I recently upraded my computer with an Asrock Penryn1600SLI-110dB motherboard with an Intel CORE 2 DUO E4600 processor. The symptoms are: When I tried to boot for the first time the cpu and case fans started but nothing else happened. The screen remained blank with no post check and the disk drives did not start. I replaced my old mother board back into the case and everything worked fine. I have de-installed the processor to check if I had done anything wrong it all looks OK to me. The socket pins look in perfect condition.
    Problem Solver:
  • 9 Answers
If you have recently upgraded your motherboard and when you turn it on, there is no display. You could check the jumper setting of your motherboard.
Check this site for jumper settings. Download the manual. Go first to page 11 and find clear CMOS jumper. That will be number 17. Then go to page 24 for the correct jumper settings. Jumper should be on the pins 1 and 2. That's the default settings.
If the jumper is set already to 1 and 2. Clear the CMOS by putting the jumper on 2 and 3. It should be off when you are going to set the jumper. This is to make sure that the settings for your motherboard is set to its original settings.
If you are going to clear the CMOS settings, you will have turn the computer on after clearing it and then turn it off again. Put the jumper back to pins 1 and 2. Now make sure that computer is totally off. Uplugged the computer just to make sure when you are doing this.
To test also the motherboard if it is working, do not connect the other pheriperals such as network card, sound card, and other cards that is not buit-in. Also drives such as Hard Drive and CDROM drives.
Check for beep codes. Short beeps tells you that the Video card is not inserted properly. Long beeps tells you that the memory card is not in place correctly.
Just remove the Video card or Memory card and then place it back again.
Computer should be off as well when doing this.
Posted on Sep 09, 2008
How to clear cmos on FoxConn_925XE7AA-8EKRS the board will not find keyboard
Unplug power remove battery try to turn comp on several times replace battery plug in power & you should then have to set everything in bios done
Feb 05, 2013 | Intel ASRock Penryn1600SLI-110dB LGA 775...
Sir,i have intel motherboard d945gcz.i want to know that it actually support core 2 duo processor..?
this motherboard have processor socket LGA 775, so it can use for pentium 4, dual core and some core 2 duo. this is short list of core 2 duo that have socket LGA 775 specification: Core 2 Duo E4300, E4400, E4500, E4600, E4700, E6300, E6320, E6400, E6420, E6540, E6550, E6600, E6700, E6750, E6850, ..... (there is a lot of list that i can type in here, even there is Core 2 Quad that be use on this socket) ------> more detail visit this wikipedia website:
hope this useful, regards. Happy browsing.
Aug 22, 2011 | Computers & Internet
My motherboard model is D101GGC Is this support CORE 2 DUO E4600 processor
This motherboard model will not support Core 2 Duo E4600.
It will support only.
1.Intel Pentium D Processor.
2.Intel Pentium 4 Processor.
3.Intel Celeron D Processor.
Thanks for using FixYa.
Jun 03, 2011 | Intel D101GGC Motherboard
My motherboard gives 8 beeps and shows no video, I tested with several video cards and gives the same result. when the computer beeps (normal as it recognizes that although the bios), then emits...
Continious beep codes are caused by the memory (RAM). Try reseating your RAM just plug it out clean it then put it back in. Or try the other memory slots. Just transfer your memory to the other slot if you have an available slot on your motherboard. Or simply buy a new memory (RAM). Just make sure it is compatible to your motherboard. Beep codes means the computer is not reading the memory (RAM) properly. There is no post and no video in your computer because the RAM is not working properly.
Dec 19, 2010 | Intel ASRock Penryn1600SLI-110dB LGA 775...
Motherboard problem?
the problem is the northbridge ,is not working buy another motherboarde
Jul 04, 2009 | Gateway GT5685E Desktop Computer - Intel...
Can i use nvidia 8600 video card for my mother board asus p5pe-vm and processor intel core 2 duo to my motherboard
this are the CPU -s that you're mb can support (core 2 duo)the numbers after "All" are the bios version's you need for the cpu: Core 2 Duo E4300 (1.8GHz,800FSB,L2:2MB,65W,rev.L2) ALL 1201 Core 2 Duo E4400 (2.0GHz,800FSB,L2:2MB,65W,rev.L2) ALL 1202 Core 2 Duo E4500 (2.2GHz,800FSB,L2:2MB,65W,rev.M0) ALL 1406 Core 2 Duo E4600 (2.4GHz,800FSB,L2:2MB,65W,rev.M0) ALL 1406 Core 2 Duo E4700 (2.6GHz,800FSB,L2:2MB,revG0) ALL 1501 Core 2 Duo E6300 (1.86GHz,1066FSB,L2:2MB,rev.B2) ALL 0604 Core 2 Duo E6300 (1.86GHz,1066FSB,L2:2MB,rev.L2) ALL 1201 Core 2 Duo E6320 (1.86GHz,1066FSB,B2:4MB,rev.B2) ALL 1402 Core 2 Duo E6400 (2.13GHz,1066FSB,L2:2MB,rev.B2) ALL 0604 Core 2 Duo E6400 (2.13GHz,1066FSB,L2:2MB,rev.L2) ALL 1201 Core 2 Duo E6420 (2.13GHz,1066FSB,L2:4MB,rev.B2) ALL 1402 Core 2 Duo E6600 (2.40GHz,1066FSB,L2:4MB,rev.B2) ALL 0604 Core 2 Duo E6700 (2.66GHz,1066FSB,L2:4MB,rev.B2) ALL 0604 Core 2 Extreme X6800(2.93GHz,1066FSB,L2:4MB,revB2) ALL 0604 and for the graphic card because you motherboard has the "AGP" interface and the nvidia 8600 has "PCI - express" interface as is described here:
Jun 14, 2009 | ASUS P5PE-VM Motherboard
Penryn1600sli-110db CMOS CHECKSUM BAD ERROR
I would replace the battery as the 1st thing, however I would also change your cpu fan for a new one and reseat the processor. Also get some decent cpu paste and make sure this is applied properly, and dont forget to wipe the old stuff off!
Does your case have anywhere were you can place some fans? It sound slike you have two problems to me, the battery being one and the overheating the second
Dec 18, 2008 | Intel ASRock Penryn1600SLI-110dB LGA 775...
CPU Upgrade on Toshiba L40-14H
i do not believe that cores are physically exchangeble for core 2's
Sep 23, 2008 | Computers & Internet
Computers & Internet Logo
124 people viewed this question
David Payne
David Payne
