Question about Garden
Installing lawn mower battery
What does the positive (+) and negative (-) mean on the battery? and how should they be set.
  • 1 more comment
  • DALEMANY7 Nov 12, 2008
    I HAVE THE SAME PROBLEM ON CRAFTSMAN 917.272263 TRACTOR START ONLY WITH A BOOT OR A CHARGE AFTER I USE IT AND TURN IT OFF IT WILL NOT START. A GOT A NEW BATTERY AND NEW STARTER WHAT NEXT?
  • fallingchip Mar 24, 2009
    A new battery last two weeks. Now the battery cables are sparking and melting the battery terminals, and yes they are hooked up right.
  • Clint Fonder Jul 26, 2013
    Are you sure it's hooked up right? The mower should blow a fuse before it melts the cables except if the cables are reversed. Check any light wiring. Headlight wiring in the grill is notorious for arching, causing battery damage.
I have Yardman, MTD, 13 HP, 38", 6 speed. Put in new spark plug and new battery. Started first time and successive times (2), battery is completely drained. Can be jumped and started and will mow, but when it is shut off, there isn't any battery to restart. What would be draining the battery or not allowing it to recharge????
Posted on Oct 05, 2008
How do I connect wires by color code for reinstallation of something?
images for mower How do I connect wires by color code
Is the Positive or Negative Cable Attached First in a Lawn ...
homeguides.sfgate.com > ... > Real Estate Rental & Lease Basics
Attach the positive cable first when working on a lawn mower battery. Nearly all ridingmowers and many walk-behind mowers are equipped with a battery for ...
free wiring color codes Riding Mowers & Garden Tractors ...
www.fixya.com/...wiring_color_codes/riding_mowers_and_garden_tract...
Ask your free wiring color codes riding mower and garden tractor questions. ... ENDSDO NOT MATCH FEMALE ENDS ON COLOR CODE CONNECTIONS ...
Nov 26, 2015 | Garden
Why does it keep blowing the 30 amp fuse as soon as I turn the switch?
You have what is commonly called an "Dead Short". Meaning that one or more wires that carry positive flow from the battery is grounded against the frame (In most cases that I have seen) Tracing a short can be a hair raising experience if it is intermittent. The first thing to check is the negative battery cable to make sure it is clean and tight. Then follow the negative cable down to the the frame or under the frame and make sure the bolt is tight. Also, if your engine bolts are loose, this also will cause the fuse to blow.
George
Aug 10, 2015 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
Removal of battery from Craftsman Model 917.377170 key-start lawn mower
remove the hold down and negative first and then positive cable , reverse procedure to install
Feb 10, 2015 | Craftsman Garden
Can't remember how to charge battery in craftsman 675 lawn mower
first hook up positive side of charger then negative side of charger make sure you do this in open air so battery gas can excape while charging
Sep 26, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
Which side is the positive battery terminal wire on an Ariens riding lawn mower
check and see that one terminal should lead you to the starter,it should be a positive
Jul 02, 2013 | Garden
What size battery for cub cadet 2006 cub cadet
Most machines will have a negative earth, this is normally a black wire , follow the wire , it will be screwed down to eart against the chassis, the live wire will be red, follow this wire and it will go to the start solinoid, there may also be a low tention wire from the live terminal this will have a fuse somewhere in it,
Mar 04, 2012 | Northern Tool Lawn Mower Battery 12 Volt,...
How do I install a lawn mower battery
Have you ever installed a car battery is about the same but for the mower on each post there are holes to put bolts through and you hold the bolts with nuts the red wire goes to the positive which on most batteries has a + sign above it and the black wire goes on the negative which will more then likely have a - sign above it.Now to review red to + and black to - ok. Good luck.
Apr 19, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
No spark
Also make sure that your battery is installed correctly. Red to POSITIVE (+) and black to NEGATIVE (-).
Regards!!, --W/D--
Jul 23, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
458 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
