Question about Tissot T-Touch T33159851 Wrist Watch
T Button inoperative
My T button works only very occasionally. The + and - button allow me activate the crystal but the lack of T button function means I cannot synchronise the watch
    Master:
    Sergeant:
  • 460 Answers
Get it serviced.. where in they will spray lubricants and clean the minute mechanisms..
Posted on Sep 09, 2008
How to turn off the alarm?
http://www.freestyleusa.com/support/
the second window down has the buzz instructions.
in the buzz instructions
TO TURN ON/OFF THE ALARM AND
HOURLY CHIME:
1. Press S3 button to select HOME ALARM or FOREIGN ALARM to set. 2. Press S1 button to activate the alarm. Alarm indicator /
will appear.
3. Press again to activate the hourly
chime. Chime indicator will
appear.
4. Press the third time to activate both
functions. Both of the indicators
will appear.
5. Press fourth time to deactivate both
functions. Both indicators will
disappear
May 30, 2014 | Freestyle Shark Buzz Wrist Watch
I just bought a Kenneth Cole Unlisted mens watch. There is no instructions on how to set the day and date. Is it broken out of the box or are those dials just fakes? Jens
The Mode button on the bottom left hand side will set your "SET" buttons to work.
The first push of your Mode button will activate your Stop Watch. Press the top right button to time your subject. Press it again to stop timing your subject.
Pressing the bottom right button will reset your Stop Watch to zero.
Press the Mode button to release your Stop Watch function and return to the Telling Time function.
Press the Mode button twice and you'll be able to set your Alarm function. Your Hour number will be flashing. Press the top right button to set your Alarm Hour. If you Alarm Hour is for the afternoon or evening continue pushing until a "P" appears by your hour number . This will be your afternoon/evening hour. If there is no "P" that, of course, will be your morning hour.
Press the bottom right button to adjust the minute number of your Alarm function. Your minute number will be flashing. Again, using the top right button, you'll be able to adjust your minute number.
(If you hold any number changing button for a long time, the numbers will flash through rapidly.)
Press the mode button to release your Alarm setting function.
Press the Mode button three times to set the Time of Day on your watch. At this point you'll also need to push the bottom left button to activate your Time of Day function. after pressing the bottom right button your minute number will start flashing. Press the top right button again to adjust your minute number. Once that's done, press the mode button to release your time of day function.
Hope this helps!
Oct 18, 2010 | Kenneth Cole Watches
Hello, I am from Greece and own a Tissot T-touch titanium. I just received it back from Tissot's service, I sent it for a battery change and a compass calibration, as it did not work well. As it was...
Its a good watch and good company, I would send an email to Tissot head office customer service. Praise the brand but insist you are not happy with the local service, having already had a failed repair. Hopefully they will accept it back for repair or replacement.
Mar 12, 2017 | Watches
I have a problem whit my Casio W94HF. It just stop working. It show the time but you can't push any button until I reinstall the battery help me please :)
usually when the watch still works but you cannot make or change any settings and you do not see any reaction or change when you push a button, then it means that one of the buttons is stuck (as if permanently pushed) and the watch will not react to any button until the stuck button is released. Inside the watch there are metal fingers (contact blades) that the buttons actually push, and sometimes one of these finger blades can get stuck even though the button has returned outward. try (with tweasers) to pull on each button to see if it will move outward and allow the watch to start functioning again. If not, then the watch must be opened,and with a fine pin-like probe, each metal finger blade must be tested for proper movement and position. Also, when a battery is replaced, occasionally the housing is not seated correctly when the "movement" is replaced in the housing (if it was removed in the first place), when the cover is back in place, if there is a plastic or metal bezel ring, maybe the ring is not seated correctly. goodluck, Macgivor
Jan 27, 2010 | Casio W94HF-3AV Wrist Watch
The anlog display does not synchronise with the digital display.There is a time difference of 2.5 hours. I got the batterie replaced which didn't change anything.Thank you in advance for your help
Activate the crystal, then find the clock calendar function. Hold the center button for 5 seconds until a synchro appears on the data screen, then start pushing top button to move the minute hand to the 12:00 then push bottom button to move minute hand to 12:00. after this is done hold center button for 5 seconds and hans will move to match time on your digital display. Now that you are synched,you can set time as you normally would.
JRH, Rhode Island
Nov 25, 2009 | Tissot T-Touch T33159851 Wrist Watch
I am trying to reset my T Touch watch from Tissot and can not find book. need to reset time and also how to convert from metric to US standards, like ferinhit and from meters to feet.
SET TIME:
1. Activate Crystal
2. Tap center of screen until digital time comes up
3. Press and hold top button (+) until watch beeps, display will be flashing
4. Use + and – key to adjust time. If several hours off, hold appropriate key and
after first hour passes, only the hour hand will move.
5. Make sure the digital display shows A or P for AM or PM
6. When finished, touch center of screen again.
SET DATE:
1. Activate Crystal
2. Tap center of screen until date appears
3. Press and hold top + button until watch beeps and display flashes.
4. Use + and – buttons to change date to correct one.
5. Make sure to set time first, if you set date first, you run the risk of the date
changing at noon rather than midnight.
Nov 26, 2008 | Tissot PRS 516 T91142651 Wrist Watch
Fix the hands correct with the dejital
Sometimes a watch will be off center due to shock, dead battery etc. Symptoms are;
hands don’t line up, digital and analog time doesn’t match, Compass function doesn’t
have the hands exactly opposite etc. This can all be fixed. The Synchronization
function can be used:
1. Activate Crystal
2. Tap center until you are the unit’s screen (12h or 24h, F ft or C m).
3. Push and hold (at least five seconds) the center crown
4. Watch will beep and word (SYNCHRO) will appear in the display.
5. Use the top + button to line up the minute hand right on the 12.
6. Use the bottom – button to line up the hour hand right on the 12.
7. When finished, press crown and you will go back to time.
Nov 16, 2008 | Tissot T-Touch T33759851
T touch Meteo out by 20 Milibars
Certain functions need to be calibrated. The altimeter and the Meteo are tied together. When a customer gets the watch, they should calibrate to either the Meteo or Altimeter. The easiest way to find out the altitude of the nearest airport (you can usually get this on line) and then go to the airport and adjust the
watch. This will also calibrate the Meteo.
To calibrate the Altimeter:
1. Activate Crystal
2. Press Altimeter
3. Press and hold top + button until the watch beeps and display flashes.
4. Use + and – buttons to adjust altitude
5. Press center of dial to lock in.
Oct 14, 2008 | Tissot T-Touch T33159851 Wrist Watch
Changing to metric
1. Activate Crystal
2. Tap center until units screen appears (This will say either 12 or 24h and F ft or C
m)
3. Press and hold top + button until watch beeps, display will be flashing.
4. While flashing, press top + button which will change the C m to F ft and back
5. While flashing, press bottom – button which will change the 24h to 12h and back.
This will also change the date format. If in 24h the date will be Date/Month, if in
12h it will be Month/Date.
Oct 03, 2008 | Tissot T-Touch T33759851
Tissot T-Touch T33159851 Wrist Watch Logo
111 people viewed this question
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Shehu Pro
Shehu Pro
Are you a Tissot Watch Expert? Answer questions, earn points and help others
