channels will i be able to get it fixed ?
  • 905 Answers
Yes this problem can be fixed but the price may scare you!
Posted on Oct 07, 2008
I'm trying to improve the picture- seems to be TOO DARK- tv is 10 yr old ser3 935351541- ihave tried color adj etc
Rca Screen Control These sets have screen control adjustment usually located behind the speaker grill(pops off -velcro or press tabs) and convergence front board. There are 6 contols on a black molded assembly about 31/2"x21/2" square. adjust only the top controls marked "Screen R G B" the bottom ones are focus
Method:
-turn on set and let warm up for 30 min at least
-switch tv to blank unused video input channel
-adjust each control in turn until you see the picture glow (with the corresponding color) and slightly back off the control - repeat for each color - this will increase screen brightness and ballance your color
Hope this helped.
Oct 18, 2009 | RCA P52945 52" Rear Projection Television
Mitsubishi WD-52628 52" Inputs look like old cable scrambled channels
Change the 1000uf @16v capacitors on the FMT board that should solve your problem. You will most likely found that they have swelled. Let me know if you need further info.
Apr 04, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Proscan (RCA) PS52652
Also, the proscan ps52652 has the ctc-169 chassis. This set is a 52" manufactured in 93.
Mar 30, 2008 | RCA P52926 52" Rear Projection Television
Sharp 32sf560 TV
Good day
You an adjust the screen brightness on the rear portion of your units flyback. Then the intensity of the color will change.
chris
Feb 02, 2008 | Sharp 32C241 TV
52 in RCA widescreen HDTV Monitor
high pitched squealing noise >> im thinking is the color wheel which will also give you the yellow color, don't know if that would also cause your screen to blank.
mcm carries RCA
Feb 01, 2008 | RCA HD52W59 HDTV Projection Television
RCA 52" projection
When you are changing channels and the screen normally blanks to black between channels, do you instead see a reddish screen?
Did you check your event codes?
Dec 05, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca home theatre big screen tv
# 1 above you have covergence problems ,there is a service flash from rca to fix your fault,ask your tv shop. fault # 2 above turn off the color and adjust your screen settings for a grey picture,set brightness and contrast to middle settings. # 3 fault read #1 cause if your auto focus will not correct you require service there is a harness connector that looses connection and causes several fualts on the 52" rca's you can repair the fault but if you miss the harness replacement you will do it again.
Dec 01, 2007 | RCA 32F531T 32" TV
How to adjust picture on projection tv
i have a 52" rca projection , and the screen looks like this ") (" on the sides can i do something to straiten it back out?
Aug 28, 2007 | Panasonic PT-53TW53 53" Rear Projection...
What could be wrong?
These old technology sets (rear projectors) are notorious for high voltage problems, and this is probably what you have. RCA is now, sadly, a Chinese junk brand with poor support, but your older unit may still be slightly viable, but not very. Put it into a big truck and take it to a shop. Home service may not be available, or may be nearly worthless. Better yet, get a new TV. I suggest a 1920X1080 LCD model. (Panasonic, Sharp, Sanyo, even Funai or Orion are the best choices) Forget plasma, DLP, or any of the rear projectors. These huge, ugly (and mostly empty) boxes really belong in the Smithsonian, not in your home! When you see the new LCD's, you will forget about your old boat anchor in a heartbeat.
Sep 04, 2006 | RCA HD52W58 52" TV
RCA HD52W59 HDTV Projection Television Logo
49 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
