Hmph. Sounds like a boot issue. But for my standards, I write myself a checklist. I do this in order to keep track of all possible solutions. My Dell Optiplex GX280 can be a real pain. . I start with the way I am turning it on. Sometimes a system can be as finiky as a cat. Unplug the system from the wall. Then plug it back in. If it is on a shield wall jack that has a switch, if it is off, turn it on. from there. First, (when, and if it comes up), check through your boot system prompt. This usually takes the form of F2,or F1. If your system displays (cannot find harddrive), or shows a problem with the amount of space on your harddrive, make sure that you have backed up all your files before going any further. Also, check to see if your harddrive OS can find the correct place where your SYSTEM is located can find your system boot by selecting AUTO for your harddrive(s). It make it easier for your computer to find the OS system in which to bring your computer online. Second. Typically, (and depending upon your space on your harddrive), they tend to short you on your drive space. This will trigger your drive to shutdown, because it has run out of useable, writeable space. ALWAYS HAVE A BACKUP. If you can get into the actual BIOS, check and see if you have exceeded the harddrive space. Third. CLEAN OUT YOUR SYSTEM. Dust can cause havoc with your computer. Fourth. Check all your connections. Make sure that all your lines leading to your hardrive(s) are connected. Five. It is possible to have a hardrive failure. See if you can take it to a computer shop that you can trust to either retrieve the information on your harddrive, or install a new harddrive, and all of its drivers that prompt your programs to work.Six. TAKE PICTURES OF THE INSIDE OF YOUR COMPUTER. There are shops out there that will take out parts, and repackage them. Seven. Check your VIDEO CARD, as well as your wires. EITHER may need replacing.I hope this information is helpful, and can get your computer up, and running. :))
When
you plug in the power cord is there any lights whatsoever on the laptop, where
the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning,
lights on the computer, hear any beeps or lights constantly blinking, hear the
DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a
second or two? If so the computer is trying to boot or may have booted,
but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the
laptop and why it is not booting. Most times it's a motherboard issue
when you hear beeps or blinking lights continuous. Most times the problem
is with the memory or Video Card. Count the Blinking Lights or Beeps and take
note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static Charge
Buildup. Remove the Power Cord, then Press and Hold the power button for
30 seconds. After 30 seconds plug the power cord back in and hit the
power button to see if it boots.
Maybe
your memory is bad or the memory slot is bad.
Remove
the Power Cord, Open the Case and remove one of the memory chips. Set the
chip aside then try rebooting the computer. If it boots, then you know
the memory chip you set aside is bad so mark an x on it with an ink pen.
If it fails to boot then move the chip to the next memory slot and try
rebooting. If it fails take the chip out and set it aside, then put the
other chip in and try booting it in both slots. If it boots, just to
verify that the chip set aside is bad, mark an x on it and put it into the open
memory chip slot and try booting.
When
Maybe
Remove
