Question about Panasonic SC-PM19 CD Shelf System
No Power When power button is pushed the power relay will click. Nothing else happens. Other than the light on the power switch being red and the relay click nothing happens. Checked the solder connections and all appear good. Thanks
  • 64 Answers
The click might originate from the cd mechanism, you might be expriencing some electrical display problem.
Posted on Mar 01, 2006
SOURCE:
Nothing happens when I push the power button on the front panel of NAD917 Preamp. Any idea why? Is there a way to reset the box?
Probably a fuse in the unit. Unplug it and open it. If you see a blown fuse, take it out and look at the writing on the metal part. buy a fuse with the same power ratings.
Apr 11, 2016 | NAD Audio Players & Recorders
TV does not turn on? (Relay problem?)
The power supply could be failing intermittently. That's why it sometimes works and sometimes doesn't. Also, the relay could be erratic.
May 26, 2014 | Funai Magnavox 40" Class 1080p 60hz LCD...
32'' Panasonic television. Power switch does not turn the set on.
1 It appears that connecting cable is faulty. Normally when you connect and push the power switch the standby light should lit. Try the cable on another appliance and see its function. Also switch on the TV and try to switch it on with your remote control.
Nov 19, 2009 | Televison & Video
SONY KV34HS510 always worked perfectly but today it wouldn't turn on by remote or button on TV. It makes the same "click" sound which it always did before coming on but it just immediately clicks again to...
You need to bring it to a TV technician. There is a relay inside the TV which can be blocked by any few errors that may occur in your TV, for protection. Only a tech may discover the problem.
May 25, 2009 | Televison & Video
Nothing happens only power button lights or turns off
Count the number of flashes for the red power button. I'm not a Hitachi owner, but you can track one down here on fixya and they''ll give you more info. One of the internal components have failed and is keeping the power supply unit from firing up. Do you hear a relay click when you try to turn it on? If so, how many times does it try to fire up?
May 23, 2009 | Hitachi 57F500 57" Rear Projection...
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
Panasonic SC-PM19 CD Shelf System Logo
190 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Joaquim Martins
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
