Question about Philips 50P8341 50" Rear Projection Television
Philips 50p8341 chassis PTV915
Hi Aj, Is the service manual not the same as the photo-fact from Sam's, this tv work is my part time hobby.
    Genius:
  • 2,035 Answers
Well the manual seems ok ,but you need check the board as there burn out in it which causing this problem check the IC S and the tracks on the board ,even bad connectors can cause this problem...
Good luck...
Posted on Sep 09, 2008
Philips TV keeps kicking off(lose of power)
moses1,
What you have there is a PTV915 chassis that has an Ssb board failing in it... To be more precise the smt (Surface Mount Technology) caps on the Ssb are failing. The board is mounted on the Lsb (Large Signal Board) vertically, just behind the tuner.
The module itself is Philips original p/n# 313912725871 and has been subbed to Philips p/n# PH3912725871 they're about $275.00 dollars.
Or you could take a risk and order one. But I'd still have the technician come out and install it for you... There are some star screws, which Philips has some infinity for, that are kinda difficult to get to and they need to be removed to access the module and extract it...
Hope this helps!
Bill
Nov 10, 2007 | Philips 50P8341 50" Rear Projection...
Replacement Lamps/Bulbs for Philips 50P8341 Rear Projection TV
These are both CRT type TV's(3 picture tubes drive the image) with different screen sizes and the CRT's are not interchangeable
Oct 24, 2009 | Philips 50P8341 50" Rear Projection...
Hi, My philips 42'' plasma won't turn ON. I went to turn it on and the ''on'' button flashes red 7 times 4 seconds apart
I just had the same problem. I downloaded a service manual and give this a try http://www.servicemanuals.net . Turn on your TV and with the remote do the following Key in the code “123654” via the standard RC transmitter. This get you into a customer service mode and you can check your error codes.
After I got out this mode my TV worked. I think the TV was stuck in protection mode for some reason and by entering the service menu's it reset it.
I then entered the SAM Mode
How to Activate SAM
Via a standard RC transmitter: key in the code “062596”
directly followed by the “INFO” button. After activating SAM
with this method a service warning will appear on the screen,
you can continue by pressing the red button on the RC.
It will give you more info.
The TV worked fine after I exited these menu's.
I also did a software update as per the user manual and the TV seems to be working fine again.
Hope this helps
Sep 09, 2009 | Philips 42PF9631D 42 in. Plasma Television
I HAVE A PHILLIPS MODEL 50P8341 REAR PROJECTION TV THAT COMES ON ,THE RED POWER LIGHT BLINKS FOR A SECOND AND THEN CUTS ITSELF OFF
Try the power supply. Look on the one in your TV for the part number ; mine is PH3501705441. I ordered one from partstore.com and it was less than $60 shipped. Hope this helps, mine works fine now........and I have a 50P8342 chassis PTV 916
Dec 10, 2008 | Philips 50P8341 50" Rear Projection...
Philips Projection Screen TV Model PTV915 Horizontal Alignment
Problem solved, needed to get the universal remote i was using set up with the proper code. Once I did that I was able to use the remote to set up the single & multi-zone Red & Blue Alignment.  I also pulled the back plate off and manually adjusted the RGB focus knobs. It seems to be working just fine now.
Thanks to all the other posts.
Nov 25, 2008 | Philips 50P8341 50" Rear Projection...
Philips model projection
hello dm beatty, First i must ask if you have anything placed on top of the tv? second what i would suggest is for a professional repairman to come and fix it. There are proceedures which you may do it yourself but if you were to mess up it would cost you a new tv. If you would like more assistance to do it yourself place post again and i will be happy to assist.
Please post what you do and how you did it. I look forward to your posts.
Nov 02, 2008 | Philips 50P8341 50" Rear Projection...
Power Button Light Flashes six times Chassis# PTV915
Replace SSB p#313912725871. (Small signal board.) New part #PH3912725871. They also sell a kit PH3912725871-KIT.
Oct 07, 2008 | Philips 50P8341 50" Rear Projection...
TV not working...no picuture, no sound
your tv needs to be taken to a tech the problem is on the IF module the tuner is also on that module.you can get parts at www.dalbani.com or www.repairworld.com and service manual try www.partstore.com.good luck
Apr 18, 2007 | Philips 50P8341 50" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
170 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
