GREEN BLINKING LIGHT
MY MODEL IS WD-52528 WOULD YOU PLEASE TELL ME ME THE 5 CAP. NUMBER TO REPLACE. MY E-MAIL IS BAMABOY409@YAHOO.COM THANKS JOHN
  • 4,234 Answers
The caps that require replaceing are teh 1000ufd caps on the "DM" board. This board should be encased in a metal shield. Be careful when removing the board. Make sure that these caps are replaced with 105c caps not the 85c ones. (temp rating).
Dan
Posted on Sep 10, 2008
I have the WD 62627 model. the lamp light is on, when i power up the tv, it comes on for like 6 to 10 secs then it turns off. Does this mean I need a new Lamp?
I would say that it probably is a bad capacitor on the power supply board of the tv. What you want to look for is any round cylinders with the tops pushed up at all. The replacements are usually really cheap, it might also be the lamp, but usually when lamps go they go completely while a bad capacitor is known to cause intermittent problems that escalate into a tv only working for about 5-10 seconds.
May 03, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Green light keeps flashing but TV will not turn on. The light goes out for say 30 secs. then will start the flash cycle again... over and over
bsdubbink,
You could literally have anything wrong with your unit. I have a tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting would should help with the troubleshooting part.
Thanks for using FixYa.
hardrocko
Feb 08, 2011 | Mitsubishi WD-52528 52" Television
Timer light keeps blinking
you probably had a power bump, unplug tv for 1 hour turn back on and hit the reset button, if the green light quits blinking your good to go. If not you might have capacitors gone bad not cool.
Apr 03, 2010 | Mitsubishi WD-52528 52" Television
Black screen, blinking green light, nothing happens
Hi it is the indication of error code......can you tell me how much time does light blinks......
Jun 03, 2009 | Mitsubishi WD-52528 52" Television
Problem with Mitsubishi 52525 TV
A teady blinking green Led is usually caused by the foru 1000uf 16V capacitors on the DM pwb
May 24, 2009 | Mitsubishi WD-52528 52" Television
MITSUBISHI BLINKING GREEN LIGHT
replace the dmv pcb, replacing just the cap is a temp fix, that is if it works location number is c9624
Jan 11, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Blinking timer light will not turn off.
You most likely have a fault in the defelection circuitry that is causing this. A repair is needed, none-the-less....accordianman
Jan 01, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Green blinking light
the chassis needs to be rebuilt.check out www.tv-techs.com
Jan 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wd 52725 blinking green light
I HAD THE SAME PROBLEM. I POWERED IT BACK ON BY UNPLUGGING AND THEN HITTING THE RESET BUTTON. AFTER ONE MINUTE OR SO THE LIGHT WENT OFF AND I WAS ABLE TO POWER ON.
I STARTED THINKING WHAT COULD HAVE TRIGGERED THIS AND IT STARTED AFTER WE HAD A SHORT POWER OUTAGE.
I HAVE NO IDEA IF THIS WILL WORK FOR YOU BUT I AM ON MY SECOND DAY OF NO BLINKING LIGHT: I WENT TO THE MITSU TV MENU AND RESET MY CLOCK... I PUT IT ON MANUAL SETTING AND RESET TO PROPER TIME AND I HAVEN'T HAD A PROBLEM. IT'S WORTH A TRY. I'LL KEEP YOU POSTED..
JM947
JM947
Dec 20, 2008 | Mitsubishi WD-52725 52". Rear Projection...
WD-52725 Timer light is blinking and will not stop.
This part will cost you about 650 to 800 bucks my friend. if you have any soldering skills, and can follow directions, I posted a DM board fix. it may just be four small capacitors. Now this set that was used in the fix is not exactly like all the other Mitsubishi TV sets that still have a DM board, but if you can locate the DM board, follow the rest of the repair. if you do not know how to solder, do not take a chance, as this part is way too expensive to be experimenting around with. Get the Capcitors(there is a link there too for the capacitors)and take the DM board to a service shop, as this should not cost you a lot to have a pro do this for you. The DM board fix is located here: http://www.fixya.com/howto/h154057-mitsubishi_dm_board_repair Good luck
May 27, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
