Question about Nokia 6131 Cellular Phone
Ring problem with nokia 6131
My nokia 6131 does not ring for incoming call it only vibrates althouth the profile is set to ring
  • bhintaward Sep 09, 2008
    can not reset factory setting shows code error
  • 1,239 Answers
HI SIR.  please cheak whether the profile in the general mode.. and keep it in the ring mode.. if also it does't work mean's. u need to restore the factory setting's..   step for setting's..   1. menu>tool>setings>phone>general>restore factor settings>it ask's for thr passward. general passward is 12345 or ur security code..what have u given.. it will restart .. and u will seen it will be ringing . if any doubt assist me.. i am there .. thank u..   please rate it.
Posted on Sep 09, 2008
Hey plz help me wit my mobile plz help me i need to update my mobile so how i can update my mobile
Posted on Dec 21, 2008
Why my nokia C3 doesnt ring accordingly although i set the ring tone already?its only vibrate.i'm not using silent mode.
I can imagine it how annoying it would be to you to see your cell vibrating instead of playing your favorite ring tone. Most probably it could be because of incorrect Profile configuration. It is possible to make your phone vibrate in almost every profile so we will assume that it is the reason for your problem too. Do the following and check some parameters as described.
1. Go to Menu > Settings > Profiles
2. Select Profile and then Select General.
3. After selecting General you will be given 3 options (Activate, Personalize, Timed)
4. Select Personalize.
5. In the Incoming Call Alert field, select Ringing.
6. In the Ringing Tone field, select your favorite ring tone.
7. Scroll down, (push down button) the next field would be Ringing Volume. For now select the max.
8. Scroll down to the Vibrating Alert field and set it to Off.
9. Scroll further down thill the very last field where it says Alert For, select All Calls for this field.
10. Save your modifications.
11. Activate the profile and see if it works now.
Only and only If it doesn't work, it may be due to software corruption.
In that case reset your phone to the factory default settings by going to:
Menu > Settings > Press UP button.
Select Restore Factory Sett. give your Security Code (default = 12345) and viola.
(Make backup of your messages ad contacts before attempting this)
Jun 04, 2011 | Nokia C3 Cell Phone
My Nokia 6131 has stopped ringing - it just vibrates when there is a call/text. I haven't done anything different. It's not on silent and I've tried resetting to factory defaults. Any suggestions?
its like the user profile has changed to silent
All you have to do is....
go to the settings on your mobile phone, scroll to profile and select it, click on general or loud, select personalize,check the incoming alert mode and see if it is set to ringing,scroll down and select a tone for the alert then save. after which activate the edited profile as the profile in use..
hope this helps
Jan 25, 2011 | Nokia 6131 Cellular Phone
Ibought my nokia e63 a week ago. Now there is no sound when it rings and no vibration i did go to the settings and set everything the way its supposed to be. I did not let it fall or anything. I put my...
u can try this
go to profiles then select the profile u want to activate then go to its customize menu and incoming call alert type and select it ringing
Aug 23, 2010 | Nokia E63 Cell Phone
Cannot get phone to ring only vibrate
To change the Nokia 6133 to ring, do the following-
Select Menu > Settings > Profiles > Select any one profile that is available in your mobile. (Ex. General)
1. Menu > Settings > Profiles > General > Personalise > Incoming call Alert > Ringing
2. Menu > Settings > Profiles > General > Personalise > Vibratibng Alert > Off
After this activate the profile(Ex. General)
Menu > Settings > Profiles > General > Activate
After this the phone will only ring and wont vibrate.
If you want both then change the vibrating alert to On.
Good Luck.
Jun 04, 2010 | Nokia 6133 Cellular Phone
My tones/alarm
separate alarm you may use the calendar to do list to set alarm times for each scheduled tasks you want. and if you just want your phone to just vibrate and not ring then costumize your profile put your incoming call alert to off then on you vibrate and thats it!
Jul 15, 2009 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
No tones on nokia 6131
check your buzzer if it was still ok, using tester set it in X1 if the buzzer creates sratch sound if you connect your testprove in the terminals of your buzzer it was ok but if you cant hear any sound, it was defective, so you have to replace it. good lack........
Jul 18, 2008 | Nokia 6131 Cellular Phone
Turn vibrate on ?
let me sole it by steps do it step wise
1. menu 2. profiles 3. general 4. personalize
then move down to incoming call alert than select off
and move vibration select on
did i solve the problem
Jun 14, 2008 | Cell Phones
How to turn vibrate on?
You can change the settings of the selected active profile.
Select Menu > Settings > Tones > Incoming call alert, Ringing tone,
Ringing volume, Vibrating alert, Push to talk settings, Message alert
, Instant msg. alert tone, Keypad tones, or Warning tones. You can
find the same settings in the Profiles menu.
Jan 16, 2008 | Nokia 6288 Cellular Phone
Ringing problem
try via using another profile in settings...option is there...else restore ur handset.....if that silent mode does not remove then do flash upgration....speaker is fine if u r able to hear the incmoing call.
Aug 05, 2007 | Nokia 6610i Cellular Phone
Nokia 6131 Cellular Phone Logo
350 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
