Question about Sharp LC-26D6U 26 in. LCD Television
Diagram? Hi, I have the same problem with the LC-26D6U about the sound, witch capacitors are you refering to? do you have a diagram that you can share?
    New Friend:
Smps no working set is dead
Posted on Nov 28, 2014
  • 16 Answers
Almost all intermittent audio or audio failure problems with Sharp Aquos LC**D4U, LC**D5U, LC**D6U, and LC**D7U televisions are the result of a relatively simple design flaw involving the heatsink pad compound used on the Tripath TA-2024 amplifier chip (IC2502) found on the A/V board. This compound has a fairly low melting point and, over time, tends to seep out from between both top and bottom heatsinks onto the legs of this chip as well as onto circuitry immediately surrounding it. Further, over time the seeping compound also becomes somewhat conductive creating bridges which short the audio amplifier circuit causing everything from intermittent audio to complete audio failure.
Fortunately, in almost every case audio can be completely restored by cleaning the old compound from both top/bottom heatsinks and from both sides of the PC board in the area immediately surrounding the chip (I used rubbing alcohol which worked quite well). Sharp has issued a service bulletin addressing this issue (LCDTV-194) wherein a ‘2502 Heat Kit’ is specified. This kit is Sharp Part Number: PSPKIT663WJZZ and is available from for $19.95. However, it’s entirely possible to get by with the heat pad only, Sharp Part Number: PSPAZA663WJKZ for only $9.95. Please note that board replacement for this problem is almost never necessary, so if you’re working with a repair technician be sure and insist that he/she be certain to try cleaning the old board and replacing the aforementioned heatsink pads before charging you for a new board.
If one is reasonably familiar with electronics disassembly/reassembly and is willing to take their time, this can even be a DIY project. It is possible to find ‘important service references’ by simply entering LC26D4U (the 5, 6, and 7 series are very similar, and this information covers all screen sizes) into the search field at This will greatly aid in disassembly/reassembly of the TV, as the A/V board is somewhat ‘buried’ under other boards. Please refer to post # 373 at for pics of the information detailed here.
My knowledge of how to solve this issue came primarily from finding the research efforts of ‘Aureius’ on the AVS forums, and particularly from his taking the time to post the solution publicly so that others might save time, money, and aggravation. I'm just passing along the information. Thanks Andy!
I also wanted to mention that a couple of other very pesky common problems with these series of Sharp TV's involving symptoms of random powering-off and/or powering-on, and 'function lock-ups' of various sorts are easily remedied through two firmware updates (Main CPU: PH1UU112, Monitor: MD1UA104). These are not available to end-users via the internet but it may be possible to get the files from an understanding factory-authorized repair tech. They are installed using an SD memory card (don't use the HC high capacity sort, use only those that are NOT HC) which is inserted into a special slot in the back of the machine. For those of the DIY persuasion, information about how to check whether your TV has old firmware in need of an upgrade is readily available through internet search.
Posted on Feb 20, 2009
Let me know also!  I am about to open her up!!!
Posted on Oct 13, 2008
I am missing the 4 screws that secure my TV to the stand and needed to know what size screws to buy. The TV is a Sharp LC-26D6U (old TV). Any ideas? Thanks.
They probably are metric M8 but the length is critical. Too short won't hold and too long may interfere with circuitry underneath.
Feb 14, 2017 | Sharp LC-26D6U 26 in. LCD Television
Sharp LC-26D6U turns on to a blue screen
Your set need a though check up. It sounds that the main digital board has damaged. Before make it sure, contact any service technician and make it confirm. A panel fault too can cause this. If you wish to get more details about this kind of fault, check this link. If you're sound in electronics, you can follow the rest. Pull up older posts there, either by its left side bar, or, see it in 'Timeslide' option.
Jun 22, 2013 | Sharp LC-26D6U 26 in. LCD Television
My sharp lc-26d6u aquos got picture but no sound, anything i can do? thanks!
No sound on ALL MODES?
Let verify first to narrow down to where the problem can be. First, make sure the MUTE or SAP function is not activated, then check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks (Red and White) to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit.
Please post back what you find.
Failed TV and Monitors:
Learn about bad caps:
Capacitors kit: he can make you a set of caps.
Or just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 26, 2011 | Sharp LC-26D6U 26 in. LCD Television
TV does not turn ON. It was working , and suddenly the screen went off. It does not even show the Power standby light.
It sounds like a power supply failure, given that you check the obvious( power cord, power in the outlet etc.). Part number for the power supply: RDENCA138WJQZ.
Jan 11, 2010 | Sharp LC-26D6U 26 in. LCD Television
My Sharp LC-26D6U TV - low audio
Sharp is taking care of this for customers even if you are out of warranty due to a mistake on how they made the tv. All you have to do is call Sharp at 1-800-237-4277. Please make sure that the repair shop also applies 2 firmware updates that all the D6U tv's need to avoid other known issues with the lcd in the future. These firmware updates are for the main cpu PH1UU112 and the monitor MD1UA104. Good luck!
Sep 28, 2009 | Sharp LC-26D6U 26 in. LCD Television
No sound at all!
I agree with everything that they are saying.
Most tv companies under design the cooling needs of the flat panel TVs. I had to fix a few TVs this way that had similar problems. Mostly with the picture on TVs freezing up because of the poor cooling design for the motherboard processor. I would give their solution a try before replacing circuit boards.
Jun 10, 2009 | Sharp LC-26D6U 26 in. LCD Television
The sound just quit
check your speakers & your sound board
Jul 07, 2008 | Sharp LC-26D6U 26 in. LCD Television
Sharp LC-26D6U sound issues
Capacitor is what I found out.. (Supposedly althoug Ive not verified).. If you can send here I'd love to see the unit...
(Theres a reason)....
Dec 27, 2007 | Sharp LC-26D6U 26 in. LCD Television
Sharp LC-26D6U 26 in. LCD Television Logo
226 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
