Question about Sony ICF-SW7600 AM/FM/SW Radio
Problem with FM reception.
My radio is the 1991 edition.
FM ceased to work. Only part of the band at first - then nothing except the interstation hiss over total Freq range. Some motorboating in the early atages of failure then nothing.
No problems with AM, SSB & SW
Regards
Brian Bartrum
Christchurch
New Zealand
  • happyyear Nov 17, 2008
    i have the same problem, the progress of the problem was bigger, resulting in no fm/am/
    i want to fix it on my own plz help me
  • Anonymous May 01, 2009
    the fm band on  my car  stopped .  the AM is fine  but just silence  when I switch  to FM.  What can be  my problem
  • 494 Answers
Sony radios of this era had notorious capacitor problems.... also several other brands were affected. These capacitors were underrated and the technology to make them was not at it's best back then. The cure is to replace the capacitors on the board with new electrolytics. About 28 of them need to be replaced but the big problem is to find someone to do this. the original capacitors are surface mount and must be removed and new radial lead caps put in their place, some are rather tough to get at and the new ones have to be placed carefully. My SONY ICF-SW7600 now works as new and maybe even better!
I have done this myself as I have skills working with surface mount capacitors. I offer my services to those who cannot find service for their radios. Please email me for details, I am not into making bucks on this, I just want to see these radios kept working and bringing enjoyment to their owners.
Good DXing Rod KB8DNS (copied and pasted)
Posted on Jun 17, 2009
  • 10,594 Answers
Do you want to repair it at own? if yes, you need enough electronics knowledge, sufficient tools to carry out repair process and service manual of subject unit to locate defective parts.
Problem seems few capacitors and 1 or 2 band-pass filters replacement.
If you still want to repair it, please let me know to help you out.
Good luck.
Posted on Sep 09, 2008
    Problem Solver:
Hi welcomejee, u helped me solve 2 problems now, so thanks so much :)
now i have new problem!
can u help me here? thanks
http://www.fixya.com/support/t5015091-sanyo_vm_es88p_camcorder_hazy_black
Posted on Jun 03, 2010
I experience a problem with the unit in radio mode. When switched on the radio do not latch on the station (only background hiss) Only after repeatedly toggling the BAND button (random times)it will l
Try turning off the AutoTune (lock, center....) function (on most FM tuners) and retune manually to the errant station. Then reactivare auto-tune, or not. Toggling bands (as you put it) means that sometimes signal will center, sometimes not...a more or less random thing as you say. That suggests resetting station auto lock. Bear in mind though that certains stations can simply be uncooperative depending on numersou factors such as transmit location, reception terrain, and so on.
Oct 03, 2014 | Crosley CR7002A Turntable
Why won't FM radio work on the Motorola 6310 two-way radio?
It's a two way communications radio, not a broadcast radio, hence it won't receive FM/AM broadcast radio stations.
You should not confuse the two as they work on different radio bands, most FM broadcast radios are on the 86-108MHz bands, whereas two way radios operate on the following bands:
1-86MHz, 108-174MHz, 220-520MHz & 865-920MHz
I don't know which band your radio works on, but not broadcast bands I'm sure.
The only exception to this is the smaller hand helds, which may have FM broadcast programmed, but if this is the case with yours, This issue is out of the realm of two way radio queries, as Broadcast radio is not two way radio, but one way radio, and I'm not competent enough to answer Broadcast radio issues.
Cheers, Peter@FixYa Team
Nov 17, 2012 | Radio Communications
I CANT GET THE FM/AM BAND TO WORK
Connect a good FM antenna to the unit's antenna jack to make sure you get good radio reception. Power on the unit. Press the Tuner/Band button. Adjust volume and tune to a known station using the up or down arrow buttons..
Mar 05, 2011 | Sharp CD-MPX850 Shelf System
I just purchased the G6 Aviator. The FM band works well, but none of the AM or shortwave stations get reception. I have tried the antenna up and down, indoors and outdoors with no success.
It sounds like the whole am band is not working which includes the shortwave bands, there is no remedy to correct this and is clearly a manufacture defect. The best solution is return the radio because there is nothing more that can be done in it's present condition.
Mar 03, 2011 | Grundig G6 Aviator (Buzz Aldrin Edition)...
Grundig g6 airband in khz and poor reception
I think having the display showing MHz for the air band would have been a better choice on Grundig's part, but it really doesn't matter that much. Its just a matter of moving the decimal point to the left three places.
As far as getting better reception on the air band, here are some tips:
1. Use an antenna.
2. Try other antennas.
3. Find a known active freq.
4. Find a freq. low of FM spurs.
5. Turn up the volume.
I own and use a G6, and get decent results with it on the airband.
Aug 20, 2009 | Grundig G6 Aviator Radio Buzz Aldrin...
Best Buy hooked up my sirius radio through the fm tuner.
Yes you can my brother bought one of those after market radios and you can run it on three different channels you need to find one that has nothing on it including hiss. look in the book and it will tell you the different channels. Also Be sure you have the reciever on the dash in the center at the top for best reception or lower it tothe middle to find the best reception you can get. it is important to get it in the right place for it to work.
Jul 17, 2009 | Directed SV1 SIRIUS Radio Receiver with...
No AM radio reception in my 2002 Audi A4
do you get any stations, even weak stations on the AM band?  If not you have a bad radio and need replacement.  Try having someone hold the antenna as you scan the AM band.
Apr 01, 2009 | 2002 Audi A4
JVC detachable face with auxillary input
You may have a bad antenna or antenna cable.
FM signals are measured in microvolts and are easily influenced by poor antennas or a mashed antenna cable.
Aug 12, 2008 | JVC AM FM CD DET FACE CAR STEREO
AM reception/AM power problems
Don't take your radio to work. Get your work done , then go home and listen to it. You will get better reception in a res. area.
Oct 08, 2007 | RCA RP7887 High-Performance Super Radio
Sony ICF-SW7600 AM/FM/SW Radio Logo
459 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
